| virus |
 virus World Chat Champion
 Posted: 18:55 - 19 Aug 2008 Post subject: gpz carb woes |
ive been doing more work on the gpz750 today, and at the moment when I set the tank to prime when on the side stand the carbs overflow back out the air box side of the venturi after filling the bowls, this only happens on carbs 1+2, 3 tends to stop with a full bowl, and 4 is always bone dry.
Im guessing I need to seperate the carbs and give every passageway a blast with carb cleaner, then set the float heights on them all? or is this all down to the fact its on the sidestand?
Also, what could cause it to backfire through the carbs when I try to start it?
Cheers
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| Finglonga |
 Finglonga World Chat Champion
| Ichy |
 Ichy World Chat Champion
 Posted: 21:05 - 19 Aug 2008 Post subject: |
No4 is probably dry because the lower carbs are flooding. Your needle valves will be stuck or the floats are knackered. You have nothing to lose so give the float bowls a tap with the handle of a hammer. Misfire is either due to a air leak or the poor fuel control. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| prawny1 |
 prawny1 World Chat Champion
| virus |
 Posted: 21:34 - 19 Aug 2008 Post subject: |
Vac tap, only floods when on prime. flood when upright, and its CDI ignition.
Will get the valves checked out soon, I hate working on 16v engines.
Cheers
| prawny1 |
| Grav |
 Grav World Chat Champion
 Posted: 22:07 - 19 Aug 2008 Post subject: |
The Float Needle Valve isn't closing properly. This is usually caused by crap in the fuel sticking it open. After cleaning the carbs thoroughly, reset the floats, fit a filter on the main fuel line and it should cure it. ____________________ Dark Lord Of Custard
snigger.....  |
| prawny1 |
| Ichy |
 Posted: 04:53 - 20 Aug 2008 Post subject: |
Don't split the carbs, its more trouble than its worth and won't help at all with the problem. Just use carb cleaner to clean around the needle valve and check its seating correctly. Carb repair kits cost about £12 per carb so it may be worth looking for another set if you can't sort it. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
The last post was made 17 years, 129 days ago. Instead of replying here, would creating a new thread be more useful? |
