| mowgli0929 |
 mowgli0929 Derestricted Danger
 Posted: 19:00 - 19 Aug 2008 Post subject: Bandit fully naked muscle project...MORE PICS...finished |
SKIP TO THE BOTTOM(ish) IF YOU JUST WANT TO SEE IT FINISHED
About 5 weeks ago I high sided my 1999 bandit 600 doing about 60mph .
All cosmetic damage really...clocks, lights, handlebars, tank split down the side, frame scuffs, brake levers, footpegs etc etc.
Was really anoying though as I'd just got it looking quite nice (although a bit generic) and figured I'd now have to scrap it as it would cost so much to restore.
But...after my dad said he wanted to go to the manx grand prix I changed my mind! Started what was going to be just a basic touch up but it turned into a huge mind boggling project (for me) with a crazy learning curve!
Before I start...you should know I have noooooo money so everything had to be on the cheap, and also that i'm well new to mechanics etc
First, I started with the tank as it had the slight defect of a big split down the side.
Began by stripping all the old paint off with a drill that had a paint stripping wheel attachment i bought (with an old credit note for B&Q )
https://i6.photobucket.com/albums/y205/mowgli0929/bike%20project/DSC00650.jpg
https://i6.photobucket.com/albums/y205/mowgli0929/bike%20project/DSC00652.jpg
Then...the split... 'hmmmm' I thought 'well I can't weld, so thats me f*cked'. Then realised that there was a tractor mechanics down the end of my drive and that the owner owed me a favour
They had a go at welding it but to no avail...apparently the metal is too thin at that point. Luckily though they are clever buggers and filled the hole (which was right on the seam) with loads and loads of solder, which worked great
I then used an angle grinder (drill attachment again...sob) to smooth out the solder and make it flush.
Anyway...i'm sure you're bored without pics, sooooo...
Here's the tank with two coats of primer, then two white coats (btw all paint used in this project was rattle can) :
https://i6.photobucket.com/albums/y205/mowgli0929/bike%20project/DSC00681.jpg
Then I put a wide strip of masking tape down the middle and did three coats of matte black on top:
https://i6.photobucket.com/albums/y205/mowgli0929/bike%20project/DSC00683.jpg
Then 24hrs later took off the making tape to reveal....
https://i6.photobucket.com/albums/y205/mowgli0929/bike%20project/DSC00684.jpg
So..that's the tank, matte black with a white stripe.
Then I moved onto the frame. I took off the fairings on the rear of the bike to get a clear look at it, and that's when it hit me!!! EPITHANY MOMENT! What I'd been trying for AGES with the bandit was to get more clearance between the back wheel and the tail and have a thinner back end, like more modern bikes. I know there were ways to do this...I tried a new undertray etc but couldnt afford some of the more drastic measures. Anyway the 99 bandit tail is horrribly chubby due to the fairings.
I realised when I had the back fairings off how much BETTER it looked with just a steel tube frame and a seat perched on top...almost hovering. Sure...the frame was adorned with lots of horrible metal fixtures etc but I figuered it could all be sorted out.
SO....now I decided that there would be no more fairings at all and all the electronics would have to be relocated.
I took them all off so they were hanging loose and got the angle grinder out (again, just a silly drill attachment one). I'd never done angle grinding before and it was baking hot outside so i was topless...fooolish (had the the old goggles on though )
Cut off all extraneous metal bits on the frame so it was just a couple of bar metal tubes with joining braces, then ground down the wounds i'd inflicted so they were smooth.
I also started to remove the old paint from the frame and grind off the scuff marks from the crash.
https://i6.photobucket.com/albums/y205/mowgli0929/bike%20project/DSC00656.jpg
https://i6.photobucket.com/albums/y205/mowgli0929/bike%20project/DSC00654.jpg
I then wire wheeled (love my drill) and painted the engine matte black. WARNING WARNING WARNING! DO NOT USE HALFORDS OWN BRAND ENGINE PAINT!!!! I used it and recently I had to drain the fuel from the crabs using the drain screws: it STRIPPED ALL THE PAINT OFF! rubbish paint.
anyway...here's the engine painted
https://i6.photobucket.com/albums/y205/mowgli0929/bike%20project/DSC00687.jpg
Since with the new design of the tail I'd decided on the underside of the seat would be in veiw, I decided to paint it. Again, I did 2 primer, 2 white, 3 black. with a stripe identical to the one on the tank. This means that from behind the stripe apears to run all the way down and under the bike.
https://i6.photobucket.com/albums/y205/mowgli0929/bike%20project/DSC00653.jpg
https://i6.photobucket.com/albums/y205/mowgli0929/bike%20project/DSC00685.jpg
I finished sanding down the frame, masked up everthing else so it looked like a christmas present and started painting. The first paint job I wasn't happy with but i'll show you anyway... two primer, three white, two clear.
https://i6.photobucket.com/albums/y205/mowgli0929/bike%20project/DSC00710.jpg
https://i6.photobucket.com/albums/y205/mowgli0929/bike%20project/DSC00711.jpg
I thought there was too much white on the bike now because i wanted it to be mostly matte black with a HINT of white. Also it reminded me too much of a mechano set or something...
So...I messed about with masking tape painted black to see which bits I should paint again (worked brilliantly, much better than just guessing)
Sanded off the clear coat, masked it up again and did three coats of matte black. Also painted exaust, fitted new brake levers, footpegs etc etc
https://i6.photobucket.com/albums/y205/mowgli0929/bike%20project/DSC00719.jpg
Much better!
The handlebars are renthal ultra lows I bought. I really wanted the effect of drop bars so i turned the upside down and reversed them....AMAZING. Feel so much more connected to the road that with the upright old bars I used to have, handles great like this. Dead cheap too. I think its only possible on the bandit because the clamps are so high off the top yoke...ridiculously so in fact.
I really wanted the front end look of a speed triple, but couldnt find any lights in my price range so had to settle for some chrome car headlamps that arnt as big from halfords. I modified the od brackets and the look great!
I then drilled through an inch of steel on the rear footpegs (which killed the brushes in my drill....noooooooooooo!!!) the mounted the rear indicators there which looks dead cool
This is the most recent phot I have so I'll make it the last, you'll have to imagine the rest for now (it's pretty much all done in this pic anyway).
https://i6.photobucket.com/albums/y205/mowgli0929/bike%20project/DSC00723.jpg
WELL happy with the look
I then mounted an old tail light RIGHT UNDER the seat....not at the tail end...under the seat but as close to the tank end as possible. This gives a great clear veiw under the back end and creates an amazing lighting effect at night
Then came the trouble of the electrics and where to put them
They'd all been inside the protection of the tail unit previously so obviously would need some sort of protection. I moved the battery into a tiny space between the frame and the rear suspension, making sure to insulate the points!! Then I gave all the diodes switches solonoids etc etc a good coating of electrical tape and put them in this old petty cash lock box i found lol. Cut some holes in the sides to let the cabled out and screwed it into place on the otherside of the rear suspention to the battery...very neat
So...yeah, that's about it really...sorry it was so long!!! I would welcome any feedback or comments, thanks!
p.s it has been nicknamed 'the badger'
p.p.s I had massive problems with getting it going again...was way beyond my expertise but eventually managed it, only got two cylinders going , recockon it's the diaphams in the carbs?? Its not the coil
| Jenks |
 Jenks World Chat Champion
| mowgli0929 |
 Posted: 19:35 - 19 Aug 2008 Post subject: |
cheers mate,
Had the worst bike trip of my life today! Had to ride back from London to somerset on 2 out of four cyclinders!!!! ohh the shame, overtaken by caravans and cost 30 quid in fuel!!!!! Didnt have the tools there to overhaul the carbs and no RAC callouts left.
Overhauling carbs tomorrow...well scared  |
| virus |
 virus World Chat Champion
| Mudskipper |
 Mudskipper World Chat Champion
 Posted: 19:56 - 19 Aug 2008 Post subject: |
Now that is actually a Blandit I would be proud to ride.  ____________________ CBR125|||GSXR400|||CBR400|||CBR400|||CB250RS|||GSXR750|||CB250RS
"You're clumsy, you eat too much and you behave like a 12 year old boy. But you know what? Every once in a while, you find a thumb." |
| Reppyboyo |
 Reppyboyo Nearly there...
| tutton |
 tutton World Chat Champion
| reu |
 reu Trackday Trickster
 Posted: 20:51 - 19 Aug 2008 Post subject: |
Some good work there mate keep it up  ____________________ 125cc Pitbike <sold> Aprilla Mx50 <current> |
| neatbik |
 neatbik World Chat Champion
 Posted: 21:18 - 19 Aug 2008 Post subject: |
Awesome mate  |
| mowgli0929 |
| chris-red |
| meach |
 meach Scooby Slapper
 Posted: 09:38 - 20 Aug 2008 Post subject: |
Nice
I would paint the rims black too though ____________________ 2005 xt660x in red, not everyone's cup of tea but neither is coffee
https://www.youtube.com/imeach |
| mowgli0929 |
| chris-red |
| alt101uk |
 alt101uk Scooby Slapper
 Posted: 14:59 - 21 Aug 2008 Post subject: |
A lot of hard work there, fine looking bike  |
| The Tot |
 The Tot World Chat Champion
 Posted: 17:13 - 21 Aug 2008 Post subject: |
I was gonna comment on the exhaust earlier but thought i might get slagged cos i have a distinct and renown prejudice for people who find any excuse to use matt black paint on anything!
The minimalistic looks are cool, but my personal preference on the headlight is to move them between the top and bottom yokes so that it gives the bike a more aggressive stance than making it look like Johnny5 or Wall-e.
Exhaust, personally i would have polished it to bits. What was it, titanium?
The way see it is that some company has spent R&D money to develop a flame scorched patina only to have it covered with matt black, but that's cos i'm always partial to shiny bits.
Try polishing out all the scuffs and use autosol to make the downpipes and end can swish... doesn't matter of the rest of the bike is matte, cos my opinion is that exhaust looks ghastly. Still, with no money, it's a good minimalistic style you've put on the bike. ____________________ The Tot 2019 Z1000SX - 2007 R1
Never argue with autism |
| mowgli0929 |
 Posted: 20:46 - 21 Aug 2008 Post subject: |
@ Titz
Very very true about the headlights, they are getting moved tomorrow, I was just lazy and didnt want to make new brackets + it was all very last minute until 2am trying to get it ready for a trip i needed to make the next day. Will get it sorted.
About the exaust...hmmmmmmm, yeah I know what you mean, I was particularly disapointed with the finish of the paint on it. I'm completely undecided as to which way to go. I don't really like chrome on the bike so...dunno.
I've done a (SHOCKINGLY bad) photoshop to compare the two: black and original
https://i6.photobucket.com/albums/y205/mowgli0929/bike%20project/compare.jpg
I didn't like the flame blue on it as I felt it added too many colours and detracted from the look of the bike...a plain chrome one MIGHT make it look better...bit less rat bike. Oh well I can always strip the paint. Anyone got an opinion on the comparison pic?  |
| The Tot |
| Dr. DaveJPS |
 Dr. DaveJPS World Chat Champion
 Posted: 21:26 - 21 Aug 2008 Post subject: |
on an aside personally i hate side numberplates like that, i've always thought a better way would be to mount the numberplate on a mudguard bolted to the swing arm (like the little one on GS1200's). but is just my opinion. nice project thou mate. ____________________ "intelligent inattention is preferable to unintelligent tinkering"
www.davejps.com |
| mowgli0929 |
 Posted: 21:39 - 21 Aug 2008 Post subject: |
Nah..fuck a new one, If I do decide to go back to titanium I'll just strip off the black paint like i did on the tank...can is a scorpion and sounds fucking imense, no way i'd change it
Disagree completely about the numberplate i'm afraid, I don't want ANYTHING blocking the veiw between the seat and the wheel, hence no mudgaurd hugger etc (got a bandit hugger...looks sooooo shit)  |
| Dr. DaveJPS |
| mowgli0929 |
| Type_Mo |
 Type_Mo World Chat Champion
 Posted: 23:59 - 21 Aug 2008 Post subject: |
nice work, but I THINK ya shoulda painted the white bits yellow to match the wheels, and cut a lil bit off the can cos its too big. just enough so the tip of the can is flush with the edge of the tyre. but good work anyways mate  ____________________ - Typhoon ?0 - Yamaha DT125R - Aprilia SR125 - Yamaha DT125R - Honda Hornet 600 - |
| chris-red |
| DaveH |
 DaveH World Chat Champion
 Posted: 11:18 - 22 Aug 2008 Post subject: |
Terrific effort
A very cool looking bike...especially once the front look is sorted
You coudl maybe get some aluminium plate for between the rear subframe spars and hide some of the electrics from view? ____________________ https://www.timhastingsracing.co.uk/
ZX7R & ER6F |
The last post was made 18 years, 22 days ago. Instead of replying here, would creating a new thread be more useful? |
