Clutch problem - snapped screw. Bugger.
DIY, pay for it, or replace
Try and drill it oot in situ - it'll be fine!
0%
 0%  [ 0 ]
Take boss off, then drill it oot
25%
 25%  [ 1 ]
Take boss off, take to a pro to drill it oot
50%
 50%  [ 2 ]
Get a 'new' boss from a scrappy, bin the old one
25%
 25%  [ 1 ]
Total Votes : 4
D O G
PostPosted: 09:40 - 22 Aug 2008    Post subject: Clutch problem - snapped screw. Bugger. Reply with quote
Okay, decided to do the plates on the clutch, and combine it with an oil change etc.
Got everything apart easy enough - cover off to reveal the clutch assembly.
I was greeted by only four screws holding the springs in, and four springs instead of five. Arse. The fifth screw, at some point in th past had been snapped, and left half of itself in the clutch boss post. Most annoying.
Explains why it was slipping. Damn shame I have already bought the plates Brick Wall
Now my problem is getting it fixed. I have never attempted extracting such a screw - it is about 3mm down from the top of the post, perhaps 3-4mm in diameter, and the snapped surface is not smooth. My GF fancies giving it a go, I do not.
I don't have a tap & die set, although I do have a set of drill bits and hand drill which could probably help.
I do, however, think that it would be best to take the clutch boss off the bike to perform any operation, which then made me think the whole piece would be much less painful if I either get a 'new' boss, or take it to someone to have it done. What do you guys think?
andi
PostPosted: 10:30 - 22 Aug 2008    Post subject: Reply with quote
Is the hole blind? With the offending piece removed, would it be possible to access the broken bolt end from behind? This would offer a flatish face for the drill Confused
A machine shop will almost certainly be able to fix but I would have a go myself first. Saying that I have the luxury of access to a machine shop if it goes pear shaped so maybe i am biased Exclamation
Before: Suzuki GT 185. Honda Superdream 250. Yamaha RD350LC. Suziki RG250. Yamaha FZS600. Honda CBR600F3
Now: Honda Fireblade 929
PostPosted: 10:34 - 22 Aug 2008    Post subject: Reply with quote
Personally, given the speed it spins at and the potential mess should that bolt come undone with the engine running I would take the basket off and drill it out very carefully. Not with a hand held drill.
Basket comes off fairly easily.
Ichy
PostPosted: 10:40 - 22 Aug 2008    Post subject: Reply with quote
I agree with KS but would definitely consider taking it to an engineering place to drill out and clean up. I have a set of left hand drills that are perfect for this kind of work, assuming your drill is reversible. This place sells them for £5 a set. The are used but have been reground and are high quality.
https://www.tracytools.com/variousclearance.htm
D O G
PostPosted: 11:01 - 22 Aug 2008    Post subject: Reply with quote
Yeah, I think it will be best if I take it somewhere and have it sorted, since it will be a quick, easy job for somewhere with the correct tools and know- how.
I suck doing things like this - fine control is not my strong point. Likely that it will cost me a lot more (and a lot more time) by trying to do it myself, and very likely that I will destroy the part.
D O G
PostPosted: 06:57 - 23 Aug 2008    Post subject: Reply with quote
Well I had a look at it this morning to see what the crack really was. Poked it with a screwdriver, and it turned freely! 30 seconds of poking with a screwdriver and it was out. Very Happy
So pleased.
Unfortunately the local breakers did not have a set of springs and bolt, so have to wait until Tuesday when the dealer can get them in.
Still, much better than having to deal with a PITA from a stuck bolt.
I really cannot believe whoever did that just left it. Unbelievable.
PostPosted: 07:55 - 23 Aug 2008    Post subject: Reply with quote
The bolts are just normal M6 bolts - nothing special about them. The spring would need to be somewhere close I guess.
PostPosted: 17:40 - 23 Aug 2008    Post subject: Reply with quote
A clutch bolt would almost certainly EZ-out ok. There will be next to no pressure on the threads and certainly no corrosion. It'll have been broken by overtightening it going in.
People snap extractors because they try to use them to extract a seized-in stub. This won't work, it's seized. Snap a bolt putting it in and extractors are very useful. I've used them to great sucess for both rocker cover bolts and sparkplug threads for example.
Gazdaman
I did a trackday!!!
PostPosted: 17:44 - 23 Aug 2008    Post subject: Reply with quote
Always buy new springs! Don't go for breakers springs!
You'll see why when you compare the length of used springs to new ones.
Gaz
The last post was made 17 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.94 - MySQL Queries: 15 - Page Size: 66.23 Kb
