Factors that affect the clutch?
s44678
Guest
PostPosted: 15:26 - 29 Aug 2008    Post subject: Factors that affect the clutch? Reply with quote
'bout 5 years back I had an operation after I fucked up the tendons in left hand. Works ok now, but some repetitive movements can cause discomfort. Unluckily for me, operating the clutch on my bike is one of them.
So I was wondering what factors affect the stiffness of the clutch? Because I reckon if it was smoother, it would put less strain on my hand (index finger to be precise).
The clutch on the bandit is well harsh. Harsher than some other bikes i've felt. Is it the springs inside the clutch doing it or what? Or the design of the lever? Is there such thing as a hydraulic clutch? And any (easy) way to make modifications on a bike to make it easier on the hand?
Thinking about changing my bike soon so i'll definitely look at any suggestions when I get it.
Kal
PostPosted: 15:35 - 29 Aug 2008    Post subject: Reply with quote
Speak to NABd. they should have some ideas for weakening the clutch without damaging it.
Otherwise the first thing that occurs is do away with the clutch all together and fit a kliktronic unit
Kal...
MaybeGuy
PostPosted: 15:38 - 29 Aug 2008    Post subject: Reply with quote
there are hydraulic clutches, a ZXR750 for example, as well as a KTM superduke has them.
you can also get easy-pull levers to take some of the strain off.
you can (but maybe not advised) get weaker clutch springs, and check that the cable is very well lubricated.
Gazdaman
I did a trackday!!!
PostPosted: 15:40 - 29 Aug 2008    Post subject: Reply with quote
Yeah, a well lubed cable will make the most difference. Get lots of 3-in-1 down the cable. Or some teflon stuff if you're posh.
Gaz
Whosthedaddy
PostPosted: 15:56 - 29 Aug 2008    Post subject: Reply with quote
Theres still quite a tension behind the lever and can make the fingers ache if in slow moving traffic, but on the ZXR you can adjust the position of the biting point to suit finger span to elevate most pains.
What about one of those clutch changing thingymebobs that some disabled bikers have that work by a push button to change gears.
MaybeGuy
PostPosted: 16:00 - 29 Aug 2008    Post subject: Reply with quote
yes, but a smaller master cylinder and wider lever movement will make it easier to pull.
s44678
Guest
PostPosted: 16:05 - 29 Aug 2008    Post subject: Reply with quote
Fuck that autochange thing. Then I have to admit ive got a disabled hand!
Will deffo try the lube idea. What I think would help is a similar adjustment that the brake lever has, where you can adjust the span. Becuase its the constant reaching right out and pulling all the way in that fucks it up. If it was closer to the bar (i.e. had a shorter range between in>out) that would make it easier.
Plus ive got small hands which doesnt help. I almost have to get my hand into a hyper-extended (bending fingers back up) position to reach the lever. And its this repeated stretching that causes the problem.
Whosthedaddy
PostPosted: 16:09 - 29 Aug 2008    Post subject: Reply with quote
Electronic quick shifter
https://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MCYCLE&pcode=HPPTQSTSR4001
Kal
PostPosted: 18:20 - 29 Aug 2008    Post subject: Reply with quote
From eBay
from Busters
Kal...
Mr Nice Guy
PostPosted: 18:28 - 29 Aug 2008    Post subject: Reply with quote
Junk the idea of a hydraulic clutch mate ...in my experience of them are basically an SP2 and a ZXR750 (RSV?) ...you get arms like pop eye the sailor after 5 minutes in traffic. MUCH MUCH stiffer than cable jobbies...
Suzuki GSX-R750K4 ~ Mivv GP
PostPosted: 18:51 - 29 Aug 2008    Post subject: Reply with quote
The one on my RSV IMO was rather light actually......
Mr Nice Guy
PostPosted: 18:52 - 29 Aug 2008    Post subject: Reply with quote
That probably ties in with me not remembering if it was hydraulic or not lol
PostPosted: 18:54 - 29 Aug 2008    Post subject: Reply with quote
No, they are hydraulic......it was still rather light IMO, and I have thin girl arms.
Mr Nice Guy
PostPosted: 18:56 - 29 Aug 2008    Post subject: Reply with quote
Read what I said again, I didn't disagree ...
And I don't have thin girl arms Laughing
Clearly just don't w@nk as often as you... plus, I'm a righty
PostPosted: 18:58 - 29 Aug 2008    Post subject: Reply with quote
Ahh, my bad. Doh!
Seb
PostPosted: 19:14 - 29 Aug 2008    Post subject: Reply with quote
The hydraulic clutch on my RST was brutal at first, I did the Plymouth megaride not long after I switched over from the ZZR. Creeping out of Lee Mill was agonising by the time I hit the gates, I don't think I've ever been so pleased to be on the A38 Wink
It's not so bad now I'm used to it, but it still feels way heavier than any other of the (admittedly limited) selection of bikes I've played around with.
2010 Triumph 1050 Sprint ST
The last post was made 17 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 90.97 Kb
