| Gixer Trickster |
 Gixer Trickster L Plate Warrior
| Scooby |
 Scooby Scrappy Doo
| Gixer Trickster |
| Dusty |
 Dusty King of the Rim
 Posted: 20:59 - 30 Mar 2004 Post subject: |
Tbh I'm not sure that fitting 6 pot calipers will nessesarily make your brakes any better. I've ridden bikes with 6 pots that aren't that impressive and bikes with 4 pots that are amazingly good.
Does your gixxer stoppie with the brakes as they are now?
As Scooby said I would look at some braided hoses and maybe Carbon Lorraine pads before you go shelling out for new callipers. ____________________ Gallery |
| MarJay |
 MarJay But it's British!
 Posted: 21:08 - 30 Mar 2004 Post subject: |
Dusty is right there,
The number of pots makes less difference than the actual construction of the caliper. If the caliper is billet (IE made from one bit of metal) then it is less likely to flex under load and will give a more consistent braking performance.
R1 calipers for example are 1 piece units.
Both Busa and Gixxer 600 calipers are 2 piece, but they should still give you amazing stopping power.
Failing braided hoses and new pads, try www.pretech.co.uk or www.billet.co.uk
Plus 6 potters are supposed to have a reputation for making the disks warp, especially if one of the pots is seized.
Bear in mind that with a lot of caliper transplants you will need a new master cylinder too, whereas the aftermarket Harrison or Pretech calipers will be designed for your bike.
The only difficulty you will have with these brakes is strengthening the forks for those stoppies!  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| Gixer Trickster |
| Gixer Trickster |
| Dusty |
| MarJay |
 Posted: 23:19 - 30 Mar 2004 Post subject: |
I wasn't 100% serious about the forks, but its worth checking that their damping is OK, because if its not the improved brakes might cause problems with pogoing.  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| TiN |
 TiN Pocket Tin
 Posted: 15:21 - 31 Mar 2004 Post subject: |
Also bear in mind that you may also need to upgrade the bore/entire master cylinder in order to make full use of the extra pots. In fact, there's a chance that the 6-pots will perform worse unless you do that.
But as has been said - just try braided hoses etc first. ____________________ TiN
dotgems.net |
| MarJay |
| kev |
 kev I Hump Things
| G |
 G The Voice of Reason
| Ste |
 Ste Not Work Safe
| G |
The last post was made 22 years, 155 days ago. Instead of replying here, would creating a new thread be more useful? |
