Change the rear shock spring
Gixer Trickster
PostPosted: 22:47 - 30 Mar 2004    Post subject: Change the rear shock spring Reply with quote
Does anybody know if it is dificult to change the rear suspension spring on a gsxr600(2000)?
The reason i want to do this is purely asthetic, the existing spring is black and has coroded,but is still working pefectly.All i want to do is change it for a yellow one.
Would it affect the suspension depending on what type (make) of spring i used, and would it be worth the taking the time to do it for such a small improvement.
Any help much thanks in advance Very Happy
PostPosted: 23:22 - 30 Mar 2004    Post subject: Reply with quote
Probably not that difficult. Suspect you would need to compress the spring so that it is not pressing on the top and bottom mounts. Hopefully one of those is located with a couple of collets, and with the spring pressure taken off that end they can be removed.
However getting hold of a correct spring might be more difficult. Might be worth just taking it to a suspension specialist.
PostPosted: 23:23 - 30 Mar 2004    Post subject: Reply with quote
My dad used to say to me when I was a lad:
If it aint broke, don't fix it!
In order to remove the spring you will need to dismantle the damper assembly.
This means losing gas pressure in the shock afaik.
Basically its a job for a suspension specialist. Unless you are very brave and have all of the equipment to re charge gas pressure into a monoshock. Smile
PostPosted: 00:07 - 31 Mar 2004    Post subject: Reply with quote
You can probably get an ok shock of ebay, dunno if they're yellow to start with.
You could always paint it, would be a bit fiddly, but probably cheaper in the long run, even if you just paid someone to do it.
The last post was made 22 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 40.51 Kb
