Info needed about van weights.
B_A_B
PostPosted: 06:22 - 03 Sep 2008    Post subject: Info needed about van weights. Reply with quote
I`m trying to figure something out but i dunno the names/models of these vans so it might be a bit tricky to explain....
When you pass your car test you`re allowed to drive vans upto 3500kg without doing the LGV test but what does a 3500kg van look like?Is it like a basic ford transit?..or is it those slightly taller/longer vans that some companies use (like DHL/parcelforce etc).
or...if anyone can give me the names of the usual vans these companies use that`d help a lot.
cheers for any replies
https://www.UK-BODYBUILDING.co.uk
Mal
PostPosted: 06:38 - 03 Sep 2008    Post subject: Reply with quote
You can drive any of the transit size vans and Luton Box Vans (as shown below) on your car licence.
https://www.bramblevanrental.co.uk/images/DSC00461.JPG
If you want to hire one there may be further rules depending on the hire company - must be over 25 and/or have less than 6 points on your licence for example.
Current: 2002 FJR1300, 1999 Thundercat, Previous: 1998 XVS650 Dragstar
"In the end we're all just chalk lines on the concrete - drawn, only to be washed away."
Bendy
Mrs Sensible
PostPosted: 07:44 - 03 Sep 2008    Post subject: Re: Info needed about van weights. Reply with quote
Not quite that simple - a lot of vans come in several weights for the same size, eg Iveco and their old 35/12 which had a very similar looking version rated to a much higher weight (5200 I think) and the only real clue was that the arse sat a bit higher when it was empty.
It's perfectly possible to find a big longwheelbase van that's 3500kg. Just be aware of the above and check which model you need. A few mins on Google should explain the model names and weights for any particular kind of van you fancy.
Parcelforce seem to have Ivecos and Sprinters (from what I've noticed), VW LT range can get quite big, or there are some pretty hefty Transits out there if you don't need something quite so large - look for hitop and long wheelbase versions.
Pedd
PostPosted: 07:55 - 03 Sep 2008    Post subject: Reply with quote
If you passed your test before the new laws came in then you can drive upto 7.5ton vehicles on your car licence Smile
thegubner
PostPosted: 08:13 - 03 Sep 2008    Post subject: Reply with quote
The thing about any size transit etc is not quite true.
If you look on the weight plate of some vehicles especially some twin wheelers they are just over 3500 k. A mate of mine was showing me his the other day and its 3512 k.
Granted its only 12 kilo but if you are fully loaded then you are overweight and technically not insured.
Never mind what people say you always need to check yourself, after all its your licence.
HTH
WildGoose
White Van Man
PostPosted: 20:01 - 03 Sep 2008    Post subject: Reply with quote
A rule of thumb, naturally there are exceptions..
Any van with only single wheels on the back axle, its a fair assumption to make to assume that its 3500kgs gross weight or less, in my experience.
Unfortunately, its often only panel vans that have single rear wheels on the back, lutons and tippers often (but not always) have the twin rear wheels, in these cases... just check the plate inside the door for the gross vehicle weight, as mentioned.
You cannot drive anything with a plated gross over that which your licence entitles, regardless of what it is carrying. In the same way that weight limit signs are applicable to the gross weight and not the actual weight carried at the time.
I'm being pedantic here, but the above turn of phrase used by so many irritates slightly, as it is misleading. It is nothing to do with your "car" licence.
Technically they stopped giving you the C1 licence category with a car test pass after '97. Apart from that nothing has changed.
I.e. if your licence has a C1 category you can drive up to 7.5t. If it doesn't, and you only have B, then you are limited to 3.5t. It is as simple as that.
B_A_B
PostPosted: 21:35 - 03 Sep 2008    Post subject: Reply with quote
cheers fellas....appreciate the info. Wink
Cigaro
PostPosted: 21:49 - 03 Sep 2008    Post subject: Reply with quote
I had an LWB transit once that was 2.9 tons and could drive it on my license.
It was like the one in the attached photo.
Not sure about those Lutons, think they weigh in at 7.5 so if you passed your test after a certain date you can't drive them.
PostPosted: 22:09 - 03 Sep 2008    Post subject: Reply with quote
As above; they can easily be 3.5t; the majority of that sized lutons are 3.5t, I'd say.
Phoenix
Twisted Firestarter
PostPosted: 03:05 - 04 Sep 2008    Post subject: Reply with quote
Lutons (box body with tail lift) are often 3.5t, the best general rule as Goose says is if it has a double rear axle then it's probably over 3.5t and this applies to lutons and LWB vans, though it's not always true. Reality (Argos deliveries) for example use Iveco Daily's (normally 3.5t) with a large double rear axle, these are rated at 6.5ton.
The other clue is if it has a tachograph fitted, it's over 3.5ton, any vehicle used by a business over 3.5ton must by law have one.
B_A_B
PostPosted: 05:33 - 04 Sep 2008    Post subject: Reply with quote
On the subject of tachographs...
I applied for the drivers card last week thinking it`d improve my chances a bit more....but after reading what you`ve just said i guess i`ve wasted my money.
Are they not used by ALL drivers...regardless of van size/weight?
thegubner
PostPosted: 07:33 - 04 Sep 2008    Post subject: Reply with quote
Which is very true, but if you get stopped and weighed by the ministry unless they are a complete c*nt they should let you go on your way if you are under 3 and half .
Finding one that is not a complete c*nt however could be very tricky indeed.
AJI
PostPosted: 11:48 - 04 Sep 2008    Post subject: Reply with quote
I've been looking at vans recently for a trip I intend to do in the next few years, and obviously I've been looking at the 3.5 ton gross limit too as I don't have a licence for anything bigger.
In my experience searching, you're fine with pretty much any panel van (including long wheelbase high roof vans - my mate drives a 3.5t Transit in that format), smaller single and double-cab tippers, and minibuses under 9 seats.
TARMAC - Automotive blog *UPDATED 26/3/09 - Abandoned fuel stations to go electric? ~ Buy my eBay stuff!
You're gonna go far, kid
Phoenix
Twisted Firestarter
PostPosted: 02:24 - 05 Sep 2008    Post subject: Reply with quote
Yes B_A_B, unless you are applying for 7.5ton or LGV work then you won't be using a tachograph, there were plans to introduce tachos for 3.5t a couple of years ago but it vapourised. Also only newer vehicles after 2006 are equipped with digital cards, most still use older analogue charts which you don't need a digital card for, it's worth having though now you've got it if you plan to move onto 7.5t/LGV.
B_A_B
PostPosted: 08:44 - 05 Sep 2008    Post subject: Reply with quote
cheers for the info Wink
The last post was made 17 years, 289 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 88.83 Kb
