cush drive rubbers
rockers
PostPosted: 17:43 - 05 Sep 2008    Post subject: cush drive rubbers Reply with quote
Hi there chaps i brought some new cush drive rubbers for my rear wheel as old ones are shagged.
Now bikes on pit stand wheels out studs jsut fell out easy enuff, but how on earth do you get the cush drive rubbers out ? i cant see how to do it at all.
Anyone any ideas, or how is it done ?
thanks
Rocky
baldy
PostPosted: 17:49 - 05 Sep 2008    Post subject: Reply with quote
The rubber bits are cush drive rubbers, they are meant to let the sprocket move a bit.
One day i will rule the world, just not today.
rockers
PostPosted: 18:10 - 08 Nov 2008    Post subject: Reply with quote
topic changed
Villers
PostPosted: 18:15 - 08 Nov 2008    Post subject: Reply with quote
Not a personal attack but surely you have BOUGHT some, not brought???
Anyway, on my previous bike they have all been easy to remove, unless Im missing something its just a case of removing the rear wheel, pulling the sprocket off and then they rubbers can just be yanked out.
If its any more difficult post a picture of it!
rockers
PostPosted: 18:33 - 08 Nov 2008    Post subject: Reply with quote
Sorry im not perfect with my English.
If you rubbers looked the smae they they look like bearings but the middle bit is rubber like a metal bit on the inside and outside of the rubber.
there flush to the hub itself so unsure how to remove them, have sprayed with wd40 and giving it some time to sink in.what did you use to yank them out ?
The camera is on charge so will get a pic up
sickpup
Old Timer
PostPosted: 19:21 - 08 Nov 2008    Post subject: My crystal ball is in for a service so... Reply with quote
A picture and telling us the bike would help.
andi
PostPosted: 20:58 - 08 Nov 2008    Post subject: Reply with quote
They Should kinda look like this:
https://i16.photobucket.com/albums/b24/andipicture/cush_drive.jpg
and fit something like this:
https://i16.photobucket.com/albums/b24/andipicture/cush_drive_rubbers_mounted.jpg
Before: Suzuki GT 185. Honda Superdream 250. Yamaha RD350LC. Suziki RG250. Yamaha FZS600. Honda CBR600F3
Now: Honda Fireblade 929
sickpup
Old Timer
PostPosted: 21:20 - 08 Nov 2008    Post subject: Reply with quote
Only some look like that.
rockers
PostPosted: 21:45 - 08 Nov 2008    Post subject: Reply with quote
They do not look like that at all, like i said they look like bearings theres metal around the outside and on the inside.
I cant get my camera work... Twisted Evil
They look like this https://img266.imageshack.us/img266/3373/bearingfd5.jpg
Finglonga
PostPosted: 21:58 - 08 Nov 2008    Post subject: Reply with quote
That looks like the bearing to me, can't get the link to the larger image to work either.
What bike would help also.
Andy Sez....
F.Y.Y.F.F.
rockers
PostPosted: 22:04 - 08 Nov 2008    Post subject: Reply with quote
Its a kymco styker 125
There not bearings, what i have got new are the same as what are in there at the moment.
Will try soem heat on them tomrrow unless anyone has any ideas ? Rolling Eyes
PostPosted: 22:44 - 08 Nov 2008    Post subject: Reply with quote
Some bikes have them round bushes as cush-drive rubbers. If they have been pressed into a blind hole you can force them out with some grease & a drift. You pack the space behind out with grease & then use a good-fitting drift that slides nicely in the centre-hole of the bush. Give the drift a good smack and the grease force the bush out of it's seat.. If the rubber is wrecked you have no chice really but to use a small cold chisel to break the outer shell to remove it.
rockers
PostPosted: 22:49 - 08 Nov 2008    Post subject: Reply with quote
Geri thanks, but what is a drift ? do you mean drill drift ? or just like a dowel that fits good in the center hole ?
Thanks
Rocky
PostPosted: 22:53 - 08 Nov 2008    Post subject: Reply with quote
Yeah that's it, a good fitting rod of some description, it has to be a good fit thoguh - usually a cut-off shouldered bolt will work for what you are doing.
A drift is just a sacrificial lump of something for hitting with a hammer so as not to damage a useful part.
sickpup
Old Timer
PostPosted: 22:58 - 08 Nov 2008    Post subject: Reply with quote
iirc they are called Metallastic bushes. Common on Brembo wheels and a fair few old small Honda's.
On Honda's they just slide into place and then the sprocket would have a large circlip holding it in place but on Ducati's with th Brembo wheels they were bonded into the wheel.
As Geri said you could drift them in but if they are a tight fit I would guess they need to be pressed into place or bonded.
rockers
PostPosted: 23:00 - 08 Nov 2008    Post subject: Reply with quote
Ah awsome will give it a go tomorrow, if all fails will use the chisel and try and colaspse the side inwards.
Thanks for the help
Rocky
PostPosted: 23:03 - 08 Nov 2008    Post subject: Reply with quote
Take care not to bend the brake disc if you are working with the wheel flat on the floor - it's easier to do than you think. I sit the wheel in an old rear tyre for stuff like this.
rockers
PostPosted: 23:16 - 08 Nov 2008    Post subject: Reply with quote
Bend the disc..... sadely my bike isnt that hi tech :p front disc rear i have a drum brake Sad
PostPosted: 07:13 - 09 Nov 2008    Post subject: Reply with quote
Oops - oh well, still worth saying Smile
The last post was made 17 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.09 - MySQL Queries: 13 - Page Size: 97.64 Kb
