The most fooked engine I have ever seen. 56K No way!
Fisty
PostPosted: 14:41 - 06 Sep 2008    Post subject: The most fooked engine I have ever seen. 56K No way! Reply with quote
A lady my dad worked with had her MG TF from new, never had it serviced from the day it was bought. These are the results.
https://i302.photobucket.com/albums/nn82/mr_fisty/DSC00314.jpg
Every valve bent or missing
https://i302.photobucket.com/albums/nn82/mr_fisty/DSC00315.jpg
Every piston disintigrated, there is a huge hole in the block too.
https://i302.photobucket.com/albums/nn82/mr_fisty/DSC00316.jpg
Cambelt went causing a large scale piston/valve/everything interface.
All because she was too tight to get it serviced.[/img][img][/img]
Fatter and faster than Fret
Tristan.
PostPosted: 14:42 - 06 Sep 2008    Post subject: Re: The most fooked engine I have ever seen. Reply with quote
How old was the car?
Fisty
PostPosted: 14:46 - 06 Sep 2008    Post subject: Reply with quote
Cheers tristan, realised what id done when i pressed submit. Delete your if you would, will make things a wee bit smaller on here xxx
Moonie
PostPosted: 14:48 - 06 Sep 2008    Post subject: Reply with quote
Jeeeesus.
Well that didn't pay off lol.
Fisty
PostPosted: 14:51 - 06 Sep 2008    Post subject: Reply with quote
Moonie wrote:
Jeeeesus.
Your telling me, 53 plate car with 38,000 miles and the bill is going to be around the 3K mark. Thats if a new engine can be found. She wont have a second hand one! tart.
Phoenix
Twisted Firestarter
PostPosted: 14:52 - 06 Sep 2008    Post subject: Reply with quote
Nice, still not servicing it didn't really kill it, just the not replacing the cambelt, if she'd done that it probably would've lasted another 80,000 or whatever it'd done. Though oil changes would help too, surely she did at least one, otherwise I would think she'd have run out of oil eventually as it got thinnner and burnt or leaked out.
Drew This post is not being displayed because the poster is banned. Unhide this post / all posts.
Fisty
PostPosted: 15:47 - 06 Sep 2008    Post subject: Reply with quote
A cambelt check/change is part of the service schedule. Also having it serviced regularly may have seen the frayed cambelt get noticed.
PostPosted: 16:38 - 06 Sep 2008    Post subject: Reply with quote
Could've been worse. That's at least five services she hasn't paid for at what? £350 each? More for a big one. Another couple of years or being prepared to fit a reconditioned engine and she'd be quids in. Unlucky it went when it did.
Mind you, did the belt wear or did a crappy plastic pulley do the usual Rover trick and fly apart, destroying the belt in the blink of an eye? In which case she was entirely justified because no amount of servicing would have prevented it.
Still a cool photo though. Did anything make an appearance out of the bottom of the engine too?
Mate of mine had some sort of Alpha Romeo. Due a cambelt change at 40k. For some reason this meant splitting the engine at the cost of around £2000. Another mate (a car mechanic) told him it didn't cost much more to rebuild the engine after the cambelt fails and to just drive it until it snapped.
Snapped at 80k when he'd have just been fitting his second one. Cost £2500 to sort.
Phoenix
Twisted Firestarter
PostPosted: 16:45 - 06 Sep 2008    Post subject: Reply with quote
Got to wonder what engine designer in their right mind would design an engine so that you have to remove it and split it in half to change the cambelt every 40,000miles. And an Afla Romeo is hardly a Lamborghini where one might spend £250,000 on buying it and be happy at £2000 a service. Why didn't they just fit a bloody chain and lose 3hp.
Graham88
PostPosted: 17:02 - 06 Sep 2008    Post subject: Reply with quote
Blimey, that's impressive.
This is my old Corsa engine! When it went it was very boring, simply cut out, I was hoping to have rods through the blocks and all sorts!
https://i18.photobucket.com/albums/b112/GrahamVFR/Corsa/Engine%20Failure/IMG_3197.jpg
https://i18.photobucket.com/albums/b112/GrahamVFR/Corsa/Engine%20Failure/IMG_3217.jpg
https://i18.photobucket.com/albums/b112/GrahamVFR/Corsa/Engine%20Failure/IMG_3239.jpg
https://i18.photobucket.com/albums/b112/GrahamVFR/Corsa/Engine%20Failure/IMG_3249.jpg
Frost
PostPosted: 17:57 - 06 Sep 2008    Post subject: Reply with quote
A squirt with some WD40 and a quick wipe with a rag and it'll be fine.
Tonka
PostPosted: 20:06 - 06 Sep 2008    Post subject: Reply with quote
I'm not clever with which cars are which, but doesn't the MG TF have the infamous 1.8 Rover engine?
I had 3 replacement engines in a Coupe (company car thank goodness) and then managed just the headgasket replacement on the Freelander, as Landrover acknowledge the fault and replace straight away.
In my experience if you're gonna drive a Rover / Landrover regular maintenance is essential....along with a healthy wallet! Rolling Eyes
The last post was made 17 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 79.79 Kb
