php help anyone
craigie b
Citizen Smith
PostPosted: 14:22 - 12 Sep 2008    Post subject: php help anyone Reply with quote
Hi guys....I am trying to edit the following code:
if ($wrapable=="1")
$cost=getCost($requestedQuantity,$serviceid);
$quantityAvailable=getWrapableSlotsAvailable($serviceid);
$output=makewrapablequantityoutput($defaultQuantity,$quantityAvailable,$serviceid);
else
$datacheck=validateinputdata($request,$serviceid);
if ($checked && $datacheck) {
$validDates=getServiceAvailabilityDates($serviceid);
$output=makedateoutput($serviceid,$validDates);
$output.=makeExtras($serviceid,$property_uid);
break;
Now the line "$output=makedateoutput($serviceid,$validDates);" creates a drop down menu and populates it with dates.
The line "$output.=makeExtras($serviceid,$property_uid);" creates a list of check box options, called optional extras in the pic attached.
Now all I want to do is have the optional extras appear above the date box instead of below. However when I move the "$output.=makeExtras($serviceid,$property_uid);" line above the command to create the date box, the extras simple do not appear. Can anyone help? Lots of good Karma to anyone who can help. Thumbs Up
craigie b
Citizen Smith
PostPosted: 14:23 - 12 Sep 2008    Post subject: Re: php help anyone Reply with quote
if ($wrapable=="1")
else
break;
Dom
PostPosted: 14:59 - 12 Sep 2008    Post subject: Reply with quote
Without seeing the PHP functions or the markup produced it's difficult to say, but I'm guessing it's a HTML problem.
My guess is you've got fields being generated within fields, or something like that, and the browser doesn't know what to do. Tried running the page through https://validator.w3.org/?
Sod that, I think the problem is that you've probably missed the '.' before the equals, which means the variable is overwritten rather than added to. F'rinstance you have '$output=makedateoutput($serviceid,$validDates);' which would overwrite any variable already called $output that is created earlier in the script (which presumably it would be if you move it up).
Add some tabs and spacing and your life would be much easier. Wink
Photos and that
Dom
PostPosted: 15:07 - 12 Sep 2008    Post subject: Reply with quote
LukeVFR wrote:
Code:
<?php
   $variable = "test";
   $variable .= "ing";
   echo $variable;
That would output "testing"
You need to call the second variable declaration something else if you want to use it above the original variable declaration.
No he doesn't, he just needs to move the dot accordingly. Razz
Photos and that
craigie b
Citizen Smith
PostPosted: 15:17 - 12 Sep 2008    Post subject: Reply with quote
lol, I should point out I am modifying a plugin written by someone else and I have no idea how to code php....I've been pretty much working blind.
Can you explain a little bit clearer...whats the dot for?
craigie b
Citizen Smith
PostPosted: 15:26 - 12 Sep 2008    Post subject: Reply with quote
Happy days I am making progress Thumbs Up Next thing....The date now appears on the same line....How do I move the date box to a new line? Karma Karma Karma
craigie b
Citizen Smith
PostPosted: 15:51 - 12 Sep 2008    Post subject: Reply with quote
if ($wrapable=="1")
else
$output=makeExtras($serviceid,$property_uid);
$output .=makedateoutput($serviceid,$validDates);
break;
I basically switched the makeExtras with the makedateoutput...I have no idea if this will have a knock on effect!
craigie b
Citizen Smith
PostPosted: 17:17 - 13 Sep 2008    Post subject: Reply with quote
Ah...I have discovered what happens when I switch the variables....the date function now only appears if there is extras attached to it so my bodge didn't work Laughing
So what I need to do is set a new variable to show the extras....how do I define a new variable? (if that is what I need to do)
craigie b
Citizen Smith
PostPosted: 23:11 - 14 Sep 2008    Post subject: Reply with quote
I can't thank you guys enough.....It took a further 6 hours of mulling over (and a previous 8 to find the fecking code in the first place) to final find a solution...... Most usefull was the tip about moving the dot. Once I sat down and thought about it overwritting the previous variable I did the following:-
$output=makeExtras($serviceid,$property_uid). "<br>";
break;
A tiny change but I would have never have solved it without your help. Big big thanks to you all Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up
The last post was made 18 years, 2 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 67.48 Kb
