Overclocking
Chills
PostPosted: 11:12 - 04 Apr 2004    Post subject: Overclocking Reply with quote
Just looking for a quick bit of advice...
I've got a P4 2.4 chip which has been running at 3.0 for months now. With my Vapochill case the cooling temp never goes above -15oC nor the CPU temp above 11oC...
Is the CPU temp the only real concern?
I mean can I just keep upping the speed as long as the CPU temp doesn't go too high? And what's too high?
Cheers for any advice. Smile
ZaphodBeeble
PostPosted: 11:45 - 04 Apr 2004    Post subject: Reply with quote
The thing is, if you increase the speed of the CPU you have to increase the voltage too. There is a limit to how much your motherboard can increase the voltage and you don't want to blow your chip if it can increase it too much.
Also, some motherboard voltages aren't as smooth as others and you won't be able to overclock as much as a board with smoother voltages.
It isn't just a matter of how cool you can keep the chip, it's how much of a voltage increase it can handle.
If I was you (and if your motherboard will do it) I'd increase the FSB (Front Side Bus) in 1MHz increments until the computer freezes up, then put it back down a couple of MHz to ensure stability.
I'd say that 40 degrees C is a suitable temperature but with that cooling system that you have that would mean that you have overclocked A LOT and I wouldn't like to risk it.
Just be careful. Thumbs Up Smile
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
Chills
PostPosted: 11:52 - 04 Apr 2004    Post subject: Reply with quote
Cheers.. will check that FSB thingy in a mo...
My board is the Abit IC7-G and it SEEMS to be coping, at least so far...
I've taken a screenshot of the voltages/temps... Does this all seem OK to you?
Hex
Party Boy
PostPosted: 15:47 - 04 Apr 2004    Post subject: Reply with quote
I think you'll find your CPU is actually about 39 not 11, 11 degrees is really cold for a cpu.
The voltages etc look fine to me.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
Chills
PostPosted: 16:12 - 04 Apr 2004    Post subject: Reply with quote
Cheers.. I see what you mean about the 39/11...
Guess I must've reversed the sensor plugs somewhere. Embarassed
Think I'll stay at 3.0GHz then. No probs playing any games anyway (yet)...
Even the Doom3 beta2 plays ok so shouldn't need an upgrade for a few months. Smile
hush
PostPosted: 23:19 - 04 Apr 2004    Post subject: Reply with quote
If your VapoChill case is a cryocooled - then the -15 case, 11 CPU is entirely possible. The performance of your computer is effected a lot by the ambient case temperature. The cooler the processer the better it works. 35-40 is a good operating temp for a P4, but they can run at 60 fine, and will not be too bothered by a 90 degree C burst either (Athlons on the other hand self destruct at those temps). But there are other components inside the computer effected by temperature.
The warmer the case, the slower everything works. but if your readings are right, you have nothing to worry about temperature wise. But as ZaphodBeeble said, 1MHz steps. Also, bear in mind that if you are adjusting your system performance, keep an eye on your memory as well, ensure that you are not getting any data errors from memory at the enhanced performance.
The last post was made 22 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 49.98 Kb
