| 5v3d3b0 |
 5v3d3b0 World Chat Champion
| Hutchysrs50 |
 Hutchysrs50 World Chat Champion
| 5v3d3b0 |
| Hutchysrs50 |
| 5v3d3b0 |
| Hutchysrs50 |
| Hutchysrs50 |
| 5v3d3b0 |
| Hutchysrs50 |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
 Posted: 20:59 - 16 Sep 2008 Post subject: |
Idle circuit is too lean.
https://i67.photobucket.com/albums/h294/supercitybity/Cagiva/DSC04295.jpg
Screw at bottom right near oil feed on the PHBH28. Turn it out half a turn and give it a go. If it feels worse, turn it back to how it was and screw it in a half turn (whole turn from where you were).
The RS carb might be slightly different to the cagiva one. . . ____________________ "because one stroke isnt enough and four strokes waste two" |
| Hutchysrs50 |
| 5v3d3b0 |
 Posted: 17:00 - 18 Sep 2008 Post subject: |
Doesn't really seem to solve the problem which ever way I go...
Was slightly better half a turn out, but still choked when giving it gas when stationary. When I did more turning out it got worse, and turning in was even worse |
| stirlinggaz |
 stirlinggaz World Chat Champion
 Posted: 17:19 - 18 Sep 2008 Post subject: |
hi,
doesnt sound like an air leak.
sounds more like your carb isnt set up properly.
done any modifications to it recently? exhaust/pv, air filter?
changed the main jet?
read kickstarts guide to the dellorto carb on here, it will give you an idea of how it all works.(excellent introduction to carbs, many thanks Keith)
then take the carb off, give it a good clean & set it up properly, idle adjusted,correct size of main jet,needle at correct height, mixture screw at stock settings- 2 & 1/2 turns out iirc)
& doing a couple of plug chops till you get it running as good as you can.
cheers,
GAZ
ps - let us know what exhaust,airfilter & other mods you have & what size of main jet is in there now. |
| 5v3d3b0 |
| 5v3d3b0 |
The last post was made 18 years, 31 days ago. Instead of replying here, would creating a new thread be more useful? |
