bike edging forward with clutch in
texas peat
PostPosted: 16:58 - 19 Sep 2008    Post subject: bike edging forward with clutch in Reply with quote
im having trouble adjusting my clutch on my rs 125. when i adjust it the way it says in the manual it creeps forward and sometimes stalls when i put it in first with the clutch in. any other adjustment i make to the cable and it wont even go into first. ive tried adjusting it at both ends. what am i doing wrong???
rotax81
PostPosted: 17:01 - 19 Sep 2008    Post subject: Reply with quote
the lever coming out of the clutch cover has to be close to 90 degrees to the cable. then tighten the cable until you have about 5mm of play at the lever.
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
texas peat
PostPosted: 17:07 - 19 Sep 2008    Post subject: Reply with quote
how do you adjust the lever to 90 degrees?? in the manual it says screw the adjuster screw all the way in then turn it back half a turn..thats what ive done but it keeps biting in gear with the clutch in.
Hutchysrs50
PostPosted: 18:48 - 19 Sep 2008    Post subject: Reply with quote
did this problem just pop up?
or have you changed somthing or had the engine stripped?
Gilera SC 125 - Current
rotax81
PostPosted: 19:59 - 19 Sep 2008    Post subject: Reply with quote
do it as you did with the screw but make sure the cable is VERY slack.
then tighten the cable at either end (it doent matter which) until it starts to move the lever at the case (not the handle bar lever). back it off a bit to give it some slack and all should work as normal.
failing that you either have the wrong oil in the gearbox (too thick) old oil thats well past it or you have warped your clutch plates through over abuse or lack of oil.
The last post was made 18 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 44.28 Kb
