is it the battery or the charging system?
dci19
PostPosted: 15:47 - 20 Sep 2008    Post subject: is it the battery or the charging system? Reply with quote
I have an 04 cbf 500, it runs fine, doesn't stall. the only running problem is half to full throttle, in this range the bike is lumpy/misfiring, so riding under 6k revs under half throttle, rides fine but bad on petrol, getting about 150miles to the tank, before the problem i was getting around 220-250 depending on how i ride it.
that said, the battery seems to be losing power, press the starter button and the engine cranks slowly, doesn't catch, let go of the starter and then try again, again cranks slowly then nothing, headlight dims. let go and try again, engine cranks then fires up. there was no clicking noise from the selenoid. the head light is dim on tick over, as i rev the bike,the light brightens and as the revs go higher the light dims again.
i have charged the battery up, can take between 20mins to an hour to charge, i have an halfords charger which has a bike setting on it. after charging the battery, the bike starts straight away and loses it charge over five days of using the bike.
i use the bike mon - fri 46 mile round trip and i use it all year round, the bike is left outside covered with a argos motorbike cover.
i have just tested the battery with a multi meter. 12.8v stood, started the bike and the volts dropped to about 7v, then rose to about 8-9v. at 2k revs 14.4, 5k revs the reading was eratic, 5v -10v.
So is this the battery or the charging system, is this the correct way to test the battery and the charging system?
at a loose end tia
mike
PostPosted: 16:30 - 20 Sep 2008    Post subject: Reply with quote
Charging system is buggered. Not sure what part, maybe the regulator/rectifier.
st3v3
PostPosted: 17:17 - 20 Sep 2008    Post subject: Reply with quote
Replace the battery and if the issue persists then replace the entire charging circuit in reg/rec as chives said.
My bike has the same symptoms but I haven't got round to replacing the battery yet. If I use it without the battery then it still happens so the battery is the most obvious fault.
FerretFing
PostPosted: 19:07 - 20 Sep 2008    Post subject: Reply with quote
usually anything below 9.5v across the battery terminals when you press the starter means bad battery - you could always take it off the bike & get a bike shop to test it under load - usually for free but make sure it`s fully charged Thumbs Up
dci19
PostPosted: 19:08 - 20 Sep 2008    Post subject: which one? Reply with quote
i dont want to sound ungrateful, but which should i replace? if money wasnt an issue, i would take my bike to a honda dealer.
is there another way of checking the charging side?
would this fault explain bad mpg's?
dci19
PostPosted: 19:13 - 20 Sep 2008    Post subject: battery test Reply with quote
i will get the battery tested first, then go from there.
i will let u know how i get on
FerretFing
PostPosted: 19:20 - 20 Sep 2008    Post subject: Reply with quote
Yep, battery first as we know it`s bad from the voltage on startup (7v) - of course, something could be causing the battery to go bad. You could get yourself a Haynes manual & go through the charging system tests - that`s what I`d do after replacing the battery Thumbs Up
Finglonga
PostPosted: 19:27 - 20 Sep 2008    Post subject: Reply with quote
Why replace the battery without testing the circuit with a meter?
Beg, borrow or buy a meter and test the circuit, saves second guessing and wasting money.
Andy Sez....
F.Y.Y.F.F.
dci19
PostPosted: 20:04 - 20 Sep 2008    Post subject: Reply with quote
so how do i test the cicuits? i have a multi metre
st3v3
PostPosted: 20:54 - 20 Sep 2008    Post subject: Reply with quote
Top dollar bet it's the battery. Mine does it, which is also a Honda incidentally. Testing is fine if poss.
PostPosted: 20:58 - 20 Sep 2008    Post subject: Reply with quote
If it was the battery surely this would not cause the lights to dim when the engine is revved.
dci19
PostPosted: 13:38 - 21 Sep 2008    Post subject: battery test Reply with quote
the battery is ok, just had it checked out at motor world. I put it back on the bike and put the multi meter on it. not started 12.9v, starting 9.7v, 2k revs 14.8v and 5krevs 13.9v?????????
i wonder if the starting motor is on the way out or am i grasping at straws?
is there anything else that could be causing the problem
tia
mike
ratboy
PostPosted: 19:27 - 21 Sep 2008    Post subject: Reply with quote
you should have a steady increase of voltage as you rev up but as this isnt the case i would suggest that your reg/rec is playing up. higher revs would cause the alternator to create more AC voltage,but if a diode deteriorates in the reg rec it would begin to let through the AC when it has sufficient power. this could be enough to reduce your voltage and damage the battery!
(this is a bit of reasoning on my part and may not be totally correct!)
starter motor shouldnt affect the voltage at 5k revs so shouldnt be that.
tom
dci19
PostPosted: 14:07 - 23 Sep 2008    Post subject: reg/rec Reply with quote
just let you know i am getting a new regulator on friday and i willlet you know how i get on.
thanks for all your replies
mike
finpos
PostPosted: 16:04 - 23 Sep 2008    Post subject: Reply with quote
The drop from 14.8V to 13.9 Volts is probably because the regulator has reached it's threshold value and has started dumping current to protect the battery. As long as those figures are consistent (you said it was fluctuating earlier) then the regulator sounds ok.
This is where you find out it's impossible to diagnose charging system faults unless you are 100% certain that the battery is in perfect working order Smile
f.
dci19
PostPosted: 19:24 - 25 Oct 2008    Post subject: New Battery Reply with quote
Sorry for the long wait.
I didnt want to jinx my new battery
I decided to replace the battery as the old one could of been the original, 4years old and is cheaper than a rectifier plus winters here!
I got a gel battery for £38 and my bike starts first time every time.
Thanks to every one who replied
Mike
Finglonga
PostPosted: 13:49 - 26 Oct 2008    Post subject: Reply with quote
Have you checked the voltages since fitting the new battery to make sure your not going to fry it?
Andy Sez....
F.Y.Y.F.F.
dci19
PostPosted: 19:33 - 01 Nov 2008    Post subject: new battery Reply with quote
It never crossed my mind to check the voltage of the new battery.
To be honest its been a good few weeks now and all is fine, when I start the bike, the engine turns a lot faster and catches within 2 secs.
What I have noticed with the new battery is that on tick over the head light dims and when I rev the engine the light gets brighter.
But saying that my car does the same.
thanks
Mike
prawny1
PostPosted: 20:22 - 01 Nov 2008    Post subject: Reply with quote
Have you checked that your choke isn't stuck on?(could be due to a kinked, frayed or siezed cable)
running a bike on choke past warm up will cause it to misfire at higher revs and hammer your fuel economy.
Not an electrical problem i know but still a possibility. Thumbs Up Thumbs Up
Finglonga
PostPosted: 20:38 - 01 Nov 2008    Post subject: Re: new battery Reply with quote
Never had a bike or car (except my old 6v bike) that dims its lights on tick over. I would still say there maybe a problem with your charging system . . . . maybe worth checking your car as well. Wink
Andy Sez....
F.Y.Y.F.F.
thanks
Mike
Sounds like it's all sorted now Thumbs Up
The headlights will be dimmer at tick over and then get brighter as you rev the engine. All my bikes have done this.
The last post was made 18 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 110.66 Kb
