Indicators on Yamaha RX100S - poorly
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 01:46 - 07 Apr 2004    Post subject: Reply with quote
Not sure if the RXS is 6v or 12v. However firstly make sure the battery has plenty of charge, and check them with the engine running.
After that check the bulbs are correct (especially if the electrics are 6v, as someone might have fitted a 12v bulb). Also check the relay.
ZaphodBeeble
PostPosted: 06:05 - 07 Apr 2004    Post subject: Reply with quote
Another thing to do is rev the engine slightly with the indicators on as these bikes don't have a very powerful alternator. You may need that extra bit of charge to get the relay working properly. Honda CG's are the same if the battery isn't fully charged. Thumbs Up
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
PostPosted: 14:38 - 07 Apr 2004    Post subject: Reply with quote
Not sure on the RXS, but do the rear indicators earth through the rear mudguard or something like that? Try the indicators and try running an extra earth wire back to them.
However the problem could still well be the wrong size of indicator bulbs.
cliff
Doctor Sicknote
PostPosted: 15:07 - 07 Apr 2004    Post subject: Reply with quote
I am almost certain the 100 is 6v. Mr. Green Thumbs Up
Sweet reggae music.
PostPosted: 22:39 - 07 Apr 2004    Post subject: Reply with quote
There should be 2 wires to each indicator. One will feed them power, the other will go to earth (eventually). Use a multimeter and find which one is earth, then run an extra wire from that to the earth terminal of the battery (make certain you get the right wire and terminal as otherwise sparks will ensure.
The last post was made 22 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 67.33 Kb
