| NSR125-Kid-UK |
 NSR125-Kid-UK Attention Whore
 Posted: 04:20 - 07 Apr 2004 Post subject: Almost ended up pushing the NSR home |
Well after finishing late, I went on a little early morning razz on the NSR. I was happily settled into it, and had been riding for about 30 minutes, when all of a sudden I hear a loud (even with earplugs in) pop from under the tank, and the normally quiet buzzing of the NSR got much louder. At the same time, I lost all throttle response and the revs/speed started dying. I coasted over to the side of the road under a streetlamp. Helmet by the back wheel, gloves off. I got down by the side of the bike and lifted up the tank to take a look.
I looked at the engine, and the spark plug wasn't there. It was dangling by its cable alongside the cylinder. I screwed the plug back into the cylinder as tight as i could (with no plug spanner) and fired it up again, half expecting the engine to blow up, and It fired up perfectly.
Sighing with relief i climbed back on the bike, expecting the engine to fail again at any moment. I pulled away, rode about another mile down the road, and the revs died down again. I pulled over again, took the plug out and looked at it. The tip was kind of whitish, which didn't strike me as good. I laid the plug against the frame and pressed the starter, and got a weedy spark. I refitted the plug, fired the bike up again, and rode home.
I'm replacing the BR9ES plug with the only spare I have, which is a new and sparkly B10EG, but I'm still wondering, what the heck happened to my bike??
The only theory I have is that the plug vibrated loose and the pressure from the explodiness in the cylinder forced it out. The thread on the plug wasn't stripped, and neither was the thread on the cylinder, which doesn't add any weight to my theory, but it's the only theory I have.
My theory also fails to account for the bike failing again without the plug being blown out of the top of the engine, so basically i'm clueless.
Can anyone tell me what's going on?  ____________________ https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman |
| Hex |
 Hex Party Boy
 Posted: 10:29 - 07 Apr 2004 Post subject: |
The plug probably hasn't been tightened up correctly or over time has just worked itself loose.
I personally wouldn't use the plug your about to, and instead just get a direct replacement one. If you do use the other plug you may find performance will be off etc. But if it means you can limp to a shop to get the right plug so be it.
As long as the threads are fine in the head all should be ok.
As for why it died the second time? Could be the plug is dieing, could be in your head, could be the fact you never got it in tight enuf. ____________________ The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio |
| Danny |
 Danny Ask Me About Stoppie School
 Posted: 11:42 - 07 Apr 2004 Post subject: |
I had this happen twice to me on my NSR, first time was on the way back from my first ever BCF meet at Boxhill.
The second time was on the M4 bus lane. When it happened the second time the bike had a hard time starting and felt a bit dodgy for a while. It was well over due for a re-build so that might have something to do with it. |
| GFK |
 GFK Scooby Slapper
| Kris |
 Kris World Chat Champion
 Posted: 14:20 - 07 Apr 2004 Post subject: |
Plug should be BR9 ECS as far as I can remember...
Unlucky though  ____________________ NSR125RR - ZXR750H1 - ZX9R E1 - GSF600S - GSF600SK3 - VFR400-NC30 - SV1000N - ST1100-R - CBR900RR-R - GSF1200SK5 - GSF600SK1 - VFR1200FA - GSXR1000K2 - ZZR1400 D8F
www.prisonplanet.com |
| McJamweasel |
 McJamweasel BCF Junkie
| Kickstart |
 Kickstart The Oracle
 Posted: 14:34 - 07 Apr 2004 Post subject: |
A "10" spark plug will probably work, but will be more prone to fouling up around town. Also an EG is quite expensive I think.
I have had spark plugs pop out occasionally. Normally when I have fitted them to a warm engine and so not done them up that tight (slight paranoia about doing them up tight on a hot engine, then having the head crack as it cools and contracts).
As to the problems afterwards, it is likely to have done some odd things without the plug, such as drawing in extra fuel so running rich for a short distance. Also the plug could easily have been damaged.
| NSR125-Kid-UK |
 Posted: 16:50 - 07 Apr 2004 Post subject: |
Well I've managed to fit the new (B10EG) plug after a little work with some pliers (getting the little adaptor thing off the end) and only one or two electrical shocks. I've taken out the old plug and found out to my horror that while the NSR was supposed to be running a BR9ECS plug, it was in fact running a BPR6ES! .
While these letters and numbers do in fact mean very little to me, here's a snapshot of the plug so I can learn what was wrong with the plug. ____________________ https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
| Robby |
 Robby Dirty Old Man
| NSR125-Kid-UK |
 Posted: 17:52 - 07 Apr 2004 Post subject: |
Ouch . So now I have to get someone to play with the carb for me? (I'd just break it).
What do all the little numbers and letters mean?
Cheers for telling me anyways . ____________________ https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
| Robby |
 Robby Dirty Old Man
| NSR125-Kid-UK |
 Posted: 19:00 - 07 Apr 2004 Post subject: |
Ack! Now I'm getting a spark with a new shiny plug, but the bloody engine won't fire and the battery's almost dead .
It was almost dead this morning too just after I fitted the new plug. Any reason why the battery should be on the way out? . ____________________ https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
| Sparks! |
 Sparks! Sir Tart-a-lot
 Posted: 19:23 - 07 Apr 2004 Post subject: |
Because you kept trying to start it and test for a spark  ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
| NSR125-Kid-UK |
 Posted: 19:37 - 07 Apr 2004 Post subject: |
Nooo, because it fired up after that, although I didn't run it long enough to charge the battery.
And i've lost a big huge battery charger somewhere  ____________________ https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
| Kickstart |
The last post was made 21 years, 360 days ago. Instead of replying here, would creating a new thread be more useful? |
