 jigga1980 L Plate Warrior
 Fisty Super Spammer
 Ant World Chat Champion
 Stiffler World Chat Champion
 Posted: 20:20 - 24 Sep 2008 Post subject: |
I went 125 - VFR400 - ZX-6R in around a year and it was all fairly straight forward. The biggest jump for me personally was a 4stroke 125 to the 400...
The 400 to 600 leap wasn't that much of a shock at all. In fact a 600 isn't significantly quicker to 60 although after that there is a great deal more power on tap. But you shouldn't ever need to be pushing it too much in that territory on the roads!
As far as handling and comfort are concerned that very much depends on what type of 600 you get. I don't think there are many bikes that handle a great deal better than many of the sports 400's. Comfort is more down to the style of bike but even the sports 600's tend to have a little more space available. ____________________ Current Bikes - Kawasaki ZX-6R (636) | BMW G650GS |
 mattgirv Trackday Trickster
 Posted: 20:29 - 24 Sep 2008 Post subject: |
My 400 is much like that in the suspension department. Because it is nearly 20 years old, and has been thrashed around and is also heavier than equivalent bikes nowadays, it means the suspension is well well past its best.
The front suspension on most bikes after about 20,000 miles probably ideally needs a rebuild but its probably never done until it fails or becomes uncomfortable to ride.
You could probably refresh your fork oil/springs in the front for not too hefty a sum. As mr_fisty has already said, that will literally transform the bike and will probably feel a lot better.
I think a 600 could be a good choice if you are finding your 400 a bit limp, but I wouldn't use the 'power to get out of problems' reasoning, its just as likely that power is what got you into that situation in the first place. If you ride within the abilities of your bike, as well as yourself, you will find things a lot easier. I find the only situation more power has been an advantage is on dual carriageways/motorways for very swift overtakes or powering ahead of someone cutting into the side of me. The only discernable problem with this theory as far as I can tell is not only might something unpredictable happen with what you are trying to avoid, but you could end up powering into some completely different situation. Coupled with the fact that you have then increased the speed of which you are going to hit something/ come off.
I think its a gamble, and you shouldn't really use the 'safety aspect' in trying to justify more power. Hey don't get me wrong we all want to experience rapid acceleration and go fast. If the 400 is comfortable at the speeds that you want to go, keep hold and overhaul your suspension.
Mine does need a rebuild really, but I won't do it for now as its just a commuting hack and I'm not running out of travel or anything its just not very good at absorbing bumps at a rapid rate.  ____________________ Bikes: 1998 Honda VFR800Fi, 26,500 miles
1989 Honda CB-1, 38,000 miles |
