Throttle return and MOT
Cigaro
PostPosted: 08:36 - 25 Sep 2008    Post subject: Throttle return and MOT Reply with quote
Hi,
My throttle return cable keeps binding inside the throttle assembly so I've removed it entirely - will there be any problems with this at MOT?
The throttle still snaps closed on its own. The only way you can tell the difference is that it can be turned backwards (it doesn't rev the engine or anything, just goes backwards).
I know it's a bodge, but will it pass?
PostPosted: 08:41 - 25 Sep 2008    Post subject: Re: Throttle return and MOT Reply with quote
TheBassJunky wrote:
Hi,
Does the throttle shut normally? Can the MOT tester see that a cable is disconnected?
If the throttle works as advertised and no one can see that a cable is disconnected I wouldn't worry. The tester is not allowed to dismantle the bike in any way so it won't be an issue.
Cigaro
PostPosted: 08:51 - 25 Sep 2008    Post subject: Reply with quote
It does shut perfectly normally, except, as I said, it can also be rolled the other way.
Apart from that it operates fine.
panhead
PostPosted: 10:39 - 25 Sep 2008    Post subject: Reply with quote
Mine did exactly that, twisted the other way when you throttled off. Although it didn't really affect the bike thats one of the things it failed its MOT on.
ER-6F
The last post was made 18 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 39.31 Kb
