| raak |
 raak Spanner Monkey
| short1uk |
 short1uk World Chat Champion
| raak |
 raak Spanner Monkey
 Posted: 23:28 - 26 Sep 2008 Post subject: |
hi C
Recover master boot record...Yeah that might sound right?
Power cut was electric key meter..and no insurance at the mo, so no joy there.
Computers mine. a bit old and we used to all share it but since we got a laptop no one uses but me.
No windows CD all pre installed.
Meant to, wanted to, should have but DIDN'T make a boot disk
Still cheers for help..
Hate being beaten by something thats probably real simple once
you know what to do.....  ____________________ Previous bikes: Suzuki GT250A / Yamaha DT125 / NTV Honda 650 // currently Suzuki RF900 |
| short1uk |
| raak |
 raak Spanner Monkey
 Posted: 14:45 - 28 Sep 2008 Post subject: |
Hi Catherine
Your were right
Looked up MBR=Master Boot Record
Guess RCV = recover
Looked at instruction manual for computer say press F10 or R for local recovery to begin.
Trouble is pressing keyboard F10 or R does nothing.
if i keep on pressing i just get error buzz
Can type nothing at prompt except in bios Y/N only
Will try to photo bootscreen (just need to dig out camera cd to load up on to laptop.
Have no friends..
to lend CD disc from
Ps on spell check frontUpgraded to opera
9.52 site does not support spell check...
Cheers for reply ____________________ Previous bikes: Suzuki GT250A / Yamaha DT125 / NTV Honda 650 // currently Suzuki RF900 |
| short1uk |
| nick606 |
 nick606 World Chat Champion
| rotax81 |
 rotax81 Nearly there...
| raak |
 raak Spanner Monkey
 Posted: 00:51 - 29 Sep 2008 Post subject: |
| short1uk |
| nick606 |
| iooi |
 iooi Super Spammer
 Posted: 19:59 - 29 Sep 2008 Post subject: |
Follow these instructions to restore the MBR:
Insert the XP or Windows 2000 installation CD in the CD-ROM drive and reboot the computer.
If the computer does not boot with the CD, then you will have to change the boot sequence in the PC’s BIOS setup so that the CD takes precedence over the hard disk.
While booting, the boot program on the CD detects any existing, bootable partitions on the hard disk, stops the boot process and only continues booting once a key has been pressed.
On the first screen of the Windows Setup program, select "R" and on the next screen, select "K" to run the Recovery Console.
Now, enter the following command
fixmbr
If, after re-starting, the hard disk is still not able to be booted, you can also re-create the boot sector in the first partition.
In order to do this, return to the Recovery Console and type in this command
fixboot c: ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| GAS |
 GAS Renault 5 Driver
| GAS |
 Posted: 20:21 - 29 Sep 2008 Post subject: |
| iooi wrote: | Follow these instructions to restore the MBR:
what disc he doesnt have one
Correct
fixmbr
fixboot c: |
| raak |
 raak Spanner Monkey
 Posted: 23:45 - 29 Sep 2008 Post subject: |
Hi all
Catherine.
Yes it's a tower, sorry for not making that clear.
Had computers open before, but only to add memory, not really confident about swapping HDD ,
although i do have an old computer i could whip drive out of if i had to (have got recovery disc for that one somewhere)
lack of confidence makes me just want to see if it is fixable in any other way..
Btw, is COA sticker likely to be inside unit on hard drive or outside on casing somewhere?
Nick606 writes
| Quote: | you can get it by spamming F8 as the pc is loading (at least i think its F8). |
Good idea, if it helps I have to press delete to get to Bios, I thought F8 had some use and have tried but nothing happens,
simply continues to boot screen and stops.
iooi
Cheers for a nice clear breakdown , sure it will help me or maybe some one else suffering 'Computer crash syndrome',
at some point but as Gas points out I don't have a cd to boot
from...
Gas
| Quote: | after switching the machine of for 10sec then switch on and start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a keyboard error message. To resolve this, restart the computer and try again |
Have tried this a few times but no joy, no error message either, just the error Beep
Any hints on how quickly to hit key, how often perhaps (Once only, Repeatedly?),
it seems a bit hit N miss, any guesses at how many times it may take until it actually does come on?
Again a nice clear idea of what to do WHEN i get the computer up and running
Its pretty late now so won't get a chance to try any ideas until thursday due to work.
Thanks all for the advice and help.
Ps to Mods: site does not support Opera 9.52 for spell checker..
J ____________________ Previous bikes: Suzuki GT250A / Yamaha DT125 / NTV Honda 650 // currently Suzuki RF900 |
| GAS |
| iooi |
 iooi Super Spammer
 Posted: 19:16 - 30 Sep 2008 Post subject: |
You got a laptop, you got the internet......
About all you need to get a copy of Windows
Or a local car boot, or friendly neighbour. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| raak |
 raak Spanner Monkey
| raak |
 raak Spanner Monkey
 Posted: 19:52 - 02 Oct 2008 Post subject: |
Just an update on progress...
Got a bit further, not F8 but F10 from booting up got me onto
*setup is inspecting your hardware cinfiguration
*starting windows pre intallation environment
*windows XP splash screen
then:
Non destructive system recovery screen.
Select 'Normal' to recover hard drive
this will not erase data but some soft ware i had installed since buying machine may need to be re-installed.
Press 'Normal' and i get
"Critic error Report.
The space of user partition is not adequate.
Recovery process can not continue!
Press OK to reboot"
Which takes me back to where i started..................
Repeat process and chose advanced and then get
"system recovery will format the user partition and recovery (Sic) all files to their factory condition.
So any data will be lost.
Take caution before pressing 'next'
I guess i have serious Hard drive issue
Am tempted to hit 'next' and continue but although windows was pre-installed if think i will lose that data and have to buy a new copy.
Does anyone know if that is correct?
Am i on the wrong screen?
IF i continue can i get windows back without buying another version?
Cheers for advice
ps catherine
have found COA data and version No
do you still need it?
Cheers
jaz ____________________ Previous bikes: Suzuki GT250A / Yamaha DT125 / NTV Honda 650 // currently Suzuki RF900 |
| raak |
 raak Spanner Monkey
 Posted: 22:50 - 05 Oct 2008 Post subject: |
Quick update and a few more questions...
Btw cheers 'iooi' and 'Gas' for help......
Begged cd of nephew. used 'R' then '1' not 'k' to access recovery module. did 'Fixmbr' still no joy.
So then restarted and did 'fixboot c: STILL no joy.
Computer got to 'Verifying dmi pool data' ok, then stopped....!
Eventually tried to reinstall window using nephews CD.
Screen said that partition C was corrupt/full/damaged did i want to format. said yes. started to re-install windows. asked me for my verification no (25 digits) input the No from the sticker on MY machine...not valid! now machine is genuine pc world purchase, so Used nephews verification no to install. all ok except am being asked to verify windows on line within 30 days.
Question;
am i worrying unneccessarily or
can i just use his number no problems ?
(bearing in mind he still has his computer up and running on the net)
Should i use my own number and hope to explain what happened to a real person via email or telephone successfully?
Will any action be taken to stop me using windows without the proper vwerification number even though i do have one?
Cheers for any help ____________________ Previous bikes: Suzuki GT250A / Yamaha DT125 / NTV Honda 650 // currently Suzuki RF900
| GodzGift |
 GodzGift World Chat Champion
| raak |
 raak Spanner Monkey
| raak |
 raak Spanner Monkey
 Posted: 12:26 - 08 Oct 2008 Post subject: |
Hi computer back up and running...
to;
Short1uk,
rotax81,
iooi,
and GAS...cheers!
Had to remove nephews version and re-intall mine,
(Found out i was mistaking an 8 for a B ,,, )
But finally got there.
Again thanks for the help, gave me a few useful pointers
when all seemed lost.
I did lose all my Data..
but i am rummaging through some old CD's
and starting to get some of it back..
So remember, create a back up disc TODAY....
Bye ____________________ Previous bikes: Suzuki GT250A / Yamaha DT125 / NTV Honda 650 // currently Suzuki RF900 |
| short1uk |
The last post was made 17 years, 335 days ago. Instead of replying here, would creating a new thread be more useful? |
