Graphics card problem... !
Method
PostPosted: 13:08 - 01 Oct 2008    Post subject: Graphics card problem... [HELP!] ! Reply with quote
Ok so ive got a Compaq Presario desktop and its a bit lame now..
Just went out and bought a GeForce 9400 GT graphics card and some more ram.
Ram went in fine, happy days.
Graphics card pushed in fine, etc and the drivers installed fine.
Only problem now is, i dont know how to get it to work...
I have this crappy 6150 in built graphics card on the motherboard which will work, but i dont know how to switch to the new card. I disabled the 6150 in device manager but that didnt work, so im realy stuck basically.
I just got this message last time i tried, idisabled both the new and old graphics card, then enabled the new one and i got this message:
At least one display adapter on the system has been disabled because its driver is not compatible with the driver for the VGA adapter
Help!? lol
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
Serendipity
PostPosted: 14:09 - 01 Oct 2008    Post subject: Reply with quote
There will probably be an option in the BIOS to switch between onboard graphics or dedicated card.
I presume on a Compaq that you would hammer F10 on start up to get into the BIOS then have a look around. (May not be F10)
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
Neorion
PostPosted: 14:29 - 01 Oct 2008    Post subject: Reply with quote
yeah disable the onboard card in the bios and make sure the cable is plugged into the new one.
some Pc's know which card a cable is plugged into.
does it how up in device manager or prompt for new drivers?
VFR FI 2000- Shiney Red Thing
"some things man was never meant to know, for everything else there's Google"
Seb
PostPosted: 18:54 - 01 Oct 2008    Post subject: Reply with quote
You shouldn't need to disable the onboard graphics.
Just for clarifications sake, you've got the new card fitted in and powered properly if relevant, your running your monitor through the new card rather than the onboard connector right?
Is it managing to boot up windows and show you a desktop when wired up that way?
If so your 90% there. If you don't get anything on screen at all, not even the bios, then most likely either your missing an external power connector on the graphics card or your desktop is specifically setup to not allow a PCI-E graphics card to be used. (I've seen this on HPs, although it gives a very specific warning on screen and won't even go past the bios when you try).
2010 Triumph 1050 Sprint ST
Colin Edwards
PostPosted: 19:10 - 01 Oct 2008    Post subject: Reply with quote
Agreed.. Even if its a crap res you should get something....
As for the bios... If your using an additional card and not the built in one put it as primary..
CE
The last post was made 17 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 46.67 Kb
