| u33db |
 u33db Renault 5 Driver
 Posted: 19:21 - 26 Sep 2008 Post subject: Derestricted/Tune Honda MTX125 |
Hi there,
Last week i became the proud owner of a 93 Honda MTX125 to use over winter so my 900 gets kept nice and clean.
Its a good bike but i'm finding it a little slow compared to the full power KMX i had years ago when i was learning...or at least from what i remember.
Are these bikes restricted and in what way?
6th gear seem practically useless at the moment so i'm thinking there must be something holding it back.
Anyone have experience of these bikes?
Thanks in advance!  |
| u33db |
 Posted: 19:32 - 26 Sep 2008 Post subject: |
Thanks for the quick reply!
Is the exhaust restriction easy to get to so it can be ground out?
Failing that what'd be a good aftermarket exhaust to go for?
On a similar note, would it be worth sending the head of to a tuner (e.g. stan stephens) for porting? I had a look at the thing tonight and i'm not sure as the inlet seems rather small to cope with any mods to the head.
Knew about the missing ATAC - been scouring ebay for a 200 head/engine but to no avail...think due to the age of these things they must be pretty rare...  |
| u33db |
| iooi |
 iooi Super Spammer
| salty21 |
 salty21 World Chat Champion
 Posted: 09:44 - 27 Sep 2008 Post subject: |
does the mtx share the same engine as the nsr? if so would'nt the same restrictions apply? ____________________ 04 NSR 125(sold) ---- 03 CBR 600rr(sold) ----90 pan euro ST1100 ' ' ----02 CG 125
94 CB400 Super Four ---- 2000 VTR SP1 (sold) ---- 08 ninja p8f(sold, meh) ----05 CBR600rr  |
| gwernybwch |
 gwernybwch Nova Slayer
| u33db |
 Posted: 14:49 - 02 Oct 2008 Post subject: |
Going to be doing the exhaust tonight hopefully but i've been doing a bit of reading into the ATAC system;
As i understand it theres a shaft that goes into the side of the head and at high rpm moves inward to close off a chamber that sits above it. This then directs all exhaust gases out into the exhaust for full power instead of a mix of gas going to the exhaust and some going into the large chamber therby sapping power.
I found the following pic on this net and it got me thinking;
Is the "chamber" the large hole coming out of the top of the barrel which then gets covered by a copper looking cap off the head?
If so this cap only seems to be held on by a small screw...would it not be possible just to take the cap off and drop a small bolt/dowl down into the hole and then reift the cap? This would obviously reduce the amount of area for the gases to squeeze into and hopefully simulate the effect of a close power value...i.e potentially giving full power.
What are your opinions?
I appreciate i'll sacrifice bottom end power but its a bike that does very little town work so would be worth doing...bouncing off the red line isn't really a problem after all
https://i129.photobucket.com/albums/p206/u33db/mtx_125/e1dc_1.jpg |
| u33db |
 Posted: 14:59 - 02 Oct 2008 Post subject: |
Heres a pic of what i mean (excuse my crude paintbrush skills);
Red dowl would get gropped down from the gold cap right to the well of the shaft therby covering the port.
I think it could work...i read elsewhere someone cap fell of their head and it made a right racket...this must have been becuase the chamber became exposed so that means i can definately get access for a dowl/bolt...
https://i129.photobucket.com/albums/p206/u33db/mtx_125/mtx125.jpg |
 Posted: 15:08 - 02 Oct 2008 Post subject: |
Close
The ATAC chamber works to increase exhaust port volume. More volume is better at low revs. The Yamaha system is far better (which changes the exhaust port timing) but suspect it was difficult to do something similar without trampling Yamahas patents.
The chamber goes from the side of the exhaust port and then does a 90 degree turn and goes up. On the full power versions, from memory, it is driven mechanically by the clutch through a centrifugal drive. When the revs got high enough it moved the linkage. The linkage went into the side of the barrel (you can see the blanked off hole on the side of the barrel) and pushed a piece out that blocked the chamber off from the exhaust at high revs.
The cap at the top can pop off. Do lots of "high" speed riding and the cap wears around the screw hole, with the screw hole elongating until it eventually allows the cap to blow off.
You probably could get someone with a lathe to knock of a spacer to go in at the top and fill the chamber, and bolt it on at the top where the cap has its mounting. Difficult bit would be sealing it.
Personally I am not sure it is that worthwhile. Don't think the chamber being open costs you that much power. Although we did consider such a mod many times when I had my MBX125. Realistically I think the MBX managed about 18hp at the back wheel given how quick it went compared to full power bikes (best on the flat was 92mph, ie, just off the end of the speedo, but it would cruise at 80mph fairly happily, and did so regularly).
| u33db |
 Posted: 15:13 - 02 Oct 2008 Post subject: |
Thanks Keith - think i'll give it a go!
Shouldn't need to worry someone with a lathe...recon i can drop some crude dowl of the right length and width in and then bolt the cap back on top which retain the standard seal design.
Worst case it doesn't work i can just pull the thing out i suppose.
Will let you know how i get on... |
 Posted: 15:22 - 02 Oct 2008 Post subject: |
Word of warning, the cap is a bugger to get off sometimes.
Suppose a piece of wood dowelling of the right length would do the job for a while. Not sure how long it would put up with the heat sitting about 1"~2" from the exhaust port.
The screw that holds the cap on could probably locate the dowelling in place.
Would say to up the jetting a bit as well when you do the exhaust.
| u33db |
 Posted: 15:27 - 02 Oct 2008 Post subject: |
Aye thought about the heat!
May opt for cutting the head off a long bolt instead so its all metal - don't fancy risking a wooden one bursting into flames...my balls are only a mere 20cm away after all  |
| u33db |
| u33db |
 Posted: 09:46 - 03 Oct 2008 Post subject: |
On average 60...maybe 65 down a hill.
The lad i bought it off said the engine was rebuilt a few years back then it stood unused in a garage until he bought it this year to help with his DAS training.
How long do these things last - maybe it needs the rings swapped?
I know its been about 2 years since i was on a 125 but i remember my KMX being a LOT more sprightly that this...even with a chipped barrel it'd pull to over 70 despite belching oil out the back wheras this one just seems breathless. |
 Posted: 09:55 - 03 Oct 2008 Post subject: |
From an old copy of PB with a 125 road test in it the restricted MTX managed 65.5mph with the rider prone and 60mph with the rider upright (the KMX was 1mph slower on both). These are true speeds rather than indicated speeds. So sounds like you are down on performance.
Worth checking over the air filter to check it isn't too dirty. Also check someone hasn't put in a massive main jet when it was derestricted.
However could be a case that when it was rebuilt someone made a mess of it. First step would be a compression check.
| u33db |
| u33db |
| gwernybwch |
The last post was made 18 years, 12 days ago. Instead of replying here, would creating a new thread be more useful? |
