| Thom |
 Thom World Chat Champion
| Ichy |
 Ichy World Chat Champion
| Thom |
| Ichy |
 Posted: 12:49 - 04 Oct 2008 Post subject: |
Seems like there could be an air leak, either through the manifold joints or maybe one of the vacuum connectors or pipes. Usual trick is to spray stuff (I use easi start, others, I believe use WD40) around all the joints to see if the engine note changes.
Just another thought, did you check the float height after patching them up?
Have you tried adjusting the mixture screw? ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| Thom |
 Posted: 21:10 - 04 Oct 2008 Post subject: |
yeah the float heights are fine and ive left the mixture screw where its supposed to be.
ill try checking for air leaks monday, working tomorrow  ____________________ Current Bike: 1996 Yamaha TRX850 (The Japanese-Ducati One).
Previous Bikes: 1990 Honda NSR125 'Rothmans' (The smoking one), 1990 Suzuki GS500e 'Caf? fighter' (The loud one), 1987 Kawasaki GPX400r (The quick one), 1997 XJ600s Diversion (The reliable one), 2000 Kawasaki ER-5 (The spontaneously combustive one) |
| Thom |
| bandit_nate |
 bandit_nate L Plate Warrior
| Thom |
| bandit_nate |
 Posted: 17:29 - 06 Oct 2008 Post subject: |
gs500's a pretty easy bikes to work on, i've never done valve clearances on a gs5 before but i'd guess it's similar to a gpz5.
You have to remove covers on the engine casing, one for attaching your socket driver to the shaft nut and the rocker cover to access the valves, then rotate the engine to whatever marking (Remove right "suzuki" cover and locate the R and R-T marks).
Look on here...
https://www.gstwin.com/adjust_valves.htm
You don't have to remove the carbs to do this valve check btw.
Hope this helps.
Nate  |
| Odie |
 Odie World Chat Champion
 Posted: 14:04 - 07 Oct 2008 Post subject: |
if you have only had your carbs apart then how could it be your cam timing that is wrong?
and glue, what planet are you on?
as for not idling, try cleaning out your idle jets, you will find it helps!
If you cannot balance your carbs because you cannot get it to run long enough, take them off, find a small, and i mean small drill bit, about 2 mm, place it in the inlet side of the carb and adjust so that both carbs gently grip the drill bit in turn, the same amount, that will give you a start point.
not being funny but if you dont know, dont play, you will only cause more mess, unless you have money to pay me to fix them ____________________ You are so ugly when you were born the doctor said "I?m gonna drop it, if it falls is a rat, if it flies is a bat." |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
| Thom |
 Posted: 14:46 - 07 Oct 2008 Post subject: |
| Odie wrote: | if you have only had your carbs apart then how could it be your cam timing that is wrong?
not being funny but if you dont know, dont play, you will only cause more mess, unless you have money to pay me to fix them |
Thanks odie, and i couldnt understand how my timing could be wrong but the popping through the carbs said to me that perhaps the inlet wasnt closing in time, obviously not the problem however.
The glue is a stuff we had lying around used for sealing fuel tanks, not liquid metal but petrol resistant, it's just a tempory measure.
Idle jets are clean, i've done this about 10 times so far with comrpessed air and carb cleaner ____________________ Current Bike: 1996 Yamaha TRX850 (The Japanese-Ducati One).
| Thom |
 Posted: 15:26 - 07 Oct 2008 Post subject: |
Right, refitted the carbs to the bike and had it running again although it doesnt seem to like it.
Im going to hopefully get a small video clip of it tomorrow to post up here because im stumped!
The problem is pretty much this, i can get the bike to run although whilst on choke it barely revs up at all (less than 1.5krevs) and will soon stall (less than 10 seconds) i have to carefully give it revs.
Now i can rev the bike up fine, but it will pop every 3-5 seconds through the carb with the revs falling until the point it stalls.
Now obviously, with the throttle set at say 4k revs the revs shouldnt drop, but they do.
I can't decide whether or not the bike under or overfuelling but it feels to me as if its one of them... possibly overfuelling as it's popping through the carb, the exhaust gasses are heavy and im guessing the throttle/revs problem is because the cylinder cant burn all the fuel and so floods a little more each time?
Someone give me some instructions to tell me what to do and ill follow them!
I've just had a really stupid thought... i was running the mixture screws out at 3 turns previously, obviously this caused rich running but i didnt have this popping issue.
Since i returned the mixture to stock as per manual its been acting weird. I've missed something dead obvious? ____________________ Current Bike: 1996 Yamaha TRX850 (The Japanese-Ducati One).
| Odie |
 Posted: 09:57 - 09 Oct 2008 Post subject: |
Right then go back to the beginning and start again, putting everything back to the stock settings and checking every-thing.
That means taking your carbs off (again ) and stripping them both down to the bare bodies (f,narr, fnarr).
Check every-thing twice just to make sure, that means checking your carb diaphrams and accelerator diaphrams for pin holes / cracking, all jets including internal, internal and external air / fuel passages, making sure that you havent got your throttle slide needle clips in a different positions than stock (if adjustable)etc.
I know that this is some-thing that you have already done but you need to make sure that there isnt some-thing you have over looked.
You will also need to check the condition of your inlet manifolds, if they are cracked or have gone hard.
When you do make adjustments make only one at a time, that way it is easier to diagnos a problem than to try and figure out 2 / 3 / 4 changes at once, all it is, is common sense, run through things logically, one at a time.
Hope it helps
Odie ____________________ You are so ugly when you were born the doctor said "I?m gonna drop it, if it falls is a rat, if it flies is a bat." |
| Thom |
The last post was made 17 years, 313 days ago. Instead of replying here, would creating a new thread be more useful? |
