Changing the swingarm.
Moonie
PostPosted: 09:01 - 04 Oct 2008    Post subject: Changing the swingarm. Reply with quote
Right.
I am now probably buying my dad's C reg FZ750 from him come february.
But I want to make it into a Streetfighter Twisted Evil . Not the gay kind of streetfighter that has no fairings and an alien headlight and that's it, I mean the whole shabang. Custom tail unit and subframe, cut down loom, wide bars, running gear from a better bike, etc etc etc.
I also want to change the swingarm, as atm the back tyre is a 130, which is the same as my GPR50 Laughing
So, anyone know how much hassle this is, which bike to use as a donor, etc.
Any help appreciated
Whosthedaddy
PostPosted: 10:14 - 04 Oct 2008    Post subject: Reply with quote
A custom rear end for a fighter can use anything hence 'custom'. Either pick one that you like the look of and engineer it to work or get one that fits (even of its the original) and try and make it look trick.
Moonie
PostPosted: 10:20 - 04 Oct 2008    Post subject: Reply with quote
Yeah I'm thinking more along the lines of getting one that fits relatively well anyways and then maybe bracing it or something.
Just thought, the FZR Genesis' have big fat rear tyres, could chop one of those about...
Whosthedaddy
PostPosted: 10:27 - 04 Oct 2008    Post subject: Reply with quote
The FZR swingarm and shock mounts. Not the biggest or best looking if I may be so bold compared to more modern bikes.
https://www.bikechatforums.com/files/fzr600_035_190.jpg
After a clean this is what it then looked like:
https://www.bikechatforums.com/files/fzr600_034_142.jpg
After a few hundred miles between strip downs:
https://www.bikechatforums.com/files/fzr600_077_455.jpg
If you are going to start chopping 17+ year old metal up then make sure its good to start with.
D O G
PostPosted: 12:26 - 04 Oct 2008    Post subject: Re: Changing the swingarm. Reply with quote
My FZR 600 has a 130 rear, AFAIK you can't get much more than a 140 on there without a transplant.
Ignore me if you are talking about a FZR1000 swinger.
The 130 should be more than enough for the power tbh. I wouldn't bother unless it's the looks you're after. A bigger rim/tyre will just be heavier and therefore make the whole piece slower.
Check the current clearances and you may find out you could get a 150 on the original rim. Maybe.
rotax81
PostPosted: 12:41 - 04 Oct 2008    Post subject: Reply with quote
make the rest of the bike look smaller then the tyre would look bigger Wink
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
Tristan.
PostPosted: 12:49 - 04 Oct 2008    Post subject: Reply with quote
The FXR genesis used a dodgy diametered rear tyre, so only put one on if you dont like having a wide choice of tyres.
The FZR600R on the other had takes a 17" 160 width, and I think that can be fitted to a genesis, so if the genny fits yours the 600R should too.
D O G
PostPosted: 12:54 - 04 Oct 2008    Post subject: Reply with quote
Not so sure. I have a FZR 600 with the dodgy 18" rear. It does severely limit the choice of tyres as you say, however on all the sites I have been on there has never been a mention of slotting in a 600R swingarm as an easy fix. They always seem to go for random swingarms from Suzukis or Hondas or whatever, then need some machining to sort the wheel out.
If it does fit, however, that would be interesting to know!
Tristan.
PostPosted: 13:13 - 04 Oct 2008    Post subject: Reply with quote
It might be the 600R wheel that fits actually Thinking or I may just be talking bollocks altogether Very Happy
NiteMare
PostPosted: 13:36 - 04 Oct 2008    Post subject: Reply with quote
it's unlikely (but not impossible) that you'll find a s/arm that will drop straight in without a certain amount of messing about
it might be worth you joining DisturbingThePeace as that's a varied make/models fighter site and there may be someone there who has swapped swingarms/wheels/tyres on your model bike ...
some of the things to consider when fitting wider tyres/wheels will be chain clearance on the tyre and then sprocket alignment, you may need an "offset" gearbox sprocket but that can possibly lead to further problems (will the chain clear the inside of the frame rails or will you have to carve the frame ? )..
i've just fitted a GSXR1100 engine into an old Z750ltd chassis, i then fitted a modified Slabby 750 s/arm into the frame (had to ease the pivot points in the frame by 2.5 -3mm each side), i then used a Z1000ltd rear wheel but i then found the sprockets don't line up (expected) so i've had to turn a spacer for the rear sprocket carrier to offset the rear sprocket , plus i had to make spacers to centralise the wheel itself in the wider s/arm...
none of this has been overly awkward (and minimal expense) for me as i have access to the required machinery/tools, how are you fixed in this way ?
some s/arms are harder to fit than others depending on what you wish to use
a couple of pictures of the things i've done ...
milled up new mounts for the suspension after chopping off the original suspension (had to pay for the welding)
https://i259.photobucket.com/albums/hh311/NiteMare_08/100-0037.jpg
sprocket offset spacer
https://i259.photobucket.com/albums/hh311/NiteMare_08/100-0042.jpg
s/arm fitted
https://i259.photobucket.com/albums/hh311/NiteMare_08/100-0047.jpg
it ain't broke...
i ain't fixed it enough
Faldo
PostPosted: 14:21 - 04 Oct 2008    Post subject: Reply with quote
If your going the "whole shabang" you will be needing a single sider. If your gonna put the effort into making a different swingarm fit, you might as well make it look as good as possible. VFR/916 etc.
Make sure you have plenty of time available, or like me you'll end up stripping it down, then it'll sit there for a year before you flog it. Embarassed
Hope to see a thread in Show and Tell soon Thumbs Up
Current: ZZR1400
PostPosted: 14:35 - 04 Oct 2008    Post subject: Reply with quote
He said
That'd make it doubly 'gay', at least Smile.
Though I'm not sure a 130 rear tyre should be much of a problem really, unless you're a tart (which I admit it does sound like he is being Smile ).
Faldo
PostPosted: 14:49 - 04 Oct 2008    Post subject: Reply with quote
Well, I suppose that's the thing with streetfighters innit ? They're all down to personal opinion.
Personally, I think single siders look good, but I doubt there's any "whole shebang" streetfighters out there where 100% of people who look at think "Yeah, that's cool". There's always some who'll say "That is pants".
Good luck with it anyway Thumbs Up
Current: ZZR1400
SoND
PostPosted: 15:56 - 04 Oct 2008    Post subject: Reply with quote
How much money have you got? Any fabrication or machining you need done will quickly add up if you aren't doing it yourself and that's on top of all the parts you will have to buy.
If you're only getting it February I wouldn't count on having it done for next year. Be prepared for a lot of work and messing about.
Good luck.
Moonie
PostPosted: 16:10 - 04 Oct 2008    Post subject: Reply with quote
I can all fabrication and machining done free of charge on demand, one of the reasons I'm doing this.
Yes, I am just being a tart Razz
No, I don't want a single sider, just personal choice.
The reason I thought of an FZR swingarm is that the FZ is basically the same thing in alot of ways, was hoping I might be able to just bang one in, or at least with minimal effort, but if it looks like it's gonna be an effort anyways then I'll just get something off a newer bike.
I was talking about the FZR1000 that has a fatter back tyre.
Cheers guys, there'll be a topic in show and tell at some point, but not for a little while yet.
anarchy
PostPosted: 18:35 - 19 Oct 2008    Post subject: genesis Reply with quote
i have a genesis. 1987-1988 have an 18" rear wheel , which is rubbish for tyre choice. also the early genesis is only a 160- 60, but a 170 can fit . late 88-95 exup models have the 17" wheel and are 170-55, but everyone gets 180-55,which would give you the fat tyre look your after.
Moonie
PostPosted: 20:02 - 19 Oct 2008    Post subject: Reply with quote
Nice one, cheers mate, I've been trying to find exactly that out for a while.
Although have now bought a Ninja G2 Swingarm and rear wheel as I have two people who have offered to get it on for free.
anarchy
PostPosted: 20:13 - 19 Oct 2008    Post subject: Reply with quote
Free is always better. Very Happy
The last post was made 17 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 102.1 Kb
