practical test nerves
Bike Chat Forums Index -> New Bikers Goto page 1, 2, 3  Next
Rufus
PostPosted: 22:30 - 04 Oct 2008    Post subject: practical test nerves Reply with quote
what's a good way to calm nerves? i get extremely agitated and it may affect my riding.
also, what are things which people commonly fail on whilst doing their practical?
thanks.
CG125 > ZX6r > GSX600F > CB250n + ZX7R+ Bandit 1200
Wise1
PostPosted: 22:33 - 04 Oct 2008    Post subject: Reply with quote
Ok, let me go make a coffee and when I return I will explain all the parts of the test, what to expect and what you will need to do.
Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
Previous - GSXR750 SRAD, Fireblade, ZXR750, CBR600
Rufus
PostPosted: 22:44 - 04 Oct 2008    Post subject: Reply with quote
you are a god wisenerl, thank you Smile
Wise1
PostPosted: 23:26 - 04 Oct 2008    Post subject: Reply with quote
ok, lets split this down to make it easier.
To start with
The examiner will want to see
Licence - paper & Photo card or your passport if you dont have photo card licence.
CBT Certificate
Theory Pass certificate
Insurance certificate - if using your own bike
He will then kit you up with radio
Before you go out on the road
He will do the show me, tell me questions.
Makes sure you know these https://www.dsa.gov.uk/General.asp?id=211
On the Road part 1
The initial ride will be quite short, so prep yourself not to make silly mistakes as this is when your nerves at their worst. The reason it will be quite short is because they tend to do the uturn and e-stop early on.
Be aware that he may ask you more than once to stop and pull off, this is normal. Usually he will just ask you to pull up on the left at a safe point and once you have stopped he will ask you to move off. I have covered this in more detail below.
U-turn and E-stop
You will pull into a street and he will ask you to pull up on the left turn off the engine and get off the bike and he will explain what he wants you to do.
First he will ask that you wheel the bike around in a uturn and stop at the other side of the road. What he is looking for is strong observation skills, look ahead and behind before you move and as your moving across the road. Exagerate your observation, dont just make a quick look. Dont turn the ignition or lights on when walking the bike.
Once at the other side he wont prompt you, just get on the bike, start it and prepare for your uturn. Take your time.
Give yourself about 15-20 feet before starting the turn, dont try and cram it all in to a few feet. Before you move look ahead and behind, make it obvious your using your mirrors and shoulder check.
Just before you start the turn, make a very obvious right lifesaver then smoothly round. Dont take the chance of getting round on just throttle, slip the clutch, revs up and cover the back brake, you should only need to use the back brake to control the speed round, but you have the clutch and throttle to adjust the power should you need it.
Once round come to a stop and wait for more instructions. Remember its a U turn not a J turn. You should try and come to stop at about the same place you started from but on the other side obviously.
For the E-stop he will probably ask you to do a circuit around the block, he will step out and raise his hand when he wants you to stop, dont stop when he walks out.
If you go around the block use the opportunity to do a quick e-stop out of sight if you can and its safe, then go around to the street where he is.
Dont rush it, I did 20 mph, he did not state what I needed to do and it as fine, so dont hammer it up to 30mph.
As you approach and he raises his hand >
Off the throttle
Ease the front on
Apply the back but not heavily
More front until your giving it some pressure
clutch in at the very last minute to prevent locking the back wheel
As soon as you stop right and left shoulder check the paddle the bike into the side of the road and into neutral. Dont sit in the middle of the road trying to find 1st to ride over. And dont come down the gears when your doing the excercise, brakes only.
On the road part 2 & Tips
Ok after the excercises its all down to your riding.
You will go up and down many streets, junctions, bends, lights roundabouts, and maybe even onto expressways or dual carriageways.
I cant say what you will be doing exactly but its all about observing the highway code, planning ahead and doing it right.
Planning ahead is very important, always be looking ahead to see whats coming, junctions, lights, crossings and be thinking what your going to do.
When your coming up to lights and they are already at green what are you going to do? Keep going or slow down a bit. If tey change quickly to red do you have enough time to stop safely or do you risk going through a red? Thats where planning will help, always look ahead to get an idea if they just went to green or have been there a while, that will tell you what you need to do.
When he asks you to pull in on the left again plan your stop, is it safe? is there a junction on the other side, if so move forward a bit. When he asks you to pull away make clear forward and rear observations before you pull off and signal before you move.
When your asked to turn right from a major road into a minor, nice clear right lifesaver before you turn.
Always remember to switch the indicators off. If the examiner asks you to turn off your indicator the test is over.
When your moving along the road, every 5-10 seconds make it clear your checking your mirrors, both of them. Dont forget.
When coming to lights and your turning right plan carefully, especially when there is a yellow box on the road. Stay behind the white line unless your absolutely sure you can make the turn before the lights go to red, if your the only one waiting to turn your will be fine, however if your behind 3 cars you will deifantely want to wait until the next green light unless the road ahead on the other side is clear enough for you all to get through. Do not get caught on the box when the lights turn to red or its over.
Watch your road position, centre of the lane all the way, dominate your lane at all times, dont let anyone bully you or try and cut you up.
In terms of road position there is likely to be a right hand bend or similiar with parked cars on one side so the road space is limited and you wont be able to see around the bend. In this case move as far left of centre as you safely can so that you can see as far around the corner as possible.
When your on the right turn to the roundabout make sure you move to the outside lane, indicate, left lifesaver coming on, another going around to the exit, left indicator once you pass the last exit and off you go.
On the mini roundabout indicate your intention when coming up to it if required, but dont worry about indicating coming off if you cant as its accepted there is simply not enough time in most cases.
Speed. Make progress, dont break the limit, if its a 40 dont be doing 20 unless you have good reason.
Be Aware of pedestrians and other road users, a simple touch of the brake will make the examiner aware you have noted the hazard.
Keep it smooth all the way and make progress. Once the uturn and e-stop are out of the way your nerves will not be as bad.
When you get back to the test centre he will ask you a question about carrying passengers then tell you if you passed.
Hope that helps.
Rufus
PostPosted: 23:50 - 04 Oct 2008    Post subject: Reply with quote
you should post that in a new thread and get it stickied, awesome advice Thumbs Up
thank you very much Very Happy
Wise1
PostPosted: 23:58 - 04 Oct 2008    Post subject: Reply with quote
No problem, always like to get people through it first time Thumbs Up
It is really not that bad, the nerves just make it exciting Laughing
nasty
PostPosted: 00:07 - 05 Oct 2008    Post subject: Reply with quote
One question, may sound daft but what side of the bike do you have to be on to do the walking u-turn?
ZX6R F3
Wise1
PostPosted: 00:11 - 05 Oct 2008    Post subject: Reply with quote
The left side. You cant control the bike properly if your on the right doing a right turn. Think about it and you will understand why, best not try it though so you dont have to pick your bike up Thumbs Up
nasty
PostPosted: 00:22 - 05 Oct 2008    Post subject: Reply with quote
Wasn't sure, I know you have to mount and dismount on the left but pushing the bike on the outside (left) as you're turning right just seems a bit strange as this could make the turning circle larger and I would imagine it would be easier to lose balance and drop the bike as opposed to being on the right hand side of the bike which would allow a smaller turning circle, less likely to drop bike as weight would be against you rather than going away from you but then there's the chance of being clipped by traffic coming up behind you when on the opposite side of the road - so I suppose from a safety aspect on the left would be common sense.
ZX6R F3
Wise1
PostPosted: 00:27 - 05 Oct 2008    Post subject: Reply with quote
Try it with then with your own bike just be careful you will likely drop the bike, you will on a bigger one which you will be on for the test.
Imagine, your wheeling it round on the right, you get to the other side of the road and stop. Now what you going to do? Are you going to get on the bike from that position on the right when the bike is on a camber in the road, you will drop it.
What if you need the stand? where is it? On the left!
nasty
PostPosted: 01:08 - 05 Oct 2008    Post subject: Reply with quote
Mount from the right, stand down and dismount from the left Twisted Evil Laughing
No seriously, it all makes sense Lee.
That's me off to sleepies as I'm off for a ride along the coast in the morning Cool
EDIT: Why is the board time over 2 hours behind? It's now 02:30 not 00:08
ZX6R F3
Cigaro
PostPosted: 07:56 - 05 Oct 2008    Post subject: Reply with quote
No. Even when you have the bars turned to the right you will still have the bike leaned into you.
K0rnIsAFAGGOT This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
lozzypop1
Certified MILF!
PostPosted: 17:47 - 05 Oct 2008    Post subject: Reply with quote
At roundabouts/junctions, Don't wait for the instructor, if you've got time to go... GO. Ride for yourself, not for him.
If you get too far ahead, the instructor will ask you to pull over when it's safe to do so and wait for him.
Louise
PostPosted: 17:53 - 05 Oct 2008    Post subject: Reply with quote
I must be one of the worse people to suffer with nerves when I approach something new.
On my test date I had around 2-3 hours to waste (and waste almost £80 because I wasnt riding)
As I got to the test center I met the guy taking me out.
I tried to crack a joke, and it didnt go that well - Got the shakes, on the bike questions I stumbled.
But once on the road it felt natural - Ride like you would normally, it went really well - passed first time.
Hardest part for me would be the 'U Turn'
Ive known a few people who failed on this. Just take a few breaths and go for it.
Put it this way, If a clumsy git like me can pass, im sure you can too Wink
Rustle
PostPosted: 17:59 - 05 Oct 2008    Post subject: Reply with quote
I have a question! Very Happy Ok, you realise that you are in the wrong lane ie. on a roundabout or junction - I know that it will definatly give you a major if you try to cut into the correct lane but if you continue in the lane your in and go a different way than originally told will that mean you get a minor? (Anyone who understands what I'm on about gets a medal! Wink )
By the way: Good Luck Rufus!
Test Passed 29/01/09 - Restriction Ends - 29/01/11
lozzypop1
Certified MILF!
PostPosted: 18:24 - 05 Oct 2008    Post subject: Reply with quote
I think You're right, I didn't do it, but it's a case of mistakes happen... just make a SAFE mistake, go the wrong way but do it SAFELY.
You can always say you misheared Wink
Louise
PostPosted: 18:36 - 05 Oct 2008    Post subject: Reply with quote
You are correct
OH did her test around a month ago - she was told to turn 'left into the next junction' She didnt and carried on. She didnt get a minor.
after all its instructions and not on you ablilty to ride.
blindside666
PostPosted: 18:55 - 05 Oct 2008    Post subject: Reply with quote
Brilliant advise there Wisenerl. Thats helping me alot as well.
Manual turns, do it from the left side. It may make logical sense to do it from the right hand side but trust me it is alot easier from the left, go out and do it from both sides and tell me what happens =P Left is correct way.
Yep, I took the wrong exit off a roundabout by accident and as we came off I tapped my earpiece and he pulled over, I said I'd misheard him, which I did cos it broke up on me =S Didn't get any marks for it though =)
Current Bike: Lifan GY125
CBT: 15th June 2008
A2 Passed: 16th October 2008
Rustle
Smile Phew - that's the only thing that has been worrying me - I'm pretty good at reading the road but if I'm nervous on the day who know Shocked atleast I won't be thinking that I've failed just because I missed a turn!
lozzypop1
Certified MILF!
PostPosted: 19:23 - 05 Oct 2008    Post subject: Re: practical test nerves Reply with quote
Leave yourself time to get to the test centre, don't forget things out of your control can happen and you may find yourself stuck in traffic etc.
ALSO REMEMBER TO STOP AT THE SHOP FIRST FOR CIGS (And make sure you have a light!) Laughing
You'll be fine, Just ride safely.
Wise1
PostPosted: 19:27 - 05 Oct 2008    Post subject: Reply with quote
If you get into the wrong lane and dont have time to move to the correct one for the turn continue in the direction of that lane.
At worst he will simply turn your around and get you back on the right road.
You should not get a minor for going the wrong way unless your doing it all the time.
As said, its your riding he is testing not your ability to listen to instructions.
Moonie
PostPosted: 19:42 - 05 Oct 2008    Post subject: Reply with quote
Lots of Jack Daniels.
You may not pass, but you won't be nervous Thumbs Up
muzz
PostPosted: 19:44 - 05 Oct 2008    Post subject: Reply with quote
As an Ex ADI (cars)...... If you misunderstand the instruction, carry on safely and correctly. You will NOT receive any negative marks, for the direction taken, unless it is unsafe, or against traffic signs etc. I.E " Take the next right", you take the next left correctly = No minor mark... "Take the next right" you turn left into a no entry = Major fault..."Take the next right" you turn left with incorrectly timed signals or road position = minor fault/s. Hope this is clear and helps.
Ride Safe 'N' Free
Rufus
PostPosted: 19:45 - 05 Oct 2008    Post subject: Re: practical test nerves Reply with quote
right! thanks loz Smile tomorrow's the day then Shocked
The last post was made 18 years, 6 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 139.55 Kb
