R6 Gearbox snags
Couger
PostPosted: 15:01 - 13 Apr 2004    Post subject: R6 Gearbox snags Reply with quote
Hiya all.
A quick query and diagnosis from you experts please! Basically my R6 gearbox has become a right pig of late. Problems:
Drops out of gear every so often,
Getting to first at the lights from neutral can be a pig,
Changes from first to second and second to first are a bastard,
When downshifting it seems to bounce lots before engaging,
Nasty sounds because of the above.
Shizer, reading that back makes it sound like my bike is nackered!
Is this a fundemental problem like nackered chain and sprockets, or is this something more terminal? Bearing in mind the bike has done 25000 miles.
Cheers.
Cougs.
Fly Navy
WildGoose
White Van Man
PostPosted: 15:39 - 13 Apr 2004    Post subject: Reply with quote
the gearbox is the notchiest ive ever used...but it always found its gear and stayed there, yours sounds a bit iffy Confused
i cant suggest what might be the problem, im no expert on gearbox internals, just hope its not expensive to resolve
Robby
Dirty Old Man
PostPosted: 16:45 - 13 Apr 2004    Post subject: Reply with quote
Change the oil, and try a fully synthetic.
Old oil makes gearboxes feel awful selecting gear, and the R6 box is notoriously notchy.
PostPosted: 20:43 - 13 Apr 2004    Post subject: Reply with quote
Wise man say:
Its very important to check the tension of the chain, too tight and the 'box is notchy too loose and all sorts of strange gremlins can occur.
Ah so. Karma
R1stu
Shrek!
PostPosted: 01:06 - 14 Apr 2004    Post subject: Reply with quote
Both mine where simular! 1st - 2nd is the worst of anybike I have ridden!
however after a full service and fully synth it was smooth as hell. That was until I changed the rearsets and messed up the shaft changer postion!
Try checking that, as if it lose the shift wont move as well as it should!!
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
The last post was made 22 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 44.57 Kb
