 bren L Plate Warrior
 mr jamez World Chat Champion
 Posted: 17:00 - 13 Apr 2004 Post subject: |
It's a piece of piss
The cyclinder head on the NSR is just a lump of metal with a few holes, you will probably have to drain the coolant. Make sure you clean all the old gasket off and don't get any crap in the engine, use some fine emery paper and white spirit/parafin and just be careful that you don't scratch the mating surfaces. Then just tighten the head bolts to the correct torque. If you download the manual then you can see how easy it is
If you do the piston rings it might be easier to take the engine out, I found it a bit tight so took the whole thing out. Oh and I am rebuilding most of the engine, no experiance before with bikes or many cars, so have alot of other people so it's not that hard  |
