chain issues
dan_bhatoa
PostPosted: 18:53 - 07 Oct 2008    Post subject: chain issues Reply with quote
Hi,
I've recently replaced the back wheel my motorbike, as the wheel bearings were loose (now replaced). I've noticed the slack on my back wheel varies as I turn the wheel, at it's tighest it's around 0.5cm (I head a ruler perpendicular to the chain and pushed straight up). At it's slackest point the chain is 2.5cm.
Is this variation in slack normal? Whilst the bike runs ok, I noticed some sounds it makes are a little different, whenever I change gear I can hear a loud chook chook sound as the gears shift and click - again is this normal?
thx
Dan
Graprilia
PostPosted: 19:00 - 07 Oct 2008    Post subject: Reply with quote
i think you have the same problem as me LOL , hopefully someone knows how to sort it.
Piaggo liberty 125 SOLD - CBR 125 - SOLD Aprilia RS 125 - SOLD CBR 400 NC29 - SOLD ZX6R currently own https://bikepics.com/members/Graprilia/
rotax81
PostPosted: 19:04 - 07 Oct 2008    Post subject: Reply with quote
sounds like new chain and sprocket time. replace them all together as any old bit will fooker a new bit Thumbs Up
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
Finglonga
PostPosted: 21:57 - 07 Oct 2008    Post subject: Reply with quote
All chains have tight spots, the tension of the chain should always be done on the tightest part of the chain. If you use a slack part of the chain then when the tight part comes around (especially with weight on the bike) you stand a chance of bending the output shaft or knackering the output bearing.
As said, if they are too far gone buy new ones.
Andy Sez....
F.Y.Y.F.F.
steve32
PostPosted: 22:08 - 07 Oct 2008    Post subject: Reply with quote
when i first got the bike ive got now i had to change both sprockets and the chain because it was doing the same thing and it failed the mot because of it i would say the best 120quid i spent in a while, better to be safe than sorry
suzuki GSX 600F katana .: ~my bike up for sale~ :.
CBT = Completed
DAS= Working on it - theory test = Passed
dan_bhatoa
PostPosted: 12:55 - 13 Oct 2008    Post subject: Reply with quote
I took it down to Hein Gericke in Welling, got a couple of the lads there to have a look, they said chain looks fine, sprocket has around another 5k of wear left. I bought some chain lube (as opposed to wd40) and gave the chain a clean, then lube (applied to the chain links, not the outside) and topped the engine oil up to the full mark (was at halfway before)
Sounds a lot better now, but will keep an eye on it.
The last post was made 18 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 48.06 Kb
