New brake pads binding for first few miles
Cigaro
PostPosted: 13:40 - 07 Oct 2008    Post subject: New brake pads binding for first few miles Reply with quote
Hi,
Got my new pads in, rebuilt calliper and master cylinder etc. Took it out for a few miles last night and noticed the brakes binding quite badly on one side. However they seem to have loosened up a bit now (though they're still doing it a tiny bit). Is this normal for new pads? Could it be that the disc is slightly worn on one side?
Cheers
Rowan
Odie
PostPosted: 13:48 - 07 Oct 2008    Post subject: Reply with quote
No its not, you have screwed some-thing up, check to see if you have fucked up putting the seals back inside the caliper, causing them to grip the piston and not allowing it to return.
You are so ugly when you were born the doctor said "I?m gonna drop it, if it falls is a rat, if it flies is a bat."
alun111
PostPosted: 12:24 - 08 Oct 2008    Post subject: Reply with quote
Did you clean up the groove where the oil seals sit to get rid of corrosion before fitting the new seals. Did you use the old seals? If so were these in good condition, with no cracks/scoring - did you clean these off (they can become covered in corrosion from the aluminium oxidising). What were the pistons like? Pitted? If so then that raised bits will be causing the brakes to bind by sticking on the seals.
Kris
PostPosted: 12:38 - 08 Oct 2008    Post subject: Reply with quote
Did you put the seals in correctly? Some have angled sides which must sit in the correct position against the piston...
www.prisonplanet.com
Cigaro
PostPosted: 13:10 - 08 Oct 2008    Post subject: Reply with quote
The first bit of the problem may have been that I missed out a little metal clip when I was putting the pads back in the calliper and putting it all back together. Embarassed So that's back in now, but it still does it.
I've spoke to the shop who rebuilt it and it turns out they only did the master cylinder, not the calliper. It seems likely that the piston is sticking due to that being the normal position when the old (quite badly worn) pads were in.
I had to have the master cylinder rebuilt because I put the wrong fluid in so it's possible that also fucked the seals in the calliper.
The binding isn't that noticable, though the bike is slightly harder to push. Went on the motorway this morning though (one junction) and SMOKE was coming from the pads when I stopped! So I think I'll have to take the calliper apart and rebuild it myself (can't afford to have a mechanic do it).
It's not possible that the pads will bed in on their own, is it? It seems to free up more every time I ride it, though that could just be wishful thinking on my part.
Coxyzxr
PostPosted: 14:31 - 08 Oct 2008    Post subject: Reply with quote
Sounds like you didn't reseat the pistons correctly, though how you got them back on and pads over the disc like this is baffling if that were the case.
I would't trust it like this so wouldn't wait for it to 'bed in'
You may need to (gently ) push the piston back in the calipers forcefully with a vice and 2 peices of wood over each side (piston and rear of caliper to avoid damage) and close the vice to properly psuh the piston in it's seat properly.
**WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID !
Cigaro
PostPosted: 14:53 - 08 Oct 2008    Post subject: Reply with quote
When I got the brake system back the piston was already pushed back in for me, but after putting the pads in and bleeding it that's when it started binding. When I took the calliper back off yesterday I noticed the piston was sticking out about 1cm, but this left more than enough clearance to install the pads.
I suppose I could pop it back in again but surely as soon as I used the brakes it'd only stick back out again?
Overall the brakes feel firm and very strong when applied, but I suspect the heat would cause fade on a long journey at the moment.
Could it be bled incorrectly? I've tried re-bleeding it (slacken off bleed nipple, pump brake so fluid comes out, hold lever down and tightning again), is this right?
Cigaro
PostPosted: 17:13 - 08 Oct 2008    Post subject: Reply with quote
I bled the brakes up a few more times and it's stopped binding now. What I did was pull the lever in until it just started to bite, then undid the bleed nipple letting a bit of fluid out and did it back up again, thinking this would 'suck' the piston away from the disc. Correct or not, it worked Laughing
Odie
PostPosted: 08:57 - 09 Oct 2008    Post subject: Reply with quote
The calipers still need stripping, cleaning and the seals checking or replaceing, it is false economy and potentially life threatening by not doing so.
Imagine its wet and you have to hammer on the brakes because some knob head in a Vectra in front decides to brake suddenly and they lock up?
Your life, your choice.
odie
The last post was made 17 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 60.51 Kb
