| Mr Hammers |
 Mr Hammers World Chat Champion
 Posted: 13:53 - 08 Oct 2008 Post subject: Step away from the toolbox... |
Chatting to a mechanic friend recently we were exchanging some home mechanics horror stories. I could hardly believe some of the stuff he's come across over the years. For example, one guy who decided to fix his own clutch in a MKII Escort forgot to tighten his flywheel bolts before putting it back together.
He shouldn't have undone them in the first place of course, and it was only when he was ragging it down the road he found out what a really bad move that was. When my mate got there, he found that the flywheel had come off, went clean through the clutch casing and almost all the way through the gearbox hump (or whatever it's called). He was lucky not to lose a leg.
I told him about the time when a neighbour replaced his rings on his Honda 90 step-thru. It seemed the rings he bought were slightly too big for the piston, so instead of waiting till he could get the right size, he decided to file down the ring seats until they just fitted into the barrel.
Worked fine....for about 2 minutes. When he opened it up again he found the entire top of the piston completely seperated from the rest
Another one was when another neighbour called me over to ask why her car wouldn't start and would barely turn over. I asked when it had started doing it, and she said ever since her son had topped it up with oil. She said he was surprised how much oil it had taken to fill it up, so of course, popping off the rocker cover cap i found it almost full to the brim....
Have you any home mechanic fvck ups you can share..? ____________________ A Guide To Powerbands |
| Kal |
 Kal World Chat Champion
 Posted: 14:08 - 08 Oct 2008 Post subject: |
I started off clueless and to be honest I am only slowly getting better
However fitting a new wiring loom to my CG125 after a botched theft attempt I thought I was pretty safe due to having two good friends with me - one taking care of either end of the bike.
In perfect innocence I believed them when they told me I didn't need the big green wire connecting and to leave it.
Cue a number of random breakdowns over the next couple of weeks culminating with a breakdown on the A47 20 miles from home. Having had enough I took into my mechanic who eventually discovered the loom was earthing through random parts of the bike.
The second thing was all me. I can't remember why but I'd had the back wheel off of my bike to compare with random parts at Lesters (they are good like that) anyway on my way home handling was slightly off until I noticed I'd not tightened the axle nut.
I tightened by hand on the side of the road and took it really easy until I got home.
There is more, but I want to give other people a chance to post... ____________________ Kal...
1984 GB250 Clubman,1983 CB250N Superdream, 1999 GPZ500S |
| Shaun |
 Shaun Likes 'em bent
 Posted: 14:21 - 08 Oct 2008 Post subject: |
Myself and my housemate are big fans of bodging stuff. My work of art is below from when my clutch cable snapped.
https://i129.photobucket.com/albums/p238/cbrshaun/15072008034.jpg
The best one he did was sellotaping the connection on his battery, only to have his lights go on and off randomly when he hit bumps in the road. |
| Reppyboyo |
 Reppyboyo Nearly there...
| tatters |
 tatters Exxon Valdez
 Posted: 15:39 - 08 Oct 2008 Post subject: |
mop stick brake lever on my old FX400R
https://www.bikechatforums.com/files/fx4_351.jpg ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| kiers |
 kiers Could Be A Chat Bot
| Ben. |
 Ben. World Chat Champion
 Posted: 16:29 - 08 Oct 2008 Post subject: |
best
mod
ever!!!
had me in stitches  ____________________ follow my racing season
Race bike - R6
Road bike - sv650 |
| .Chris. |
 .Chris. World Chat Champion
 Posted: 16:36 - 08 Oct 2008 Post subject: |
A couple of days ago I changed the oil and filter on my car after doing a load of work on the engine. All seemed ok until I started it up and drove off up the road. When I stopped at the junction with the main road I heard a funny bubbling sound, then the oil light came on so I killed the engine immediately and got out to investigate. Looking back down the road there was a huge trail of oil following me, so I pushed the car back into my drive and investigated. Seems like the O-ring from the previous oil filter had stuck to the top of the housing without me noticing. This had then bowed under the pressure of the new filter being tightened up against it, creating a big hole for the oil to piss out of .
All sorted now though, very nearly managed to do a half_lyfe  ____________________ Chris
1985 Kawasaki Z550F |
| Ben. |
| Seb |
 Seb World Chat Champion
 Posted: 18:38 - 08 Oct 2008 Post subject: |
My ZZR had a duracell packet doubling as a numberplate light lens  ____________________ 2010 Triumph 1050 Sprint ST |
| virus |
 virus World Chat Champion
 Posted: 18:52 - 08 Oct 2008 Post subject: |
does this count?
https://www.bikechatforums.com/viewtopic.php?t=158063
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| Moonie |
 Moonie World Chat Champion
 Posted: 19:52 - 08 Oct 2008 Post subject: |
My breather pipe for the carb is a handle off one of those paper bags, the float hinge a paper clip, Throttle cable is partly an old BMX brake cable, radiator cap is from a petrol can, Airbox tube broke so is connected by a tube made of gaffa tape, and the undertray is held on with those pins that split in two. ____________________ Don't practice it until you get it right, practice it until you don't get it wrong.
Presenting the one and only Chinkmobile  |
| tutton |
 tutton World Chat Champion
 Posted: 20:47 - 08 Oct 2008 Post subject: |
my frame is held on by rust  ____________________ Past: '05 Peugeot XPS '99 Aprillia RS125 '94 FZR600R
Current: '02 ZX636 A1P '51 CCM R30 |
| chris-red |
 Posted: 21:29 - 08 Oct 2008 Post subject: |
I left a screwdriver in my airbox,
Nealry broke myself and the TDM today trying to put it a front paddock stand on my own.
I did all sorts of horrid things to the GS to keep it running. That rear sprocket is not coming off the carrier
Infact as we speak my TDM is balanced incredibly precariously on 2 axel stands neither of which have all there feet on the deck ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| quacker_boy |
 quacker_boy Cuddle Bitch
 Posted: 22:11 - 08 Oct 2008 Post subject: |
| Davie_G71 |
 Davie_G71 World Chat Champion
| D O G |
 D O G World Chat Champion
| G |
 G The Voice of Reason
| NSR Mick |
 NSR Mick World Chat Champion
| Coxyzxr |
 Coxyzxr Brolly Dolly
 Posted: 12:20 - 09 Oct 2008 Post subject: |
My ZXR throttle linkage is actually held on by two cable ties. It had snapped off the side of the carb bank and whoever had it before tried to glue it on with araldite, dodgy because cable ties is what it needed.  ____________________ **WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID ! |
| garth |
 garth World Chat Champion
| Feasty |
 Feasty World Chat Champion
 Posted: 12:24 - 10 Oct 2008 Post subject: |
When I was about 12 I loved helping my brother work on his car doing bits and bops, he was replacing his front brakes one time and I put the wheels back on for him and tightened them up... only I put all the nuts on the wrong way round, luckily he noticed just before he was due to set off on a rather long journey!!!  ____________________ Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed). |
| Cigaro |
 Cigaro World Chat Champion
 Posted: 13:43 - 10 Oct 2008 Post subject: |
Riding home from work with a hand throttle after the cable snapped. Twice, as the first time I fucked up soldering the end on the new cable Second time I used a screwdriver to make the bike go.
Putting the wrong brake fluid in my bike, that was expensive... seals in the master cylinder swelled so it needed a rebuild.
Driving 250 miles in a car without a clutch cable...not so bad as most of it was motorway.
The best one though, all the switches on my right handlebar fell apart...so I've replaced them with toggle switches inside a Maplin project box, cabletied onto the right bar clamp
Cable ties are absolutely great.
And on my Cavalier, the ignition fell apart - so I kept a screwdriver in the glovebox for the purpose of starting it. |
| LeeR |
 LeeR World Chat Champion
 Posted: 17:59 - 10 Oct 2008 Post subject: |
Helping a mate change the clutch in his Triumph Spitfire, we'd successfully changed the one in his mom's Mini earlier in the summer how hard could it be? We made the mistake of fitting it all back together in reverse order just as the Haynes manual told us to, only we'd put it in backwards. We engaged first gear and the car tried to shake itself to bits, an hour or so later we'd got it sorted.  ____________________ My claim to fame: Austin Vince nicked my pen... |
| ms51ves3 |
 ms51ves3 Super Spammer
 Posted: 18:07 - 10 Oct 2008 Post subject: |
I cable tied the brake lever on my mates quad  |
The last post was made 17 years, 109 days ago. Instead of replying here, would creating a new thread be more useful? |
