bleeding front brakes dilemma. PLEASE ADVISE.
Jai466
PostPosted: 09:21 - 09 Oct 2008    Post subject: bleeding front brakes dilemma. PLEASE ADVISE. Reply with quote
Hope you members can help please.
One of the pistons in my front brakes were sized and I decided to rebuild the caliper.
I brought some dot 4 brake fluid from Halfords and filled the reservoir to full, I’m using the Haynes manual and it says there that I should 1st pull the brake leaver a few times until there are no air bubbles appearing from the reservoir. The problem is that I’ve been pumping the brakes for 3 hours and the bubbles don’t stop.
I them brought a one man bleeding kit for £3.99 from Halfords and open the bleed nipple and started to bleed the brakes. There seems to be extremely small thousands of air bubbles appearing in the lube within the brake fluid, from the bleed tube. I then thought that it could be air entering from the nipple and then put some plumper tape around and retired, still same issue.
The bleeding took too long and I just decided to close the nipple and pump the brake leaver until the bubbles stop appearing.
To be honest they didn’t stop and I gave up, there still was pressure in the system as the brake would apply.
I filled the reservoir and took the bike out for a ride… hoping that the brakes would work. I was testing and trying out emergency stop and worked fine at about 35mph, fastest I could go due to road length.
How would I go about removing the air from the system as there are bubbles from the reservoir if I was to pull the leaver, is there any need?
Sorry for the long post, trying the make things clear.
Many thanks in advance.
The Artist
PostPosted: 09:39 - 09 Oct 2008    Post subject: Reply with quote
OK, those one man bleed things, is it a tube with a valve on the end? If so, put it on the nipple that has been un done about 1/4 of a turn.
Take lid off reservoir.
Top up.
pump brake lots, keep filling up reservoir
NEVER let it run out.
Watch the tube thing and make sure there are no bubbles coming out. If there are, continue.
If there are not, close the bleed nipple and make sure reservoir is full. Put lid back on and go for a test.
As you have done a rebuild, this process may need repeating in the next day or two depending on use.
map
Mr Calendar
PostPosted: 09:51 - 09 Oct 2008    Post subject: Reply with quote
Take top of reservoir (make sure turn bars to it's level). Cover with clean cloth to stop muck getting in and then tie brake lever back to the bars (with bungie, gaffer tape, etc.). Leave overnight (or during the day) but try and avoid doing this when the weathers damp/wet (or if you've got a garage no problems).
This forces the air slowly up to the reservoir. Remember to put the top back on Very Happy
Another tips is to take a rubber mallet and gently tap the caliper to force air up the lines.
Another lace where air gets trapped is the banjo bolt into the reservoir. Crack this open (put a cloth underneath to prevent spilling onto bodywork/paintwork) and then tighten it.
HTH Thumbs Up
Jai466
Top up.
Thanks mate.
The bleeding kit i'm using is the one with a one way value.
Should the bleed tube be complete clear (no air bubbles at all)?
Jai466
PostPosted: 09:56 - 09 Oct 2008    Post subject: Reply with quote
HTH Thumbs Up
Thanks mate.
Sorry is the banjo bolt the only bolt which connects brake pipe to the master cyclinder (reservour)?
Whosthedaddy
PostPosted: 09:57 - 09 Oct 2008    Post subject: Reply with quote
Yep, no bubbles, just fluid.
Repeat, test, repeat again as it may need doing several times of you are having problems as I have had in the past.
Jai466
PostPosted: 10:01 - 09 Oct 2008    Post subject: Reply with quote
Should the top be on while the leaver is held tight with the bars (overnight)?
Jai466
PostPosted: 10:02 - 09 Oct 2008    Post subject: Reply with quote
map
Mr Calendar
PostPosted: 10:04 - 09 Oct 2008    Post subject: Reply with quote
Ideally yes. It's what I do and it works for me.
Whosthedaddy
PostPosted: 10:05 - 09 Oct 2008    Post subject: Reply with quote
I believe the answer to be yes.
Whosthedaddy
PostPosted: 10:08 - 09 Oct 2008    Post subject: Reply with quote
Finally try this trick: Leaving the cap off the master cylinder pull the brake lever in and secure it in place.
https://www.kornel.com/pics/Brakes/P1010019.jpg
Leave the bike to stand overnight then in the morning give the calipers and brake lines a good tapping/twising, starting from the bottom and working your way up to the master cylinder. Once you're done release the lever and replace the master cylinder cover.
Note: Cover the top of the master cylinder with a piece of paper or something similar to prevent the brake fluid absorbing moisture from the air.
Jai466
PostPosted: 10:11 - 09 Oct 2008    Post subject: Reply with quote
How would the air bubbles come up as there is a rubble seal which is air tight... would this not stop the air cumming up to the reservior.
Sorry just read the above post.
Thanks
Jai466
PostPosted: 13:27 - 09 Oct 2008    Post subject: Reply with quote
Would you guys advice that I can ride my bike... or shall I bleed 1st.
I have already taken the bike for a ride as my 1st post said and it stops.
PostPosted: 13:42 - 09 Oct 2008    Post subject: Reply with quote
Personally I would say sort it.
Where are bubbles visable?
One problem can be that when the bleed nipple is undone air can get down the threads and into the caliper. Normally only undoing it a small amount stops this. However might be worth trying again, but pull the lever hard , keep it pulled and then slacken off an retighten the bleed nipple (ie, undo it slightly and allow some fluid / air out but tighten it as the lever reaches the bar so air has no chance to get back in). Repeat that a fair amount.
Also check the bleed nipple is at the highest point on the caliper (assume you aren't trying to use a bleed nipple banjo bolt, normally a bodge people use when they have sheered off the bleed nipple).
As mentioned above it is common to get a bit of air stuck in the top banjo bolt. To get rid of this wrap some cloth around the banjo bolt, pull the lever and crack off the banjo bolt and tighten it again, then you can release the lever.
Jai466
PostPosted: 14:04 - 09 Oct 2008    Post subject: Reply with quote
The air buubles are visable wen I open the top of the reserviour and pull the leaver.
Also wen I attached a one man bleed kit there are thousands of buubles into the tube with the brake fuild.
I thought the same with the bleed nipple then I added some plumers tape which helped.
Sorry what is the banjo bolt, can sum1 please attach a picture with a arrow.
thx
Whosthedaddy
PostPosted: 14:08 - 09 Oct 2008    Post subject: Reply with quote
Google says:
https://www.sideways-technologies.co.uk/images/m2.jpg
I've had bubbles in the tube that may be likened to that of a glass of beer, the more you pump the brake lever, tighten the nipple, top and repeat should start to see less and less bubbles, or even just larger bubbles that are easier to get out of the tubing.
NiteMare
PostPosted: 14:11 - 09 Oct 2008    Post subject: Reply with quote
right then, do you want a cheap and simple way to sort your problem ??
my way of bleeding stripped and re-assembled front calipers works quite easily and quickly ...
you need a couple of large syringes from your local chemist (50ml) and some snug fitting pipe to connect one to your bleed nipple, fill that syringe with brake fluid and connect to the nipple...
after first sucking all the fluid out of the reservoir with the other one, after of course covering your paintwork with rags to protect it...
leave the res' cap off so you can suck more out as needed...
now slacken the bleed nipple and start injecting fluid in thru there (air goes uphill easier than down), your res' will start filling so keep an eye on it, bubbles may come up as well, once you have some fluid in the res' repeat the process with your other caliper(injecting fluid)....
now at this point you should have no air in the mastercylinder or lines but there may be a little trapped in the caliper still...
so nowyou bleed the brakes using a tube into a jar with a little fluid in it to act as an airlock, bleed as you normally would to get the remainder of the air out of the caliper being careful not to let the res' empty, repeat for the second caliper ....
you now should have shit hot brakes ...
if you still can't get it correct it's time to pay someone that can
it ain't broke...
i ain't fixed it enough
Jai466
PostPosted: 14:17 - 09 Oct 2008    Post subject: Reply with quote
Whosthedaddy wrote:
Google says:
The more you pump the brake lever, tighten the nipple, top and repeat should start to see less and less bubbles,
Sorry do you mean open the nipple when pumpping and then wen I release the lever then close?
Sorry not quite clear what you mean.
Thanks
Jai466
PostPosted: 14:20 - 09 Oct 2008    Post subject: Reply with quote
When bleeding with the nipple and jar should i leave the res cap off?
PostPosted: 14:25 - 09 Oct 2008    Post subject: Reply with quote
While you will get bubbles there they should stop eventually. Should be no way for air to get in there. One thing to try is tapping the brake hoses (use the handle of a screw driver) to encourage the air bubbles to rise up. Turn the bars so that the small fluid hole in the master cylinder is at a high point (ie, probably with the lever pointing upwards a small amount). Then pull the brake lever a tiny amount gently and get a few bubbles out. Repeat this. Can normally get quite a lot out this way. Don't pull the lever fully doing this as all you need is a tiny amount of pressure to push the air out of the hole, and you do not need to pull it much as the piston in the master cylinder will block the hole almost immediatly.
Jai466 wrote:
Also wen I attached a one man bleed kit there are thousands of bubbles into the tube with the brake fuild.
The air probably has got in around the bleed nipple but you probably let a lot more in when you fitted the plumbers tape. Personally not sure about using the ptfe tape as it shouldn't be necessary and no sure it won't react with the fluid.
If you look at the end of the brake hose you will find a banjo shaped piece and a bolt through the middle. The bolt in the middle is the banjo bolt.
For example in the following pic the banjo bolt is red
https://www.alfa-pages.co.uk/TempPicture/HelensBrakes.jpg
(that is a failed alloy brake line fitting).
Jai466
PostPosted: 14:32 - 09 Oct 2008    Post subject: Reply with quote
Thanks
Should I open the one near the master cyclinder and the calipier only master cyclinder?
Also Keith I know you said that I should not pull the lever all the way but if I do then thats the time wen all the air bubbles come out.
PostPosted: 14:43 - 09 Oct 2008    Post subject: Reply with quote
Air gets stuck in the top banjo bolt. Basically you want to have the lever pulled and then crack the banjo off a touch and retighten it (use cloth around it so any fluid that gets squirted out is caught).
There are likely 2 holes in the bottom of the reserviour. There is likely one fairly large hole that allows fluid to get behind the piston. This will be nearer the lever is is pretty irrelevant. There will also be another hole further from the lever that is probably a fair bit smaller. This leads into the useful part of the master cylinder and it is from here that you want no bubbles to come from.
NiteMare
PostPosted: 18:37 - 09 Oct 2008    Post subject: Reply with quote
how else will you see if you are running low on fluid in the res' and be able to top it up ??
it ain't broke...
Jai466
PostPosted: 19:02 - 09 Oct 2008    Post subject: Reply with quote
Right guys thanks for your posts.
What I've done is took all the old brake fuild as I found out that my brother shook the bootle before he put in the brake fuild i.e. lots of bubbles.
I kept on pumping the lever untill none was left in the res and opened the nipple.
Top which with new fuild and closed nipple and kept on pumping the leaver untill no air bubble appear from the res.
ATO pressure has bulit up and there are very very small bubbles appear when the leaver is pumpped and held against the bar tight.
I've got a cable tie and held the leaver and handle bar together to let all the remaining air out.
What you guys thing would all the air be gone now?
p.s. You guys rock.
Thanks for all your help.
rotax81
PostPosted: 19:03 - 09 Oct 2008    Post subject: Reply with quote
apart from all the other techniques above. if there is still a stream of tiny bubbles coming up then i normally start the bike up and let it idle while gently pumping the lever. the vibrations help the bubbles rise.
the normal way i do it is to use an easibleed kit but fit it to each caliper nipple rather than the cap.
mind taking it out if you are unsure of the brakes. they can be unpredictable with any air in there Thumbs Up
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
The last post was made 17 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.23 Sec - Server Load: 0.74 - MySQL Queries: 15 - Page Size: 140.98 Kb
