 AJ Nitrous Nuisance
 Kickstart The Oracle
 Posted: 12:44 - 10 Oct 2008 Post subject: |
Take it that it is going into gear and then just not moving forward.
Anything at the back sprocket or a snapped chain should be pretty obvious. So that suggests front sprocket or engine.
Front sprocket lives on splines and should be held in place with a nut (and quite possibly a tab washer). But this should again be obvious with a quick glance.
My best guess would be that somehow you have damaged or jammed the clutch pushrod, or possibly adjusted the cable / actuater on the sprocket cover, so that the clutch is disengaged.
Take off the front sprocket cover. Check the clutch pushrod is in place and straight. And adjust the clutch mechanism and then the cable again from scratch.
 AJ Nitrous Nuisance
 Posted: 15:37 - 10 Oct 2008 Post subject: |
Thanks Keith, I am a spanner I put the washer behind the sprocket instead of in front of it.
Thats what happens when you work in the dark with a torchlight.
Bike is now working 100% again
Shame it's raining tomorrow  |
