| PlasticSun |
 PlasticSun L Plate Warrior
| G |
 G The Voice of Reason
| MarJay |
 MarJay But it's British!
 Posted: 12:30 - 15 Apr 2004 Post subject: |
Aha! A question I can answer. You'll need to check that the bar end weights on your clipons are correct. Sometimes in a low speed spill these are the first things to get damaged and are often replaced by tarty aftermarket items. Perhaps the previous owner had some bad luck and replaced them.
The bar end weights are designed to keep vibration to a minimum and so that would be the first thing that I would check.
Secondly, follow G's advice, and also a good service often helps to reduce vibration especially if you have the throttle bodies balanced.
If those fail then try asking in the technical forum on www.t595.net
HTH  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| PlasticSun |
| Kickstart |
 Kickstart The Oracle
 Posted: 19:40 - 15 Apr 2004 Post subject: |
The weight of the bar end weights is meant to damp out the vibration, greatly reducing the frequency. Adding extra weight might well help, but the Triumph triple is meant to be quite smooth.
I would be inclined to agree that there is a problem elsewhere. Quite possibly nothing serious, but throttle bodies out of balance or a loose engine mount are both possible.
If you DO want to fill the bars with buck shot then take the switchgear off. You will probably find a small (2~3mm) diameter hole in the bars for locating the switchgear (to stop it just spinning round the bars). If you are lucky you can feed the shot in through that hole (might take a while!).
| MarJay |
 Posted: 19:52 - 15 Apr 2004 Post subject: |
Keith, I'm not sure but I think that the Triumph clip ons are billet most of the way along, with an open endpiece that is machined out to fit the bar end weight. I don't /think/ that they are hollow.
I took my switchgear off recently and there is no hole, just a centre punched mark.
I think that a service with balanced throttle bodies is your best bet!  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
The last post was made 22 years, 124 days ago. Instead of replying here, would creating a new thread be more useful? |
