| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 01:27 - 15 Oct 2008 Post subject: Its dyno time baby! Now with added results |
The following is a graph of the ZX7R as it should be, well a US one and a few ponies shy of the figures that Parkers and MCN state it should have, but a power curve none the less.
https://images.sportrider.com/bikes/dyno-2000-kaw-zx-7r.gif
I never really noticed it until somone mentioned it after riding my bike, theres quite a few flat spots at low to mid range with the occasional bogging down before going bananas again.
Secondly, I swear it should accelerate harder than it does at the moment.
I don't like to really give it some in 1st as not too keen on the idea of the front lifting unexpectantly, but coming out of a slip road or from a standing start the bike seems to run out of steam (11-12,000 revs) in 1st at 50 odd with 2nd gear peaking at 80mph. I could get the ZXR to hit 100mph on the clocks in 2nd and I assume that the 7 should be pulling equal speeds if not a little better.
Both of the above should by my knowldge be down to fueling and carburation. Could the above also be key pieces of evidence that would suggest why the bike still doesn't like starting when the engine temperature is medium to hot, say midway up the temp gauge but starts fine when cold?
I've found a local workshop that does race preparation for bikes and has a dyno, for the price of a few quid I want a go to see how the 7's running and what could be done to improve it.
My question, what could be done (hypothetically at this stage) to improve the running of the bike.
If I remember correctly I believe the bike may have been re jetted previously, is there a limit to the amount of tinkering that can be realistically done?
Do the flat spots affect both power and torque or just the ability for the bike to rev in a smooth manner?
Should I start taking guess' to what the bhp is.
| SoND |
 SoND World Chat Champion
 Posted: 01:51 - 15 Oct 2008 Post subject: |
What sort of miles is on it?
Clean, balance and set up carbs if they need done.
Clean/replace air and fuel filters.
Compression good?
Set valve clearances.
Are the valves seating properly without leaks? Could clean them and the head up or get them cut when you're in there.
Got a race can on it? If not it could help.
Is the exhaust leaking at all? ____________________ Go back to bed - You have no rights - "Streetfighters ~ Mainstream motorcycling's crackwhore sister." |
| Whosthedaddy |
| SoND |
 Posted: 02:41 - 15 Oct 2008 Post subject: |
With those miles if you haven't paid for the valves I doubt they've been touched.
Maybe the dyno could solve all your problems, maybe not. Good luck.
My guess is 100hp  ____________________ Go back to bed - You have no rights - "Streetfighters ~ Mainstream motorcycling's crackwhore sister." |
| Whosthedaddy |
| Whosthedaddy |
 Posted: 10:16 - 21 Oct 2008 Post subject: |
Like an excited boy waiting for Christmas to arrive, today finally came. The 7R was off to the dyno!
I had a little tightness in the stomach as would the bike behave in the workshop as it still has a displeasure to starting when hot*, but in no time the bike was up, strapped down and ready to go.
I would have loved to have filmed it but I think it would have come over a little nerdy as I peered through the inspection window.
A few warm up revs and through the box to get things started and already I start beaming like a Cheshire cat at the noise of it. Up and down the box, to the red line before free-wheeling it back down to start once more all the time being accompanied by spitting flames from the exhausts.
The results were as clear as day on the screen and made me smile even more when I see the bhp result.
https://w3.bikepics.com/pics/2008%5C10%5C21%5Cbikepics-1456548-800.jpg
Stock according to the manuals, 123bhp, mine after 10 years and 23,000miles, 115bhp at the rear wheel. All I wanted was a 100, and it has!
Top speed appears to have taken a hammering? The power is still there but the speed isn't? Would have been interesting to see the torque and split times for 0-62mph, 1/4 mile and the likes but that can be for next time.
It was quite clear that my suspicions about a flat spot at 4,000 revs was justified. With the front wheel tethered firm the bike shook as it compressed the suspension hard as it jittered to make progress. Once the spot was passed, it just took off like a rocket.
Fuelling suggests that its a little rich at the top end, not by much but a little more than they would set the carbs to if they were to be tuned, and obviously lean when bogging down.
Treatment, not a lot unless I want a full carb assessment as may need the jetting sorted depending on what's been done in the past.
I even had the chain lubed and the gear linkage tinkered with to allow for smoother transition up and down the box.
* True to form the bike just turned and turned like a lemon only starting with a bump on the rolling road? He suspected it was maybe an inlet problem staying open ever so slightly?
£35 well spent, many thanks to www.mistralperformance.co.uk |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 10:23 - 21 Oct 2008 Post subject: |
Good results.  ____________________ My Flickr |
| Whosthedaddy |
| Keir |
 Keir World Chat Champion
 Posted: 11:15 - 21 Oct 2008 Post subject: |
did they check the air/fuel ratio and torque curve? ____________________ Current : '08 Yamaha FZ1s
Previous: '99 Honda CBR 600FX, 03 ZX636 B1H, 99 Fazer 600 (red), 02 GSX-R 600 K2, 00 SV650s (red), 2008 ZX10R, 97 Bandit 1200N, 04 ZX6RR K1H, 04 GSX-R 1000, 98 Fazer 600 (gold), 05 Madness 110 Pit bike, 04 CR125R, 00 SV650s (black), 06 KTM 625 SMC, 99 SRAD 600 track bike, 03 SV650, 98 Bandit 1200N, Bandit 600SY, 03 GSX-R 600 K3, 01 GSX-R 600, 01 Fazer 600 (black), VFR 400 NC30 x3, 78 Honda Dream, 00 Speedfight 50 |
| Whosthedaddy |
| Keir |
 Posted: 11:27 - 21 Oct 2008 Post subject: |
personally id be happy, regardless of the power figue, knowing that the fuelling is fine and not about to lunch the engine with the exhaust and filter etc maybe leaning it it up a bit.
Power looks good, think manufacturers quote crank power usually dont they? so 123bhp may be at the crank so in turn 115 at the wheel may be very good and hardly any lost at all.... if you get my drift!
on a side note, are you still round these parts? thought you was selling up? ____________________ Current : '08 Yamaha FZ1s
| Keir |
 Posted: 11:29 - 21 Oct 2008 Post subject: |
| Kickstart wrote: | You say the bike is quiet. Think it has shimmed valves, which tend to tighten up with wear and get quieter. Probably is well worth checking the clearances given the mileage and the poor starting. |
The man has a point (as usual....). when the engines warm the clearance probably gets smaller still with parts having slight heat expansion. ____________________ Current : '08 Yamaha FZ1s
| Whosthedaddy |
| Whosthedaddy |
| Keir |
 Posted: 11:56 - 21 Oct 2008 Post subject: |
| Whosthedaddy wrote: | Average cost?
I will have a fluid and filter change, new pads and the like before too long worth getting them measured you think? The last thing I want is for someone to have problems on a test ride when I want rid, that is of course if I don't bin it at Brands come the end of November. |
I think swifts quoted circa £150 for my mates Gixxer. ____________________ Current : '08 Yamaha FZ1s
| Wafer_Thin_Ham |
| Coxyzxr |
 Coxyzxr Brolly Dolly
| Whosthedaddy |
 Posted: 19:23 - 21 Oct 2008 Post subject: |
Mistral are renowned for their engine-building expertise. Did you get a peek in the engine-bay, usually have half a dozen 'busa engines in there being worked-on  ____________________ a.k.a 'Geri'
| Whosthedaddy |
 Posted: 19:28 - 21 Oct 2008 Post subject: |
Bits everywhere!
Had a Busa tucked up in the corner, kept looking at it and wanting to ask more about it but felt a little shy. He said that he is working on engine powered cars mainly, 1600cc Busa engined cars.  |
 Posted: 19:40 - 21 Oct 2008 Post subject: |
Yeah he does a lot of cars, from engines to full-builds. Nice guy too  ____________________ a.k.a 'Geri'
| Wafer_Thin_Ham |
 Posted: 22:21 - 22 Oct 2008 Post subject: |
The last post was made 18 years, 9 days ago. Instead of replying here, would creating a new thread be more useful? |
