| jingeroo |
 jingeroo Two Stroke Sniffer
| Cigaro |
 Cigaro World Chat Champion
 Posted: 14:40 - 21 Oct 2008 Post subject: |
Being the master of bodgery, what I would personally do would be hacksaw it off, drill the bolt out, and put another one through of the same size with a washer and a nut on the outside of the frame, then torque it all up very tight.
It's probably not a good idea though, really.  |
| ravingriley |
 ravingriley Borekit Bruiser
 Posted: 15:23 - 21 Oct 2008 Post subject: |
Thats sounds a good idea. Plus its hard to find tap and die sets with large thread peices.
Bass junky  ____________________ Were all born individual . . Don't die a copy
Sleep When Your Dead!!!!!!!
Sachs Madass  |
| Cigaro |
 Posted: 17:14 - 21 Oct 2008 Post subject: |
The nut is only welded to the frame for the conveniance of a) not being able to lose it and b) for being able to tighten it up using only one spanner.
I wouldn't necessarily even take the old nut off, once you have the bolt out, just fit a slightly longer bolt of the same diameter and put a nut on the outside of the knackered one.
Obviously if this makes it stick out so far it risks fouling something, the original captive nut might need to be ground off the frame. There is no real need to weld the new one on though, just nip it up good and tight with two spanners.
Use a mild steel bolt not a stainless one, use one that is the same diameter as the original and has the numbers 8,8 stamped onto the head of the bolt. This indicates it is strong enough to do the job and not some crappy monkey metal thing from B&Q.
For added security you could always use a nylok nut providing it doesn't stick out too far. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| syl |
 syl World Chat Champion
 Posted: 17:50 - 21 Oct 2008 Post subject: |
Stinkwheel's usually spot on, but now I'm confused. Which one is welded to the frame - the nut or the bolt? ____________________ Current bike: Kawasaki Z750S |
| G |
 G The Voice of Reason
| BanditsHigh |
 BanditsHigh Worse than a woman
 Posted: 20:16 - 21 Oct 2008 Post subject: |
I agree with Method 2, shold last a long time. Might not pass next-years MOT if the tester's a stickler. ____________________ a.k.a 'Geri'
| ZRX61 |
 ZRX61 Victor Meldrew
 Posted: 21:35 - 21 Oct 2008 Post subject: |
Good fucking grief, first fix should be run a thread chaser along the stud FFS  |
| BanditsHigh |
 Posted: 08:57 - 22 Oct 2008 Post subject: |
Ahh, sorry, I misread it as a captive nut Consider my previous post as a load of bollocks.
I've never seen a twinshock with a fixed stud, mine have always had a bolt going through a lug on the subframe.
Although, if it is genuinely a bolt going through the frame with the head tack-welded in place *, grinding off the welds, knocking it back through and replacing it with a new bolt would be my preferred fix.
* Honda actually do use this method for a surprising number of studs, including those on the rear exhaust manifold on VFR750s as I was incredibly relieved to find when I sheared one. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| BanditsHigh |
| jingeroo |
The last post was made 17 years, 301 days ago. Instead of replying here, would creating a new thread be more useful? |
