KX 250 Oil Leak
xxxscotxxx
PostPosted: 19:38 - 23 Oct 2008    Post subject: KX 250 Oil Leak Reply with quote
Well after a bit of work finally got it firing up. Now an oil leak just what i need after a complete rebuild. Found where its leaking from, the output shaft. But I dont no whether it has a seal already or none at all . The seals are on there way but I jus wondered if I should remove this bit of rubber or is it part of the sealing with the seal. And do i have to split the cases again cause I really aint looking forward to doing that again just for a seal. Ive added a pic.
Ant132
PostPosted: 20:04 - 23 Oct 2008    Post subject: Reply with quote
Should you have an O-ring in there?
1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200
xxxscotxxx
PostPosted: 20:32 - 23 Oct 2008    Post subject: Reply with quote
Thought so but how about fitting one and what about that other bit of rubber in there already
Finglonga
PostPosted: 21:12 - 23 Oct 2008    Post subject: Reply with quote
The seal face will be behind where the splines end, when the new ones come you will be able to see if they are just pushed in & your not needing to split the engine to do it.
I have used a couple of self tapping screws before now to get the output shaft seals out(depending on the bike and fitment). By screwing them in to the runner at 12 & 6 o'clock positions and pulling with pliers.
Andy Sez....
F.Y.Y.F.F.
The last post was made 17 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 38.55 Kb
