| T_revs |
 T_revs L Plate Warrior
| Shimmydude |
 Shimmydude Scooby Slapper
 Posted: 16:31 - 19 Apr 2004 Post subject: |
Your pipe shouldn’t be different? But yes I would do it the same way as is on nsr125.com my friend did it that way and it worked fine. I’ve got to do mine yet when I get time.
What nsr you got? ____________________
| Irdawood the 2nd |
 Irdawood the 2nd Nitrous Nuisance
 Posted: 16:39 - 19 Apr 2004 Post subject: |
Ok mate if its an import it will be slightly differant to that on nsr125.com. Take the exhaust off, and I think if its the UK one you will be able to see this.
If its an import its a lot more difficult, where the exhaust come out from the bike there are kinks in the pipe work at the first kink you need to cut there and there will be a ring, grind the ring away and then weld back up. You may need to take it to a garage to do it. But before you do this find out what restriction there is on it. Then try and find the guide on the net with pictures on how to do it properly.
Hope that helped mate  |
| Ant |
 Ant World Chat Champion
| Shimmydude |
 Posted: 18:31 - 20 Apr 2004 Post subject: |
Thanks kickstart. Mines a 1998 so hopefully the exhaust will be as easy to de-restrict as the one on the site! (If I ever get around to it). Hard enough work trying to get it to work properly restricted at the moment!  ____________________
The last post was made 22 years, 123 days ago. Instead of replying here, would creating a new thread be more useful? |
