Honda CB250 G5
Lerch
PostPosted: 19:19 - 27 Oct 2008    Post subject: Honda CB250 G5 Reply with quote
Hi all, this is my first project, an old g5. It had been in my pals garden for 5 years covered by an ASDA carrier bag! anyway, this is my first post, so heres a few pics. Cheers.
bmwsport
PostPosted: 19:37 - 27 Oct 2008    Post subject: Reply with quote
welcome, plenty to be getting on with there! Very Happy
NiteMare
PostPosted: 10:47 - 28 Oct 2008    Post subject: Reply with quote
i had a couple of these when there was still plenty of them on the road...
they came in 3 or 4 flavours that i remember, 250 and 360 G5 then there was the CJ250/360...
the G5 was twin exhaust and 5 speed box and the more common of the two styles/models
the CJ had a 2 into 1 exhaust and a 4 speed box (5th was just blanked off in them so could easily be converted to 5 speed)
there was slight styling differences between the two as well
i put 360 guts in the 250 cases back then (250 learner laws) for the extra bit of power, had to open up the mouth of the top case if i remember correctly (also did the same with the earlier 250/350 K4)
front suspension and brakes could be swapped between the K4 and G5 if needed (twin leading drum on the K4) but the fork legs would accept the caliper hanger etc out of the CJ and vice versa
i liked those old bikes and would have another one any day as a run around toy, whip off the right hand case and clean out the "spinner/centrifuge" oil strainer, change the oil regularly as it'll eat the cam and cylinder head if you don't, and those parts will be difficult to find in good condition now
check the cam chain tensioner works freely or you'll smash the roller and guides and eat your way out of the camchain tunnel (seen that happen)
the rest of the engine is almost bullet proof and very simple to work on
you decide to part with it i'd possibly be interested Smile
it ain't broke...
i ain't fixed it enough
Lerch
PostPosted: 20:22 - 29 Oct 2008    Post subject: Reply with quote
A few more pics.......
(the g5 has a 6 speed box?) Very Happy
NiteMare
PostPosted: 22:28 - 29 Oct 2008    Post subject: Reply with quote
now you have my poor old memory at a loss, it might be 6 speed which would mean the CJ was 5speed ...
if not, then i was correct first time Laughing
and hasn't someone been putting in quite a bit of elbow grease, looking nice Thumbs Up
it ain't broke...
hmmmnz
PostPosted: 02:28 - 30 Oct 2008    Post subject: Reply with quote
i had a g5 and it was a 5 speed, with the worst disc brake ive ever come across, i swear the back drum was better than the front disc.
here was mine as it stood last year Very Happy
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0275Medium.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0274Medium.jpg
good luck with it... hopefully you dont have to replace too many valves,
make sure your tappets are tight, and when you do valve clearances, make sure you use loctight glue..
have fun, they are good wee bikes, if a bit prone to eating themselves,
the humans are dead
I kick arse for the lord
PostPosted: 06:25 - 30 Oct 2008    Post subject: Reply with quote
Do the flames make it go faster?
NiteMare
PostPosted: 20:53 - 30 Oct 2008    Post subject: Reply with quote
you should have got the earlier K4 twin leading shoe drum brake then, it would have dropped straight in those forks and is a pretty good brake
it ain't broke...
hmmmnz
PostPosted: 07:43 - 05 Nov 2008    Post subject: Reply with quote
thye k4 was an over all better bike, they were a genuine 100mph bike, unlike the g5 which tops out at around 80mph,
all though i did manage to get my knee down and grind the pegs on it Very Happy
the humans are dead
NiteMare
PostPosted: 09:46 - 05 Nov 2008    Post subject: Reply with quote
i never saw 100mph on my K4 in either capacity (250/350), 98 was the best i ever saw on the clock in 350 guise (actually 325cc) solo or two up at 9800rpm thrashing the tits off it ....
the 360 G5 i used to pull a sidecar on, so speed was never an issue, i just liked the styling of the bike...
in some ways i'd prefer to have the K4 as when the cam journals wear you don't lose the cylinder head, just the cam carriers which bolt on either side of the head, but both bikes are good as long as they are assembled correctly and the oil is changed regularly ...
both are definitely better built/designed than the wetdream in my opinion
it ain't broke...
hmmmnz
PostPosted: 06:59 - 06 Nov 2008    Post subject: Reply with quote
mine ate a rocker arm or 2 Very Happy and a few tappets and a valve
the humans are dead
NiteMare
PostPosted: 12:14 - 06 Nov 2008    Post subject: Reply with quote
from what i can see it's also eating the bearing surfaces Sad
it ain't broke...
satelliteone
PostPosted: 12:44 - 06 Nov 2008    Post subject: Reply with quote
agreed, the cam shaft needs some tlc. been running shit oil perhaps, or a comtamination in the oil.
If ya can get the cam out. clean up the bearing surfaces. Complete flush of all the oil out of that engine. Might be worth a complete strip down, see what the bottom end is like. Have you a book on the bike?
Honda XLR125R - Project
TZR125RR Belgarda 4DL - Sold
Chinki Project done n Dusted/sold** DTR125 2003 - Finished/sold
NiteMare
PostPosted: 13:29 - 06 Nov 2008    Post subject: Reply with quote
they steadily eat rocker arms as normally as i'd eat dinner
the bearing surfaces will be dying due to lack of oil changes, sad but true
the bottom of that engine should still be solid as the day it was made, roller mains and bigends ...
the top wearing out is the normal reason for those bikes to get pushed to the bottom of the garden and forgot about till they've rusted away to nothing, which is a shame as they are quite a strong engine if looked after with a little thought
it ain't broke...
hmmmnz
PostPosted: 21:50 - 07 Nov 2008    Post subject: Reply with quote
yeah the top end is definitly a weak point,
its just that the cam eats it way though the head,
although the pics above look bad, it wasn't that, that caused me any problems, it was the valve stems kept breaking, along with the rocker arms,
not a huge deal, but a pain in the arse thats for sure,
the humans are dead
Lerch
PostPosted: 22:19 - 04 Dec 2008    Post subject: Reply with quote
How do...........
Ive just tried to turn the engine over using the kick start and it jams up???
It moves freely when the clutch is engaged and the crank turns freely,
I'm pretty sure the kick start mechanism is all correct.
Any ideas??
Cheers.
Tom.
MaybeGuy
PostPosted: 23:46 - 05 Dec 2008    Post subject: Reply with quote
Lerch wrote:
How do...........
Any ideas??
Cheers.
Tom.
put it in neutral?
https://images2.ggl.com/articles/5375/spastic.jpg
Lerch
PostPosted: 22:20 - 22 Dec 2008    Post subject: Reply with quote
Gettin there.....
Big Rab
PostPosted: 20:34 - 08 Jan 2009    Post subject: Reply with quote
I had one of these in 1975, the 250g5 model.
The 360 was a better engine with a bit more power.
Looks like you are doing well with the restoration Thumbs Up
Lets see it when its done.
Rab
The last post was made 17 years, 247 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 103.57 Kb
