Kawasaki KMX125 probably a simple solution
sauluk
PostPosted: 16:41 - 21 Oct 2008    Post subject: Kawasaki KMX125 probably a simple solution Reply with quote
I've not fiddled with a 2 stroke before but i've got a kmx that I just got given to me. It started and rode fine on Sunday but I started it today and the oil light came on and then it cut out.
Checked oil and there was none, topped it up, tried to start and it still wouldn't. The bike has a dead battery but has always started regardless.
I was wondering whether someone could talk me through ways I could try and sort the problem?
Thanks
sauluk
PostPosted: 16:47 - 21 Oct 2008    Post subject: Reply with quote
oh and it's a 2000 W reg. Quite an old one
Finglonga
PostPosted: 20:14 - 21 Oct 2008    Post subject: Reply with quote
Sounds like it seized as you ran out of 2 stroke oil, usually the light comes on when its low but the sender may be duff on yours and came on too late.
Take it you mean you topped the 2 stroke oil tank up?
Will the engine turn over now?
Andy Sez....
F.Y.Y.F.F.
MaybeGuy
PostPosted: 23:04 - 21 Oct 2008    Post subject: Reply with quote
sauluk
PostPosted: 21:03 - 27 Oct 2008    Post subject: Reply with quote
Turns out it was fine, think I flooded it and it cleared overnight, took it for a good run to get it all cleared through
luke27
PostPosted: 23:46 - 27 Oct 2008    Post subject: Reply with quote
If the battery has had it, get a new one soon.
Cold weather finishes off failing batterys.
stevo as b4
PostPosted: 21:06 - 28 Oct 2008    Post subject: Reply with quote
It's actually quite a new one then in KMX terms! Smile
My 200 is a 1988 E-plater, 20years old this year! I wish i had started the engine re-build 2.5years ago, as i have not yet separated the crankcase halfs, and had a look inside to see what is worn and needs replacing? I know the crankshaft assembly and all the bearings won't be a problem to replace, but i have heard that some gearbox parts are now unavailable new? I've been tempted to try and get hold of a cheap second engine from ebay/ bike breaker's to use for spares, but have always thought that the £50-100 it might cost would be better put towards brand new engine parts for my original lump!
The last post was made 17 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 51.79 Kb
