Converting Microfiche Into PDF format
smegbrains
PostPosted: 14:01 - 29 Oct 2008    Post subject: Reply with quote
If you can scan it into a PC, a program called CutePDF will do the conversion to PDF. You install it, and it creates a printer. Send it to that "printer" and it'll offer up a dialog box to save as a PDF file
Nice n easy.
smegbrains
PostPosted: 14:15 - 29 Oct 2008    Post subject: Reply with quote
Vincent wrote:
Nice n easy.
From what I've read up about it so far, an ordinary scanner is no use, the images are just to small Sad Thanks for the input tho Wink
Ahhh... if it's for work there are companies that specialise in doing this. Boss might have to open his wallet a little!
https://www.tasi.ac.uk/resources/digitisation-services.html
You can get addon things for a flatbed scanner of high enough quality, but you will still lose out on some of the detail.
smegbrains
PostPosted: 14:28 - 29 Oct 2008    Post subject: Reply with quote
One of the not-for-profit ones may do it for you quite happily if you call them up and flirt a bit.
There's also the library. My local one still has a microfiche reader.
PostPosted: 21:08 - 29 Oct 2008    Post subject: Reply with quote
I had some done a few years back. Certainly wasn't cheap (£190 for 14 fiche) and not good enough quality to turn into a pdf (scanned as jpg and tif).
I have tried a few desktop scanners with no real success. Not sure you can get an affordable slide / negative scanner. Think part of the problem with a desktop scanner is getting a way of mounting the slide in a decent position.
I have loads of fiche I want to scan, but still trying to find an affordable way.
PostPosted: 22:18 - 29 Oct 2008    Post subject: Reply with quote
I did find a scanner that would do the job, but they seemed to go for about £500. Given the hundreds of fiche I have floating round it gets tempting.
The last post was made 17 years, 352 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 77.95 Kb
