need help with wiring indicators
shogun06
PostPosted: 23:49 - 29 Oct 2008    Post subject: need help with wiring indicators Reply with quote
hi everyone i am trying to put led indicators onto my dt125x the work but dont flash..they just stay on anyone no whats wrong i havent changed the flasher relay..thanks in advance shogun
PostPosted: 23:52 - 29 Oct 2008    Post subject: Re: need help with wiring indicators Reply with quote
You need a resister of appropriate value in-line, I suspect.
I don't know the value, you could google it and I'm sure you'd find some useful info, or wait for someone else to come along and google it for you Smile.
Syx
PostPosted: 13:01 - 30 Oct 2008    Post subject: Reply with quote
Would it not just be a case of changing the relay? I know this has solved problems on a lot of bikes where LED indies have been installed.
Ichy
PostPosted: 18:32 - 30 Oct 2008    Post subject: Reply with quote
Just change the relay, I got one off Ebay for a couple of quid.
I don't like the idea of fitting resistors. Even ballast ones can get quiet hot, fit the wrong ones and bits will start melting.
The benefit of a relay is that it reduces the load on the generator by a good amount, between 80 and 40 watts. 4 - 6 amps. I realise its not continuous but when your lights are on all the time it helps to keep the battery charged up.
The last post was made 17 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 38.81 Kb
