ignition timing/points gap
Chealsie
PostPosted: 19:14 - 30 Oct 2008    Post subject: ignition timing/points gap Reply with quote
Hiya
Following on from a last thread about my bike (GP100) thats being a real pain to start now, i was advised to check the timing and points gap.
I studied the manual and attempted it today, as i need the bike to get to my training and test the next few days.
So today, i took the flywheel off and cleaned the points, no difference. So i gapped the point to an approx. (no proper measuring tool) .3/.4 mm points gap. Then i lined the timing marks on the flywheel against the mark on the crankcase and the points were sparking good and on time.
Still no difference when i put everything back together again.
Took aaages to start again. Crying or Very sad Slight powerloss recently but compression of 150psi Confused Today i also cleaned my exhaust and exhaust port.
What else can i do or try please, or is it possible the timing is still wrong. Thank you guys
Chealsie Dagger! Wink
chillpill
PostPosted: 19:33 - 30 Oct 2008    Post subject: Reply with quote
new plug
and get yourself a feeler gauge to gap it properley there only a few quid Wink
Chealsie
PostPosted: 19:35 - 30 Oct 2008    Post subject: Reply with quote
chillpill wrote:
new plug
Hi, recently a new plug. 1 maybe 2 weeks ago infact. I suppose a new one wouldnt hurt but surely something must be wrong to go through a plug that quick right?
Thanks Smile
rotax81
PostPosted: 19:37 - 30 Oct 2008    Post subject: Reply with quote
if the points were sparking well good then my guess is a knackered condenser (the little can next to the points).
its common to change that and the points together Thumbs Up
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
Chealsie
PostPosted: 19:40 - 30 Oct 2008    Post subject: Reply with quote
Hi, thanks for that. I think i will change them both for new tbh then Smile Another thing i noticed, being a total noob with changing stuff like that, i was messing with the gapping and trying the spark and sometimes it wouldnt spark and then id change the points position and it would spark. Not sure if this says anything but thought it might be worth mentioning.
Gonna look into new bits for it then Smile Thanks
PostPosted: 19:41 - 30 Oct 2008    Post subject: Reply with quote
A dead condenser can kill a plug and a set of points in very short order.
Eyeballing the timing is not good enough. At a very minimum use the old "fag paper" trick. Slide a fag paper between the points. You ought to just be able to pull it out without tearing it as you get to the timing mark.
Chealsie
PostPosted: 19:51 - 30 Oct 2008    Post subject: Reply with quote
Thanks Stinkwheel, Embarassed i should have also mentioned i have done the rizla trick. my neighbour was helping me for a short while, he bought out a packet of rizla and showed me, i thought oh great, why did i ever let you help Laughing , good basic method though
So im at the point where i know the points open at the right time, but unsure of the gap. It looks really small, but i havent measured it at all.
What are the symptons/signs of a naff condenser? Sound likely in my case? Can i pick one up from any bike shop or will it have to be online, as time is a factor Sad
Thanks again Very Happy
rotax81
PostPosted: 20:08 - 30 Oct 2008    Post subject: Reply with quote
your bike shop should have a condenser as they are a very common replacment. a lot of bikes use the same part in most cases.
if the points are new and the timing is where its suppose to be then the fag paper trick will work.
i used to use the card from a fag packet for the points gap Thumbs Up
basically the points have to open to release the spark from the coil.
the points have to be closed for an amount of time to charge the coil.
hence the importance of the gap Thumbs Up
lube the little pad on the cam that opens the points with a BIT of engine/2 stroke oil to stop the heel wearing too quick on the points.
(thats if it has one)
PostPosted: 00:19 - 31 Oct 2008    Post subject: Reply with quote
It's probably like most small strokers of that era in there is no seperate adjustment for the gap and the timing.
They reach a point of wear where it is impossable to get both within an acceptable limit and the points just need replacing, even if they look to hav eplenty of meat on them.
Basically, set the timing, check the gap. If the gap is too big, you need new points.
You should be able to get new points and condenser from wemoto.com . I think the last ones I bought for my GFs YB100 came in around the £15 mark.
The last post was made 17 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 64.77 Kb
