Aprilia RSV suddenly won't start
loply
PostPosted: 19:56 - 30 Oct 2008    Post subject: Aprilia RSV suddenly won't start Reply with quote
Hi folks,
My new 2002 Aprilia RSV has suddenly stopped starting. This morning the battery was flat (it's been struggling for a while) so it turned over a few times then left it and walked.
I wen't back this evening (having left it on charge all day) and it was exactly the same. When I hit the starter it turned over, made a slight crack (nothing too loud though, I don't think it was anything...) and I gave up.
I hooked up some jump leads to my car and tried it... Turns over beautifully, nice and fast, sounds smooth as you like, but absolutely no firing.
Theres air poofing out the exhaust and I can smell the odd whiff of petrol but it won't fire or backfire no matter what I do.
I'm feeling like there's no spark? These are twinspark engines so... CDI? What would cause that?
I get no warning lights but for a few moments the dash intemittently flashed "EFI" whilst turning over.
Any suggestions? I can obviouslly pop a spark plug out and check if it's sparking, but I don't know what to do once I've done that...?
Thanks for any help,
Rich
Yamaha SZR660 Caution to the wind, the throttle pinned!
Finglonga
PostPosted: 20:13 - 30 Oct 2008    Post subject: Reply with quote
You may have just flooded it, try with the jump leads first so it has a good chance next time.
Then Get a new battery . . . a good one.
Andy Sez....
F.Y.Y.F.F.
loply
PostPosted: 20:39 - 30 Oct 2008    Post subject: Reply with quote
I considered that, but, given that I tried for quite a bit (in two sessions) to start it, and I never got a single backfire or even a cough or splutter, I thought in the end it wasn't down to that?
If it was flooded, the best bet would be to leave it for a while (say overnight) then try again?
Finglonga
PostPosted: 20:48 - 30 Oct 2008    Post subject: Reply with quote
You can sometimes clear it by holding the throttle open fully until it catches(close it straight away as soon as it fires) but if not half hour standing should do it.
Andy Sez....
F.Y.Y.F.F.
Cigaro
PostPosted: 20:53 - 30 Oct 2008    Post subject: Reply with quote
A trick with fuel injected stuff is to pull the fuel pump fuse to clear the flood.
ZaphodBeeble
PostPosted: 20:54 - 30 Oct 2008    Post subject: Reply with quote
A few words of advice:
Don't try to start an RSV with a low battery charge. I know of people who have ruined their starter (sprag) clutches because of a weak battery. These sprag clutches are about £200 last time I checked and most of the time cannot be repaired, only replaced. Be VERY careful with it and make sure the battery is fully charged. Get yourself an optimate charger or similar.
As for the problem you are having; I would first check the spark plugs - as long as you have fuel in the tank. Smile
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
PostPosted: 08:29 - 31 Oct 2008    Post subject: Reply with quote
I was going to say the exact same Beetle.
The clag you heard was the motor kicking back against the starter clutch. Do that too often and it'll break. I always used to keep mine hooked up to an optimate(well once a week) as it had an alarm on it and I never had any problems.
The alternative is to fit a 14aH battery instead of the standard 12aH. Fit something decent like a Yuasa battery though.
loply
PostPosted: 10:58 - 31 Oct 2008    Post subject: Reply with quote
Okay folks. I have a new battery here waiting to go in, in the interim I'm jumping it off a car anyway so that shouldn't matter.
My plan is to check the fall-over/crash switch, then I'm going to connect the diagnostic wires which may lead to a code being displayed on the screen.
After that I'm going to pop a spark plug out and take it from there.
Problem is, that bike is left in a daft place where it broke down, so I need to either work on it there (and it's pissing down!) or wait a few days to move it with a van. Nightmare Rolling Eyes
PostPosted: 17:14 - 01 Nov 2008    Post subject: Reply with quote
Be surprised if it was the tilt switch. They tend to not reset themselves after a fall. It's rare for them to just cut the bike out.
ZaphodBeeble
PostPosted: 22:51 - 01 Nov 2008    Post subject: Reply with quote
You can unplug the tilt switch on the RSV's to eliminate them. The only problem is they give you a dash warning when unplugged.
The last post was made 18 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 64.29 Kb
