| Deemer |
 Deemer Derestricted Danger
 Posted: 13:57 - 01 Nov 2008 Post subject: Peugeot Speedfight 2 - Wont start? |
https://uk.youtube.com/watch?v=Yk3i69T9Qyk
Hello, I've got a problem with my Peugeot Speedfight 2 scooter.
It randomly gives off a spark, I've had the coil tested and it's getting to the coil but the coil doesn't seem to be always sending it to the spark.
The lights are also working fine.
The Battery is also working but since i've been trying to start it now for ages it's dieing down and struggling so i'm sticking with kickstart for now.
The red immobaliser light flashes red when the keys turned on and the brake lights work also.
I've got a brand new spark plug, the cable in coil lead the end is green not sure what that mean's friend told me it's not getting a signal or something from other end?
It doesn't start, but then randomly it might just start but wont start again so it's really confusing, Not sure if it's the coil? or wiring problem.
Please help me fix my baby
Thanks,
Paul Deemer.
| rotax81 |
 rotax81 Nearly there...
 Posted: 14:17 - 01 Nov 2008 Post subject: |
if the end of the lead is green, cut it back slightly and refit the cap.
go from there  ____________________ ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol) |
| Deemer |
| prawny1 |
 prawny1 World Chat Champion
| Deemer |
| prawny1 |
| ms51ves3 |
 ms51ves3 Super Spammer
| Deemer |
| prawny1 |
| Deemer |
| ms51ves3 |
| Andyco11 |
 Andyco11 Borekit Bruiser
| Deemer |
 Posted: 20:43 - 01 Nov 2008 Post subject: |
ooops sorry IT DOES rev
Edit: It starts randomly like 1/30
and even run fine... but when i turn it off it wont start up again. |
| ms51ves3 |
| Deemer |
| Deemer |
 Posted: 11:57 - 02 Nov 2008 Post subject: |
File is uploading, There's a sequence on the flashing it's like flash, stop... flash.. stop.... FLASH stay on.
you'll see in video.
Edit: When I start the electric start, the light flickers.
Edit: https://uk.youtube.com/watch?v=Yk3i69T9Qyk
There's the LINK |
| Deemer |
| yambabe |
 yambabe World Chat Champion
 Posted: 00:30 - 12 Nov 2008 Post subject: |
You probably need a new battery.
Your immobiliser will kick in if your voltage is dropping below 9 volts and this is what Himself says is happening after watching your video.
Switch it off, connect it to a booster pack then switch back on. Don't try to connect a booster or charge the battery in any way with the ignition still switched on! If it starts no problem this is the cause of your problem and replacing the battery should sort it out. ____________________ Sod falling in love, I wanna fall in chocolate.  |
| prawny1 |
 Posted: 01:20 - 12 Nov 2008 Post subject: |
do you have both the ignition keys for your bike?
you can try resetting the immobiliser if you have both the red (master key)and black (service/normal) key,
First make sure the battery is charged then put your red key in the ignition and turn it on for five seconds and then turn it off and remove it, then put the black key in and turn the ignition on for five second then remove it and finnaly put the red key back in and turn it on for another five seconds then remove it again and wait two minutes before trying to start the bike with your black (service/normal) key,
The above precedure should be completed as quickly as possible and both keys should not be near the ignition at the same time, also make sure you have no radio equipment on near the bike when you do it.
The flash code is very important in diagnosing immobiliser faults, infortunatly i cannot recall what they are, but some times the immobiliser has just lost code much like a car and just needs resetting.
The above precedure is worth a try, my pal has a breakers yard told me how to do this, he got the info from a peugeot dealer, Most dealers would rather charge you for a new immobiliser than tell you how to re-register your own keys (missmatched keys won't work only the origional or cloned ones will be recognised), or charge you a small fortune to do it for you. |
| Deemer |
| Keir |
 Keir World Chat Champion
 Posted: 14:01 - 13 Nov 2008 Post subject: |
| Deemer wrote: | PROBLEM RESOLVED
Immobiliser Problem:
Fixed By:
Fitted a CDI that bypasses the Immobliser, This worked great and started first time even with no battery. |
well that was suggested by prawny all along....  ____________________ Current : '08 Yamaha FZ1s
Previous: '99 Honda CBR 600FX, 03 ZX636 B1H, 99 Fazer 600 (red), 02 GSX-R 600 K2, 00 SV650s (red), 2008 ZX10R, 97 Bandit 1200N, 04 ZX6RR K1H, 04 GSX-R 1000, 98 Fazer 600 (gold), 05 Madness 110 Pit bike, 04 CR125R, 00 SV650s (black), 06 KTM 625 SMC, 99 SRAD 600 track bike, 03 SV650, 98 Bandit 1200N, Bandit 600SY, 03 GSX-R 600 K3, 01 GSX-R 600, 01 Fazer 600 (black), VFR 400 NC30 x3, 78 Honda Dream, 00 Speedfight 50 |
| Dondi |
 Dondi L Plate Warrior
| finpos |
 finpos World Chat Champion
| tomotomo |
 tomotomo L Plate Warrior
The last post was made 16 years, 294 days ago. Instead of replying here, would creating a new thread be more useful? |
