Pain in the Arse
Proview
PostPosted: 02:05 - 03 Nov 2008    Post subject: Pain in the Arse Reply with quote
Right well here in spain it has started to get cold at night so when i go to work at 5 pm it usualy quite warm n sunny but wen i leave at like 2 am it usualy very cold and my Aerox RR has a 20 carb and it usualy starts ok but if i give it full revs it just cuts out so i have to come home at like 10 mph and its a right pain whats wrong with it yes i posted this at nearly 4 am it just took me so mlong to get home tonight
Aerox R 50cc 2008 ,Aerox RR 2002, Mbk Nitro 2001, Beta RRT Elf racing series ,1989 Beta trueba Needs fixing
! ! ! -Pat- ! ! !
Gonna wrap a teatowel around the lid nextime..y'know for relgious reasons
Ichy
PostPosted: 06:18 - 03 Nov 2008    Post subject: Reply with quote
Check the air filter is clean and oiled if its a foam type. It might be condensation restricting the air flow.
rotax81
PostPosted: 09:10 - 03 Nov 2008    Post subject: Reply with quote
im not sure if you mean it does it all the time or just when the weather is cold.
if it just does it at night on the way home when the temperature is cold it sounds like carburettor icing. basically ice will block the jets off where the air flows through the carb.
to test this.
start your bike up, head home and when it starts playing up, stop the engine for about a minute then start it again.
if it is ok for a while and then plays up again that will be your problem.
if it does it all the time, day and night then it may be more of a fuel filter or carb problem.
p.s. it doesnt have to be icy for the carb to ice up. the weather just has to be very cold.
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
Proview
PostPosted: 21:16 - 03 Nov 2008    Post subject: Reply with quote
yep it only happens at night when its colder
but it wouldnt start tonight so i took the bowl of the bottom of the carb and emptied it out and it was very oily i think the oil is sinking and the petrol is floating but then it wouldnt run anyway would it ?
! ! ! -Pat- ! ! !
rotax81
PostPosted: 21:25 - 03 Nov 2008    Post subject: Reply with quote
your main jet will take it from the bottom, if its oily then it will upset the running.
shouldnt be oily though, are you mixing the oil in the fuel or has it got an autolube pump and tank?
Proview
PostPosted: 00:59 - 05 Nov 2008    Post subject: Reply with quote
it did have but the pilliock who had it b4 me took it off thinking it would go faster but hey
also i noticed where the auto lube system was and there is a tube that goes to the bottom of the engine next to the cilinder would tht lube the bottom end ?
! ! ! -Pat- ! ! !
rotax81
PostPosted: 10:38 - 05 Nov 2008    Post subject: Reply with quote
that lubes everything. the piston,cylinder,bearings etc Thumbs Up
Proview
PostPosted: 18:38 - 05 Nov 2008    Post subject: Reply with quote
are you 100 % that it lubes the bottom end aswell so how do people take it off and not ruin the engine ?
! ! ! -Pat- ! ! !
The last post was made 17 years, 353 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 56.37 Kb
