Shocking bars !
Jamie S
PostPosted: 20:51 - 03 Nov 2008    Post subject: Shocking bars ! Reply with quote
No joke !, The ER-5 has shocking bars!, electric shocking bars Confused
Christ it hurts, even through gloves you can notice it, and it's bad enough to make you want to take your hand off ( dad first noticed it) It only seems to do it on the throttle side though, I still can't see how you can get a shock through rubber grips (heated grips, but they weren't plugged in) , but what could be causing this ?
Would 12v be enough to cause much pain? , how many volts would be in the kill switch mechanism?
Ariel Badger
PostPosted: 21:01 - 03 Nov 2008    Post subject: Reply with quote
The only voltage you should "feel" on a bike if it gets you is the HT from a sparking plug etc. How on earth that could be coming up to the twist grip though Confused
Try putting a voltage meter to earth (house water pipe)and have a poke about with the other lead and see what it shows up.
Warning... if it is the HT it will cook your meter.
Kill switch will be on the LT side ....12v although I suppose there could be some leakage or a nob had wired it from the HT side.
Paddy Blake
PostPosted: 21:25 - 03 Nov 2008    Post subject: Reply with quote
At a guess I'd say it's a short at the kill switch.
Paddy.
Finglonga
PostPosted: 21:57 - 03 Nov 2008    Post subject: Reply with quote
HT lead shorting out on heated grip cable?
Andy Sez....
F.Y.Y.F.F.
Jamie S
PostPosted: 22:27 - 03 Nov 2008    Post subject: Reply with quote
Thanks for the help guys, seems that the best thing to investigate first will be the HT side of the ignition then (it feels almost like a spark plug shock), just continuously, and not quite as bad.
The bike runs sort on though, still, will check everything over tomorrow. Thumbs Up [/i]
Cigaro
PostPosted: 09:14 - 04 Nov 2008    Post subject: Reply with quote
Heated grip cable too close to HT lead is the only thing I can think of. I would have suggested throttle cable but most bikes have a plastic throttle tube.
The last post was made 17 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 46.84 Kb
