Need help with zx6 2002 model
Tasos
PostPosted: 08:46 - 04 Nov 2008    Post subject: Need help with zx6 2002 model Reply with quote
hi all first post
been having problems with cooling system but am guessing the thermolstat has gone as fan is starting way too late so bike is running very hot and it keep dumping the resavor
and my bike like to be a pain in the a**S it does not like running in fog or heavy rain ect it starts to fire on 3 cylinders and after some time stall and will not start if i wait 10 mins it will start and then same happens again and it takes about a day or 2 of dry weather to start working again on all cylinders and back to full power i have been to bike shops and looked for the problem my self but getting to the stage where i am almost ready to give up any help would be apreaciated
sorry about the long message
TAX MY BRAIN
PostPosted: 17:44 - 04 Nov 2008    Post subject: Reply with quote
Sounds a bit like your getting water into your electrics,
You could try a can of dampstart to drive out the moisture from the electrical contacts on your bike,
But i would start with a look at all your electrical contacts if waters been getting in to your wiring loom and contacts chances are the contacts will be all green and coroded,
If this is the case give um a clean with some smooth sandpaper and a bit of good old wd40,
Tasos
PostPosted: 20:55 - 06 Nov 2008    Post subject: thanx Reply with quote
i have done that and found the problem my bike. it uses induction coils and they had started to let water in and on top of that found a cracked spark plug but still cant fix temp problem is still running very hot 105 to 112 c
and i put new thermal stat in but still no help
guess you can say confused.com
The last post was made 17 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 35.29 Kb
