| wookey |
 wookey L Plate Warrior
| wookey |
| Major_Grooves |
 Major_Grooves The Doctor
 Posted: 20:34 - 21 Apr 2004 Post subject: |
I think Keith always mentions corrosion as being a problem with bandits. Probably true if it's that old. ____________________ About me|@Major_Grooves|My company|Digg|Flickr |
| Kickstart |
 Kickstart The Oracle
 Posted: 21:27 - 21 Apr 2004 Post subject: |
I have a 1200 Bandit, not a 600. Corrosion is a problem (I had frame paint crack off when the bike was under 6 months old). The rear brake caliper seizes up. Wiring covering breaks as it goes around the head stock. 95% of the exhaust is stainless steel, but the 5% that is mild steel (on the 1200, where the 4>1 section joins the link pipe to the silencer) rots badly. Fuel gauges can fail. Rear shock is likely to be getting on a bit, and the linkages are probably in need of attention. Bodywork breaks where in attaches under the seat just behind the petrol tank.
| sickpup |
 sickpup Old Timer
| Kickstart |
| sickpup |
 sickpup Old Timer
| Kickstart |
 Posted: 12:43 - 22 Apr 2004 Post subject: |
The paint around the rear footrest hanger cracked off at 6 months old, and was (eventually) bodged up under warrenty. Most of the other damage only became visable when I stripped the bike down. Suspect that 99% of other Bandits are similar, its just that until it is in pieces you cannot see it.
It bent the valves (all 16 of them) because the cam chain jumped, and that happened because of a foreign object getting into the crankcases, which is probably my fault as it probably got in there while the rocker cover was off. By the way, 16 valves is around £300.
The last post was made 21 years, 241 days ago. Instead of replying here, would creating a new thread be more useful? |
