Smokey and the Bandit
lutmfurl
PostPosted: 19:56 - 05 Nov 2008    Post subject: Smokey and the Bandit Reply with quote
Hi all, new to the site and fairly new to biking. Little over a year under my belt. Recently changed up from a cb750 to a X plate 1200 S Bandit. Been a bit confused due to the bike being registered in 2000 but apparently the model (K1) is a 2001. Has the single grab rail, sweeping clock faces etc.
Anyway to my problem, In the mornings/after the bike has sat for a few hours I am finding it hard to keep ticking over for the first 10 minutes. I stick the choke on and start it up and leave it on choke for about 3 minutes. When I take it off the revs drop down to about 750 and finally cuts out. If you try to rev the bike for the first 10 minutes it revs upto about 4500 drops a couple then carries on up the clock. I can do 5 miles and it still cuts out when you roll off It also smokes alot for the first 5 minutes. I have heard that this is a common problem with the bandit along with guzzeling oil. Used a full tank in around 1000 miles.
Have tried turning the tick over up but this then causes the bike to sit to high once its done a few miles.
Anybody any clues.
Thanks in advance
Matt
We came, we saw, we drank the place dry.
PostPosted: 20:07 - 05 Nov 2008    Post subject: Reply with quote
Who told you that was a common bandit 'trait'? It wasn't the dealer that sold it to you by any chance?
I've never heard of any bike (apart from a two stroke) where smoking is 'normal'.
What colour is the smoke? Blue? White? Black?
Sounds like you have an issue...
lutmfurl
PostPosted: 20:38 - 05 Nov 2008    Post subject: Reply with quote
white smoke
lutmfurl
PostPosted: 20:43 - 05 Nov 2008    Post subject: Reply with quote
https://www.sukbog.co.uk/gallery/misc/lenny/lenny.html
have a look at this and also try googling stuff like
smoking bandit 1200 oil problem
Just noticed that there were other ppl talking about a simular thing
PostPosted: 20:50 - 05 Nov 2008    Post subject: Reply with quote
White smoke sounds like coolant rather than oil. If it were burning oil it would be blue smoke.
Have you checked your coolant levels lately? I realise that the oil level is dropping, but it is worth noting that there might be something else wrong beyond the standard issues.
It could be a blown head gasket, that would explain the loss of oil and coolant.
lutmfurl
PostPosted: 21:03 - 05 Nov 2008    Post subject: Reply with quote
is that easly fixed. How much is it likley to cost if it is the problem
lutmfurl
PostPosted: 21:04 - 05 Nov 2008    Post subject: Reply with quote
it only smokes for the first 10 minutes though
Mark_petty
PostPosted: 21:24 - 05 Nov 2008    Post subject: Reply with quote
I have a bandit 600, it always smokes first thing for about 5 minutes until its warmed up (white smoke as well)
I had the same issue as you about cutting out straight away even after a long ride. It also backfired alot. Does yours?
In the end is was my carbs totally gunked up so needed striping and cleaning.
It now runs like a dream
[Rides: Suzuki GSF600sx]
[CBT: Passed] [Theory: Passed] [DAS: Passed]
sickpup
Old Timer
PostPosted: 10:26 - 06 Nov 2008    Post subject: Reply with quote
Highly unlikely on a Bandit 12.
Davie_G71
PostPosted: 10:30 - 06 Nov 2008    Post subject: Reply with quote
Are you sure it isn't just condensation evaporating in the exhaust?
My GSXR does this, especially in the cold mornings.
Suzuki GSXR600 SRAD, 1997 & Kawasaki Z1000, 2003.
Robby
Dirty Old Man
PostPosted: 11:39 - 06 Nov 2008    Post subject: Reply with quote
On cold mornings it is quite usual for the exhaust on any vehicle to look like a lot of white smoke/steam. It will look like this until the engine is up to full operating temperature, and exhaust has some heat in too.
This will take a fair while on a bandit 12, because it is a large air/oil cooled engine. Also the reason why it won't burning coolant, because it doesn't have any.
Burning oil is still a bit of a worry though. A litre every 1000 miles is the upper end of acceptable fuel burn. I would check the crankcase breather is clear, change the oil, and take it out for a good hard thrashing. See if that sorts it out.
PostPosted: 12:10 - 06 Nov 2008    Post subject: Reply with quote
Doh!
Oil cooled. What a dumbass. Sorry. I wasn't very with it yesterday, I was off sick from work and slightly delerious.
BanditsHigh
Worse than a woman
PostPosted: 15:48 - 06 Nov 2008    Post subject: Reply with quote
From memory I am sure the 2001 B12 had some engine changes which weren't done right, result the engine burns a lot of oil.
the grim reaper
PostPosted: 15:52 - 07 Nov 2008    Post subject: Reply with quote
I had a 2002 Bandit 1200s and never had any oil burning issues, condensation is normal though. FWIW, the choke is bloody useless, mine would never idle properly although not as bad as yours is. Have you checked that the choke on the carbs isn't seizing or badly adjusted?
Grim
The last post was made 17 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 82.19 Kb
