Keep hitting neutral going from 2-1?
veeeffarr
PostPosted: 09:25 - 07 Nov 2008    Post subject: Keep hitting neutral going from 2-1? Reply with quote
Hi guys,
Have done this quite a few times, on various bikes, but done it quite a bit on the Viff...
Have tried waiting until I slow right down and then changing down gears in one go (Going 4-3-2-1, etc) instead of going (4-blip-engine brake-3-blip-engine brake-2-blip-engine brake-1) but the latter feels a lot more natural...
Any more ideas? I take it its going into neutal because I'm not giving it enough of a shove from 2-1? Would repositioning the gear lever so that it sat higher up help (So I wouldn't have to bend my foot down as much)
Thanks,
T
D O G
PostPosted: 09:41 - 07 Nov 2008    Post subject: Reply with quote
Sorry for thread mini hijack, but wtf is it with 2nd gears on bikes being shit? The SRAD had a couple of problems in the 1-2/2-1 interface, same (occasionally) with the FZR (I know it is a bit of a Yammy problem)? Is there a fundamental difficulty in getting the thing to work right?
Toby, I would go for adjusting the shifter, so you can give it a good shove into first, although I generally don't go into first unless I'm stopped. AFAIK you cannot actually put Kwaks into 1st until they are stopped.
PostPosted: 09:45 - 07 Nov 2008    Post subject: Reply with quote
Yeah, give it a more many shove downwards. Thumbs Up
You must only be tapping it for it to have happened on lots of bikes.
veeeffarr
PostPosted: 09:46 - 07 Nov 2008    Post subject: Reply with quote
I will try that Smile
I go into first quite a bit, entering small roundabouts, etc, gives me more shove when coming out of them Smile
I think it's something to do with a compromise between making second gear work well and being able to find neutral easily. If they make it so you can find neutral easily I guess they have to cut the gears in such a way that makes them weaker. Confused
Feasty
PostPosted: 09:50 - 07 Nov 2008    Post subject: Reply with quote
And probably a complete noob question, but why couldn't they just make bikes with the neutral last??
I.e 5-4-3-2-1-N-1-2-3-4-5
Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed).
Syx
PostPosted: 09:52 - 07 Nov 2008    Post subject: Reply with quote
The easiest way to do this without having to put unnecessary pressure on the mechanism is to just apply the regular amount of force you would need to shift down, and slowly release the clutch lever. This will result in the gear engaging correctly, and then you can just pull the clutch back in.
The gear will engage before you reach a point where you're moving, but if you're not sure just apply a dab of rear brake to keep the bike in the same spot.
Works for me every time. Thumbs Up
Small edit: You might want to ensure you're moving before you try to apply rear brake and shift gears! I added that bit as an extra; I've never needed it.
If you panic downshift and go too far you have no engine braking and are more likely to hit the thing you're trying to avoid. Thumbs Up
Quad bike gear boxes are like that though.
Paddy Blake
PostPosted: 09:54 - 07 Nov 2008    Post subject: Reply with quote
Hi Toby.
You need the clutch and lever adjusted right first then lube both.
If you let the revs drop to far it will be harder to change gear.You need to find out at what revs it is best to change at and do it fast.
I hope that helps.
Paddy.
PostPosted: 09:57 - 07 Nov 2008    Post subject: Reply with quote
They do, they made bikes with all sorts of arrangements. 1 down 5 up like on most modern Japanese bikes.
The C90 is 3 down.
The YB100 is 4 down.
I've seen old brits that are 1 up 3 down.
Race bikes are often 1 up 5 down or even 6 down.
I had a bike where you could choose from 1 down 4 up or 1 up 4 down and swap the levers to the left or the right.
veeeffarr
PostPosted: 10:00 - 07 Nov 2008    Post subject: Reply with quote
Thanks for the input guys, it's pretty pant filling when you're approaching something and you shift down from second only to start rolling in neutral...
carlnicholson...
PostPosted: 10:35 - 07 Nov 2008    Post subject: Reply with quote
My brand new Ninja had a wank second gear as well, you'd think for all the technology on modern bikes now they'd have cracked the art of crafting a few cogs in a box. (Before you set upon me, I expect there's a fair bit more to it than that!)
It's amazing how much of a difference adjusting the lever makes, even wearing various footwear can make a difference I've found.
"THOSE WHO RISK NOTHING, DO NOTHING, ACHIEVE NOTHING, BECOME NOTHING."
Bike_craze1
PostPosted: 13:30 - 07 Nov 2008    Post subject: Reply with quote
Happened to me.
Kick into 2nd harder, bikes always do that.
Yamaha R125 - Cagiva Mito 125 - Honda CBR 600
CBT passed: 22/07/08 Bike Theory passed: 28/03/09
Bike Test passed: 15/04/09
veeeffarr
PostPosted: 13:48 - 07 Nov 2008    Post subject: Reply with quote
Bike_craze1 wrote:
Happened to me.
2nd to 1st...
Pickle
PostPosted: 14:56 - 07 Nov 2008    Post subject: Reply with quote
You can on mine (ER-5)... Confused
I'd rather keep putting it accidentally into neutral than not be able to find the bugger, which is what I've found with the Hondas I've ridden.
Phoenix
Twisted Firestarter
PostPosted: 17:08 - 07 Nov 2008    Post subject: Reply with quote
I usually downshift a couple of gears when slowing down, then block shift the rest as I roll to a stop, clutch in. Often end up not being able to go further than neutral, so you just slowly let the clutch out until you hear a small clunk, pull it back in and it'll go into first.
carlnicholson...
PostPosted: 17:12 - 07 Nov 2008    Post subject: Reply with quote
Newer models, such as the new shape ninja, have a thing called 'Positive Nuetral Finder', don't know what it is, or how it works, but it stops you selecting second from first at a stand still so you can guarantee you're in neutral. Probably does the same going down, I never tried tbh.
strag
PostPosted: 17:46 - 07 Nov 2008    Post subject: Reply with quote
TBH if you haven't got your engine braking sorted by the time you are in 2nd you might want to think about slowing down sooner, first will lock the back wheel very easily. Personally I only ever go into first from a standstill.
carbon bling
Phoenix
Twisted Firestarter
PostPosted: 19:22 - 07 Nov 2008    Post subject: Reply with quote
I think he's referring to just engaging 1st, not releasing the clutch and slowing down using 1st, as you say it's only really appropriate for pulling away rather than slowing down.
LeeR
PostPosted: 19:51 - 07 Nov 2008    Post subject: Reply with quote
And I understand some bikes (mostly grey imports) have rotary boxes so if you knock it up from top you end up in 1st, and likewise if you knock it down in 1st you'll go "up" to top.
My claim to fame: Austin Vince nicked my pen...
quacker_boy
Cuddle Bitch
PostPosted: 21:17 - 07 Nov 2008    Post subject: Reply with quote
I'd be interested in where you heard that dude.
Every quad I've ridden have all had boxes like a bike 1-N-2-3-4-5-6. Although the only quads I've ridden have all been sport ATVs...
Tristan.
PostPosted: 21:23 - 07 Nov 2008    Post subject: Reply with quote
Farm quads I've ridden have been 4/5 up
Ben.
PostPosted: 22:46 - 07 Nov 2008    Post subject: Reply with quote
if it starts clunking of grinding you will start ti damage the box. is it just slipping into neutral then like grinding as you try to kick it into first from neutral or does it engage properley
follow my racing season
Race bike - R6
Road bike - sv650
Dalemac
PostPosted: 01:29 - 08 Nov 2008    Post subject: Reply with quote
im constantly going into first on the gpz, like when cornering and doing roundabouts.
I love to fly around them, and 2nd gear is just too lumpy on a parallel twin to produce any sort of power when turning off the roundabout.
YBR125 -> GPZ500S -> SL1000
McJamweasel
BCF Junkie
PostPosted: 17:48 - 08 Nov 2008    Post subject: Reply with quote
Is your chain tension right? If it's a bit slack it can make it harder to go between 1/2/n. Also make sure that you give it a decent knock and not just a little tap. Adjusting the gear lever may well help you and if it doesn't it's only a 2 minute job to change it.
The last post was made 17 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 129.53 Kb
