| McJamweasel |
 McJamweasel BCF Junkie
| RSixer03 |
 RSixer03 Renault 5 Driver
 Posted: 14:14 - 22 Apr 2004 Post subject: who knows? |
If it starts up ok, it sounds like that for some reason you either have a bad graphics card or the monitor is playing up.
is it a seperate graphics card?..agp? or pci? or onboard? if you could borrow one then u could test the card.
If your monitor stays blank, it might just be a busted monitor get a friends monitor to try......
 ____________________ "If everything seems under control, you're just not going fast enough."
Mario Andretti. |
| McJamweasel |
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 14:18 - 22 Apr 2004 Post subject: |
If the gfx card was knackered then it should beep. Although the pc speaker might be busted, which would be a nightmare. I doubt it's that though. Check it's connected up right though. ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 14:20 - 22 Apr 2004 Post subject: |
Haven't actually ever tried this before but would the power supply come on even though it wasn't actually connected to anything except the mains? Maybe that's all that's happening. Either faulty connection to the motherboard or the board is gubbed. ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| McJamweasel |
| dainesefreak |
 dainesefreak World Chat Champion
| McJamweasel |
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 14:31 - 22 Apr 2004 Post subject: |
Have you got a spare duron you could try? I thought it would have beeped for that too but I can't be sure on that. I'd say it's the motherboard. ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| McJamweasel |
| dainesefreak |
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 14:35 - 22 Apr 2004 Post subject: |
Take out the gfx card from your own pc and stick it in and see if it works then. ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| RSixer03 |
 Posted: 15:53 - 22 Apr 2004 Post subject: PC problems |
if it beeps when the card is out, it prob trying to tell you that you card is not in lol
Anyway when i get a problem with a piece of hardware i tend to go here and ask, they will have the answer for you, just make sure you give them as much detail as possible.
https://www.techimo.com/forum/f6/index.html
Mario Andretti. |
| AcIdBuRnZ |
 AcIdBuRnZ World Chat Champion
 Posted: 16:12 - 22 Apr 2004 Post subject: |
Hi,
Could be a few things.
RSixer....it won't beep with the card out as it would default to the on board graphics.
Could be the processor, but the POST should still beep to tell you that.
Any idea the BIOS manufacturer? e.g. Award, AMI etc. Because if you do, tell me how many beeps and I'll tell you what's wrong. I have lists for each manufacturer, and the BEEP code sheet, which tells you what the problem is in relation to the number of beeps. Sad, I know, but then I AM a computing student!
A single beep should mean that the MoBo is not detecting any faults (well, obvious ones anyway!)
As to ProXimaCore's question - no, you can't power on a PSU without it connected to something (even a case fan would draw power to test it).
The most common thing which causes a PC not to start is shagged memory (9 times out of 10!). Stick in some know good RAM and try that. But again, the POST should beep ti indicate a memory problem (TELL ME HOW MANY BEEPS!!!).
The other (long winded way) would be to try all the components in your own machine, power it on after installing each one and see what happens, this should single out the dodgy part.
Hope this helps, like I say, number of beeps would be helpful. But if it only gives 1 beep, then try my other method of swapping the components into your good machine (be careful here - it's easy to end up with 2 f***** machines!)
Good luck
Mark ____________________ Past: Honda NSR125R >> Kawasaki ER-5a2 >> Kawasaki ZZR-600e1 >> Suzuki GSXR-750Y >> Honda VTR 1000 Firestorm
"Chickity China the Chinese Chicken..." |
| McJamweasel |
| RSixer03 |
The last post was made 21 years, 249 days ago. Instead of replying here, would creating a new thread be more useful? |
